Beginner in Arduino and ESP-32 needs help.
I bought an ESP32-WROOM-32 and i realize that there are some things who are not the same comparing to Arduino Nano,UNO or Mega. One of the things that i realized who are diferent is how to store and read data from the controler. I want to save some data to EEPROM, to retain that value even when the device is switched OFF.
I have the following code that i use all the time in mine little projekts whit Arduino Boards. The code consist in creating a Oled Menu where i can navigate true pages and change Int values and this values are stored in the EEprom.
The same code i uploaded to the esp32 without any problem and the Menu works fine. I can change the Int values. The problem is that after switching OFF/ON the board the values are not persistence.
I Googled already for some tutorials in the Internet about EEprom with ESP32 and Preferences Library with ESP32 and tried to implement it , but unfortnally without result.
#include <EEPROM.h>
#include <OneButton.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define DISP_RESET -1
const char*Vartext[] {"Data_0", "Data_1", "Data_2"};
const byte maxAnz = sizeof(Vartext) / sizeof(Vartext[0]);
const int mindata[maxAnz] {0, 0, 0};
const int maxdata[maxAnz] {10000, 200, 300};
uint32_t longstart;
byte Varindex;
byte Page = 0;
bool input;
bool changed;
bool datachanged ;
// data in struct to save on EEprom
struct mydaten {
int VarData[maxAnz];
} mydata;
const byte pinsel = 16; // select Button
const byte pinplus = 4; // Plus Button
const byte pinminus = 5; // Minus Button
OneButton Btnsel(pinsel, true);
OneButton Btnplus(pinplus, true);
OneButton Btnminus(pinminus, true);
Adafruit_SSD1306 DISP(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, DISP_RESET);
EEPROM.get(0, mydata); // Read Data from EEPROM
for (byte i = 0; i < maxAnz; i++) {
checkminmax();
changed = true;
Btnsel.attachClick(selClick);
Btnsel.attachDoubleClick(selDblClick);
Btnplus.attachClick(plusClick);
Btnplus.attachDuringLongPress(plusDurPress);
Btnplus.attachLongPressStart(LongStart);
Btnminus.attachClick(minusClick);
Btnminus.attachDuringLongPress(minusDurPress);
Btnminus.attachLongPressStart(LongStart);
DISP.begin(SSD1306_SWITCHCAPVCC, 0x3C);
DISP.clearDisplay();
DISP.setTextWrap(false);
DISP.setTextSize(2);
DISP.setTextColor(WHITE);
DISP.setCursor(20, 30); DISP.print(F("Menu"));
DISP.display();
delay(2000);
Btnsel.tick();
Btnplus.tick();
Btnminus.tick();
if (input)Displayinput();
else Display(Page);
void saveEEprom() {
if (datachanged) {
datachanged = false;
#ifdef debug
Serial.println("Save in EEprom");
#endif
EEPROM.put(0, mydata);
void selClick() {
changed = true;
if (input) {
Varindex++;
if (Varindex >= maxAnz) Varindex = 0;
else {
Page++;
if (Page >= 3) Page = 0;
void selDblClick() {
if (input) saveEEprom();
input = !input;
changed = true;
void plusClick() {
click(1);
void minusClick() {
click(-1);
void plusDurPress() {
longclick(1);
void minusDurPress() {
longclick(-1);
void LongStart() {
longstart = millis();
void click(int inc) {
if (input) {
changed = true;
datachanged = true;
mydata.VarData[Varindex] += inc;
checkminmax();
void longclick(int direction) {
static uint32_t oldtime;
int inc = 10;
if (millis() - longstart > 5000) inc = 100;
if (millis() - oldtime >= 100 && input) {
oldtime = millis();
changed = true;
datachanged = true;
mydata.VarData[Varindex] += inc * direction;
checkminmax();
void checkminmax() {
if (mydata.VarData[Varindex] < mindata[Varindex]) {
mydata.VarData[Varindex] = mindata[Varindex];
if (mydata.VarData[Varindex] > maxdata[Varindex]) {
mydata.VarData[Varindex] = maxdata[Varindex];
void Displayinput() { // Display bei input
if (changed ) {
changed = false;
DISP.setCursor(0, 0); DISP.print("input");
DISP.setCursor(0, 20); DISP.print(Vartext[Varindex]);
DISP.setCursor(10, 40); DISP.print(mydata.VarData[Varindex]);
DISP.display();
void Display(byte Page) {
if (changed) {
changed = false;
if (Page == 0) {
DISP.setTextSize(1);
DISP.print("variable Value");
byte row = i * 10 + 10;
DISP.setCursor(0, row);
DISP.print(Vartext[i]);
DISP.setCursor(80, row );
DISP.print(mydata.VarData[i]);
else if (Page == 1) {
DISP.setCursor(0, 0); DISP.print("Page 1");
else if (Page == 2) {
DISP.setCursor(0, 0); DISP.print("Page 2");
DISP.display();
Thanks in advance for some help
