I want this void, if run sometime into the sketch to set a boolean after x time.
I used this code for it:
boolean off = false;
boolean set = false;
void switchOff()
unsigned long previousMillis2;
unsigned long currentMillis2 = millis();
if (set == false){
previousMillis2 = millis();
set = true;}
if (currentMillis2 - previousMillis2 >= interval2)
{off = true;}}
void loop(){
switchOff();
My thought is, it runs the code, sets previousMillis2 to "5000".
Now it compares those "5000" to millis(), and if there is a difference of "2000" (interval2) it sets boolean off to true.
Every time you call the function previousMillis2 will be set to a new, unspecified value and currentMillis2 will be set to millis()
As previousMillis2 has an unknown value how likely is this to be true when you want it to be ?
If you want the value of previousMillis2 to persist between calls to the function declare it as static but set it equal to currentMills2 before exiting the function.
Alright, I moved the unsigned long… outside of the void.
UKHeliBob:
By that you mean writing static rather than unsigned, right?
If thats what you mean I’ve tried it but I didnt get it to work yet.
I’ve added a LED on inside the “if (set == false)” function and I know its called, however in the next function “off” doesnt get set to true.
