There seems to be a fundamental problem here. You should follow Robin's advice. Good Luck.
Robin2:
We are now at Reply #39 and very little progress seems to have been made - if anything success seems to further away. I think the most productive thing now is to put all your existing code to one side and start again - seriously.Write a very short program to make one stepper move at the speed you require - use the second example in the link I gave you in Reply #1 as your starting point.
When that is working (and only then) add the code for a second motor so it moves at a different speed - to prove that it is being controlled separately, but at the same time.
...R
Ok, you've right.. I'll try to restart by basic movements.. Thank you!
DKWatson:
Sure it is.. it is my first time coding.. anyway thank you for your help..
I tryed to start again by your tutorial example, Robin, and then, after i moved both motors, the temptation to take a look again at the program that nearly worked last evening was too much.. Sorry.
So i did it and, it works! Every 1512 Xsteps, Y makes 88 steps, simultaneously. Now i only need to make the CCW function and find out how to call it in the right way to make all work fine.
#define EN 8
//Direction pin
#define X_DIR 5
#define Y_DIR 6
//Step pin
#define X_STP 2
#define Y_STP 3
int StepperPosX = 0; // How far we've traveled on X
int StepperPosY = 0; // How far we've traveled on Y
int Delay = 200;
int StepperDestinationX = 1600;
int StepperDestinationY = 88;
int StepperDestinationXB = 1512;
void pulse_X_CW(int steps) {
for (int i = 0; i < steps; i++) {
digitalWrite(X_DIR, HIGH);
digitalWrite(X_STP, HIGH);
delayMicroseconds(Delay);
digitalWrite(X_STP, LOW);
void pulse_Y_CW(int steps) {
digitalWrite(Y_DIR, HIGH);
digitalWrite(Y_STP, HIGH);
digitalWrite(Y_STP, LOW);
void setup(){
pinMode(X_DIR, OUTPUT); pinMode(X_STP, OUTPUT);
pinMode(Y_DIR, OUTPUT); pinMode(Y_STP, OUTPUT);
pinMode(EN, OUTPUT);
digitalWrite(EN, LOW);
void loop(){
StepperPosX ++;
if (StepperPosX < StepperDestinationX) {
pulse_X_CW (StepperDestinationX);
StepperPosX = StepperPosX +1; // Record X step
if (StepperPosX = StepperDestinationXB) {
pulse_Y_CW (StepperDestinationY);
if (StepperPosX == StepperDestinationX) {
StepperPosX = 0;
Glad you have it working.
...R
Robin2:
Glad you have it working....R
Actually i realized that steppers weren't at sync, i thought that they were just slowing down when both were timing because of the sum of delays, but at higher delays i seen that the X was totally stopped meanwhile the Y was doing its movements.
So i made this correction to the program functions:
void pulse_Y_CCW(int steps) {
digitalWrite(Y_DIR, LOW);
A big thank you for your and DKWatson's precious help (:
So everything is good?
