I'm working on a project using a MKR GSM 1400 and a MKR ENV Shield to log environment values in a remote location.
Everything is working fine, the documentation is great
However, I have a concern about the battery. I'm using a 10000 mAh LiPo battery, and I read that it should not be discharged under 3.2V.
I am planning on leaving the setup somewhere, and it might fully discharge before I come back to get it back. Is there a saftey concern here? Meaning that the Arduino could be continuously discharging the battery below its recommended value? Or is there a function already implemented in the MKR GSM 1400 to prevent that behaviour?
The same interrogation goes for overcharging, but that can be easily handled since I can be around the device when that happens.
In general its recommended not to let lithium batteries disscharge below 3.3V to 3.0V. If you have a phone\camera the circuit in that will cut off the battery around that point.
My view is that the discharge circuits in the batteries are not really intended to be used routinely, much better for the device using the battery to cut of at an appropriate point. Perhaps the circuits are there as a last ditch safety measure.
Whether its safe to re-use a lithium battery thats been discharged down to 2.4V, I dont know.
