Run code if serial connection is idle for X min
Here is my code. I have a simple ANDON light that I want to do a certain function when it doesn't receive serial input after x min.
int red = 11;
int green = 12;
int yellow = 13;
String readString;
  pinMode(red, OUTPUT);
  pinMode(green, OUTPUT);
  pinMode(yellow, OUTPUT);
  Serial.println("serial on/off test 0021"); // so I can keep track
  while (Serial.available()) {
    delay(3);
    char c = Serial.read();
    readString += c;
  if (readString.length() >0) {
    Serial.println(readString);
    if(readString.indexOf("0") >=0)
      digitalWrite(red, LOW);
      digitalWrite(green, LOW);
      digitalWrite(yellow, LOW);
      Serial.println("ALL OFF");
    if(readString.indexOf("1") >=0)
      digitalWrite(red, HIGH);
      Serial.println("RED ON");
        if(readString.indexOf("2") >=0)
      digitalWrite(green, HIGH);
      Serial.println("GREEN ON");
            if(readString.indexOf("3") >=0)
      digitalWrite(yellow, HIGH);
      Serial.println("YELLOW ON");
    readString="";
Ok does this look good?
Im not getting any luck. Sorry if I did it wrong
int red = 11;
int green = 12;
int yellow = 13;
String readString;
unsigned long timeSinceLastSerial;
unsigned long timeout = 10000;  // One minute
  Serial.println("Connection Established");
  if(timeSinceLastSerial > timeout){
      Serial.println("ALL ON"); // DO your thing here
    delay(3);
    readString += c;
    readString="";
Sorry the goal is when the Arduino doesn't receive any input from the PC it will run the code to get all the lights on.
A simple way to read a line, and do something with it.
In my simple example, I just print the line.
After 30 seconds of no serial reception, I print a message.
const byte maxMsgLen = 16;
const byte cbLF = 10;
const byte cbCR = 13;
  Serial.println(F("echo lines with timeout"));
uint32_t lastReception;
  if (handleSerial()) {
    lastReception = millis();
  if (millis() - lastReception >= 30000) {
    Serial.println(F("30 seconds no reception."));
void oneLineReceived(const char * buffer) {
  Serial.println(buffer);
bool handleSerial() {
  static uint8_t bIndex;
  static uint8_t buffer[maxMsgLen + 1];
  bool lineReady = false;
  if (Serial.available()) {
    uint8_t inChar = Serial.read();
    if (inChar != cbLF) {
      if (inChar == cbCR) {
        lineReady = true;
        buffer[bIndex++] = inChar;
        lineReady = (bIndex == maxMsgLen);
      if (lineReady) {
        buffer[bIndex] = 0;
        oneLineReceived((const char*)buffer);
        bIndex = 0;
    return true;
  return false;
23:07:53.892 -> echo lines with timeout
23:07:59.313 -> one
23:08:03.313 -> two
23:08:06.873 -> three
23:08:36.902 -> 30 seconds no reception.
Thanks. I was able to take what you sent and work through. I was able to correct my issue.
