Hi, i run my servos via an array. It works good. The array is called 'Servos' and have and slots. In my for loop i can run a servo by
Servos[1].write(pos);
or
char vals = 1;
Servos[vals].write(pos);
but my whole program is talking over serial with processing. Processing sends a byte which is stored in 'val'. So if i send '11' from processing char 'type' = 1' and char 'val' = '1'. But when trying to run the servo array with 'val' the servo doesent run, even if val=1. What is going on here? There are probably a lot of other problems in my code some might be related to this problem and some not, so bare with mig
#include <Servo.h>
const int NoServos = 8; // number of servos in legs
Servo Servos[NoServos]; // Define servo array
int ServosPins[NoServos] = // Servo pins, starting at servo0
2,3,4,5,6,7,8,9};
long previousMillis = 0; // will store last time LED was updated
long interval = 50; // interval at which to blink (milliseconds)
boolean readSerials = true;
boolean isFunctionDone=false;
char val; // Data received from the serial port
char vals = 1; // Data received from the serial port
char type; // Data received from the serial port
int pos = 0; // Set servo to 0
char myservo;
int solenoid = 13;
for (int thisServo = 1; thisServo < NoServos; thisServo++)
Servos[thisServo].attach(ServosPins[thisServo]);
pinMode(solenoid, OUTPUT);
establishContact();
if(currentMillis - previousMillis > interval) {
// save the last time you blinked the LED
updateSerialRead();
void updateSerialRead(){
if (Serial.available() > 0 ) { // If data is available to read,
type = Serial.read(); // read it and store it in value
val = Serial.read(); // read it and store it in value
if (val > '0' && type > '0'){
decideType();
readSerials=false;
else{
Serial.println("STANDBY");
void decideType(){
if(type == '1'){
type1();
void type1(){
if (type == '1')
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
Servos[val].write(pos);
delay(15); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
Servos[val].write(pos); // tell servo to go to position in variable 'pos'
isFunctionDone=true;
if (isFunctionDone=true){
functionDone();
void functionDone(){
Serial.println("666");
void establishContact() {
while (Serial.available() <= 0) {
Serial.println("A"); // send a capital A
delay(300);
Errm,
AWOL, servo zero was left out. its a mistake made by me. Ill correct it. I dont have any good answer to why testing if 'type' is true twice, just a mistake in my mind!
Robin2
in the end ill have 24 servos divided on 4 types. thats why the first byte = type and the second bytes = val.
If there is at least one byte to read, read them both. I'd ask how that's working for you, but I already know.
PaulS:
Paul, what you are writing is ringing a bell in my head. it seems obvious but still not…
Am i only reading the first byte?
Im picturing something like this.
if (Serial.available() == 2 ) { // If there's 2 bytes to read,
type = Serial.read(); // store the first byte in type (dont know how)
val = Serial.read(); // store the second byte in val (dont know how)
if (Serial.available() >= 2 ) { // If there's at least 2 bytes to read,
[/quote]
I get it. But do i need to define so that the first byte = type and the second = val?
With the minor changes i made nothing changed.
zoomkat
I will have '4 servo' groups/types, each group/type will have a different command.
Robin2
ill have 24 servos and 6 solenoids.
I think ill need at least 35 outputs
#include <Servo.h>
2,3,4,5,6,7,8,9};
int solenoid = 13;
establishContact();
updateSerialRead();
if (Serial.available() >= 2 ) { // If data is available to read,
decideType();
readSerials=false;
else{
void decideType(){
if(type == '1'){
type1();
void type1(){
functionDone();
delay(300);
chrille_dill:
If the bytes are always in the same order you can infer which is which
The upper and lower case letters give you 62 options counting the characters in between.
Edit to add ...
I have had a look at your code and I can't figure out what you are trying to do.
What is the purpose of the function establishContact() ? Why not a simple "Serial.println("I'm ready");"
What is the purpose of "readSerials=false;" - it isn't used anywhere.
What is the purpose of "type"? - it isn't effectively used anywhere
Val seems to select the servo - why not call it servoID to make it more obvious?
The function "functionDone()" doesn't seem very useful.
...R
So you insist that i should use only ONE variable? The reason i use 'type' is because i wanted 5 functions, type1, type2, type3…
Each type contain a different servo setting. I thought it was more simple to have multiple types, and the solenoids wont be controlled in the same way as the servos. The solenoids will be in type5, and will be controlled by HIGH / LOW.
I still don understand why my code doesnt work, where does everything go wrong?
establishContact & functionDone communicates with processing which sends commands to a .PHP-file.
It looks like you're sending ascii characters in the range '1' to '8' to be used to populate val. Then you use val as an index into your servo array. Character '1' is decimal 49 though, so you're addressing memory far off the end of your array, hence the failure you see. You'll need to subtract '0' from it:
val=val-'0';
Robin 2 — i now updated val to motorID and type to typeID for a better overview.
wildbill:
i tried your suggestion, but it still doesnt position the servo. the subtraction didnt change anything.
In 'void typeID1(){' i print the value of 'motorID' which is printing it correct (1) but the servo doesnt move.
Again, if i define
'motorID = 1'
the servo moves, but when
motorID = Serial.read();
it doesnt move. but it prints '1' in serial print.
Updated code
#include <Servo.h>
2,3,4,5,6,7,8,9};
long interval = 50;
char motorID; // Data received from the serial port
char typeID; // Data received from the serial port
int solenoid = 13;
establishContact();
updateSerialRead();
typeID = Serial.read(); // read it and store it in value
motorID = Serial.read(); // read it and store it in value
if (motorID > '0' && typeID > '0'){
motorID=motorID-'0';
motorType();
else{
void motorType(){
if(typeID == '1'){
typeID1();
void typeID1(){
Serial.println(typeID);
Servos[motorID].write(pos);
Servos[motorID].write(pos); // tell servo to go to position in variable 'pos'
functionDone();
delay(300);
You can't create the name of a function on the fly. Those references are set by the compiler. There are complex ways to get the same effect but it would be much simpler just to pass a parameter such as motorType(typeID)
I sort-of understand your intended use of types now, but I can't help feeling there should be a simpler way to do it. Can you describe the sort of things that each different type is intended to achieve?
