RTClib doen't work as it should - get different unix times
hello. I need some help. I get different unix time depending on where in the code i put the rtc.now(); function. Please help
#include "RTClib.h"
#include <SevSeg.h>
// Init the DS3231 using the hardware interface
RTC_DS1307 rtc;
unsigned long currentunix;
unsigned long togetherunix = 1566727200;
unsigned long sinceunix;
unsigned long sincedays;
SevSeg sevseg; //Instantiate a seven segment controller object
Serial.begin(57600);
bool resistorsOnSegments = true;
bool updateWithDelaysIn = true;
byte hardwareConfig = COMMON_CATHODE;
byte numDigits = 4;
byte digitPins[] = {10, 11, 12, 13}; //Digits: 1,2,3,4 <--put one resistor (ex: 220 Ohms, or 330 Ohms, etc, on each digit pin)
byte segmentPins[] = {9, 2, 3, 5, 6, 8, 7, 4}; //Segments: A,B,C,D,E,F,G,Period
sevseg.begin(hardwareConfig, numDigits, digitPins, segmentPins);
sevseg.setBrightness(10); //Note: 100 brightness simply corresponds to a delay of 2000us after lighting each segment. A brightness of 0
//is a delay of 1us; it doesn't really affect brightness as much as it affects update rate (frequency).
//Therefore, for a 4-digit 7-segment + pd, COMMON_ANODE display, the max update rate for a "brightness" of 100 is 1/(2000us8) = 62.5Hz.
//I am choosing a "brightness" of 10 because it increases the max update rate to approx. 1/(200us
8) = 625Hz.
//This is preferable, as it decreases aliasing when recording the display with a video camera....I think.
DateTime now = rtc.now();
currentunix = now.unixtime();
sinceunix = currentunix - togetherunix;
sincedays = sinceunix / 60;
sincedays = sincedays / 60;
sincedays = sincedays / 24;
sevseg.setNumber(sincedays, 0);
sevseg.refreshDisplay(); // Must run repeatedly; don't use blocking code (ex: delay()) in the loop() function or this won't work right
Not sure what library you're using, but are you sure you don't need an rtc.begin() or similar call in setup?
Please post the code, which demonstrates this problem along with the values seen.
Please post using code tags, as described in point 7 of this posting guide .
