mmmmmmmmmm, Thank you very much for the quick reply but i tried that as i had read it somewhere else, i have tried it and cant seem to make it work. The standard fade sketch:
Fade
This example shows how to fade an LED on pin 9
using the analogWrite() function.
This example code is in the public domain.
int led = 9; // the pin that the LED is attached to
int brightness = 0; // how bright the LED is
int fadeAmount = 5; // how many points to fade the LED by
// the setup routine runs once when you press reset:
// declare pin 9 to be an output:
pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
// set the brightness of pin 9:
analogWrite(led, brightness);
// change the brightness for next time through the loop:
brightness = brightness + fadeAmount;
// reverse the direction of the fading at the ends of the fade:
if (brightness == 0 || brightness == 255) {
fadeAmount = -fadeAmount ;
// wait for 30 milliseconds to see the dimming effect
delay(30);
Works fine, so i changed it to this (Just copying out the loop to the setup section)
Fade
delay(30);
And absolutely nothing happens,the LED doesn't light at all. So, what amazingly simple mistake have i made because there is bound to be one. My logic says that the loop cannot complete because it doesn't go back into the loop once it gets to the end to check the value, but that's just my logic of course. Also i want it to stop once it gets to max brightness but i found that if i take out the fade back down bits of the code i still get nothing.
Fade
//if (brightness == 0 || brightness == 255) {
//fadeAmount = -fadeAmount ;
//delay(30);
As you can see i'm no expert here......................
