RVS Touch doorbell with Neopixel
Hi i need help with my project.
I want to make a door bell with a adafruit Neopixel ledring NeoPixel Ring - 16 x 5050 RGB LED with Integrated Drivers : ID 1463 : $9.95 : Adafruit Industries, Unique & fun DIY electronics and kits inside.
The doorbell must work with the capsense and give a little pulse feedback to activate my Fibaro binary sensor ( http://domotica4all.com/video-game-review/fibaro-universal-binary-sensor/ )
This sensor with rigger my doorbell and sent a email or text.
Who can help me finish my project i will add the ino files i used for this project.
If you help me finish this project i will sent you a RVS doorbell!!
Hi, welcome to the forum.
Could you modify you first post ? Please put the sketch between code tags < code > and < / code >
What is your question ?
Hi
I made this stainless steel button inside is a adafruit Neopixel ledring connected with Red/yellow/black wires.
I want the led ring to change colors and the middle of the button used as a capsense button that will
Sent a signal to my Fibaro binary sensor
the led ring does not have to change color as the button is pressed it just has to keep on changing color.
#define PIN 6
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
// and minimize distance between Arduino and first pixel.  Avoid connecting
// on a live circuit...if you must, connect GND first.
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  // Some example procedures showing how to display to the pixels:
  rainbow(20);
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, c);
      strip.show();
      delay(wait);
void rainbow(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256; j++) {
    for(i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel((i+j) & 255));
    strip.show();
    delay(275);
//Theatre-style crawling lights.
void theaterChase(uint32_t c, uint8_t wait) {
  for (int j=0; j<10; j++) {  //do 10 cycles of chasing
    for (int q=0; q < 3; q++) {
      for (int i=0; i < strip.numPixels(); i=i+3) {
        strip.setPixelColor(i+q, c);    //turn every third pixel on
      strip.show();
      delay(wait);
        strip.setPixelColor(i+q, 0);        //turn every third pixel off
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
   return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  } else if(WheelPos < 170) {
    WheelPos -= 85;
   return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
   WheelPos -= 170;
   return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
You have to help me out here. I'm having troubles with your question. Is your question how to add a button ?
That Fibaro sensor is confusing !
The site of Fibaro doesn't even have a seperate page for that sensor. The sensor doesn't have a good name, it it sometimes called "universal sensor" or "binary sensor" or "universal binary sensor".
I assume it is this one ? http://domotica4all.com/video-game-review/fibaro-universal-binary-sensor/
I didn't use NeoPixels myself, but Adafruit has many examples.
Is the rainbow working ?
Using an Arduino as capacitive sensor is not very reliable.
You can start with the CapacitiveSensor library, and if that is not good enough, use a special chip.
http://playground.arduino.cc/Main/CapacitiveSensor
Use version 05. This is the page of the maker of version 05:
https://www.pjrc.com/teensy/td_libs_CapacitiveSensor.html
Do you know how to include that library in your project ?
This is a special chip: Standalone 5-Pad Capacitive Touch Sensor Breakout - AT42QT1070 : ID 1362 : $7.50 : Adafruit Industries, Unique & fun DIY electronics and kits
Hi
The Led ring is working with the adafruit Ino i just don't know how to get the capsense and led working together at once.
and if the IN1 is triggered on the fibaro it will trigger out1 on the fibaro board and activate
my doorbell and sent a text to my mobile phone.
I hoped that the capsense would work otherwise i have to make a whole new doorbell.
Thx
Did you see the example of the CapacitiveSensor Library at pjrc.com ?
Can you make a test sketch for only touching the button without leds, to see if you can make that work ?
The rainbow() and the other function use a delay. During those delays, nothing can be done.
So you have to remove those delays and rewrite some of the code.
Or replace the delay() with a function that tests also the sensor during the delay.
The best way to do a few things at once, is to use the millis() function. That way a sketch can be created without any call to the delay() function and still have a lot of timing and waiting. The waiting has however no influence on other tasks that run at the same time. It requires that a sketch is specific written for that.
The BlinkWithoutDelay shows the use of millis() : http://arduino.cc/en/Tutorial/BlinkWithoutDelay
