running 8mm stepper motors with arduino
I have concluded that this is better in the Motors, Mechanics, Power and CNC section, so if the mods want to delete or merge this with a post I have created there please do so
I have made some gauges that represent aircraft engine gauges that use x27-68 steppers with A4988 drivers, and they work great for my purposes. The A4988 boards have a 12v supply and the X27-68 motors are perfectly happy with it, if a bit less smooth than I would like. They are fed by an arduino programmed with a system called DCS bios, that reads in game data from a flight sim and outputs it to the arduino.
However for two of the gauges I have made, there are actually two gauges on the same device, one representing the x10 digit, then a smaller sub-gauge that is not concentric to the main gauge that displays the x1 digit. It forms a sort of gauge within a gauge, but is small.
My intention is to try and use some 8mm diameter stepper motors that are (apparently) used in cameras and some home electronics (CD trays maybe?). I have them, they are four wire units and I have tested them using the same A4988 board setup as the X27-68 motors and so I know that they behave the same, except that they get very hot, presumably because the A4988 board is supplying too high voltage. It's a shame, as if it were not for that, I could easily just control them using the existing hardware.
As it is a gauge, there is virtually zero torque involved, the only thing it has to move would be a tiny, lightweight plastic pointer. I would need something to time it, that's the second part of this and I'll come to that later as a separate question.
The motors, from what I can gather, operate at 3v. So what I need is either to be able to control the steppers directly using the Arduinos, or find a stepper driver that is capable of working with arduinos to control these diminutive motors, so the first question is what is available to do this? Can I use two outputs from the arduino to control direct?
The second part is that I need to set a zero for the stepper. On larger gauges I have an optocoupler and a bit of code in the sketch that works with that, but this is tiny and the optocouplers just don't fit. So for those very small applications, what methods are available that would work with the arduinos that would allow me to set a zero position?
Any thoughts and suggestions gratefully received
Les
Apologies, I have just realised that for the second part of the question I didn't specify dimensions.
The large gauge in which this smaller gauge sits is 52mm dimeter, and the smaller gauge is only 15mm in diameter and sits up and to the right of the main gauge axis
Cheers
Les
Pololu does a variety of stepper drivers. If you need to use a 3V supply, it looks like this one would do it: DRV8834 Low-Voltage Stepper Motor Driver Carrier.
