Hello everyone and so sorry to the moderators for repeat my question..
I have a RFID-ID20 + ArduinoUNO
I want to read a tag and save it in EEPROM (between 10 to 29)
read a second tag and save it in EEPROM (between 30 to 49)
when my code read a tag saved before in EEPROM must delete this tag only between positions where this tag had been saved before
currently
-if read a tag that before was saved between 30 to 49 my code work fine.
my problem:
- if read a tag that before was saved between 10 to 29 my code delete the EEPROM between 10 to 49, here must delete only between 10 to 29
#include <EEPROM.h>
char code[15];
int val = 0;
int bytesread = 0;
int led = 13;
int addr = 10;
int addr2 = 30;
byte x= 1; // (00000001)
pinMode(13, OUTPUT);
pinMode(12, OUTPUT);
if(Serial.available() > 0)
if((val = Serial.read()) == 10)
bytesread = 0;
while(bytesread < 15)
if( Serial.available() > 0)
val = Serial.read();
if((val == 10)||(val == 15))
code[bytesread] = val;
bytesread++;
Serial.print("tag read: ");
Serial.println(code); //tag1 x2400CC392AFBxxx tag2 x2400CC572897xxx
bool match1 = true;
byte offs1=10;
bool match2 = true;
byte offs2=30;
//comparation1 value in eeprom with value read-tag
for (byte b=2; b<13; b++)
if (EEPROM.read( b + offs1) != code [b])
match1 = false;
if (match1 == true)
Serial.println("ok position1 - tag deleted from position1, EERPOM 10 to 29");
digitalWrite(13, HIGH);
delay(250);
digitalWrite(13, LOW);
delay(250);
bitWrite(x, 1, 0);
//delete EEPROM between 10 to 29
for (int i = 10; i < 29; i++)
EEPROM.write(i, 0);
//comparation2 value in eeprom with value read-tag
if (EEPROM.read( b + offs2) != code [b])
match2 = false;
if (match2 == true)
Serial.println("ok position2 - tag deleted from position2, EERPOM 30 to 49");
digitalWrite(12, HIGH);
delay(250);
digitalWrite(12, LOW);
delay(250);
bitWrite(x, 2, 0);
//delete EEPROM between positions 30 to 49
for (int i = 30; i < 49; i++)
EEPROM.write(i, 0);
//bitread position 1
if (bitRead(x,1) == 0)
//write 1
bitWrite(x, 1, 1);
//write in eerpom
for(byte b=0; b<bytesread; b++)
{ //addr = start in position 10
EEPROM.write(addr + b, code[b]);
//turn on led pin13
delay(250);
delay(250);
Serial.println("1 at position 1 of X - Tag saved at position1, 10 to 24 in EEPROM");
//bitread position 2
if (bitRead(x,2) == 0)
//write 1
bitWrite(x, 2, 1);
//write in eerpom
{ //addr2 = start in position 30
EEPROM.write(addr2 + b, code[b]);
//turn on led pin12
delay(250);
delay(250);
Serial.println("1 at position 2 of X - Tag saved at position2, 30 to 44 in EEPROM");
Thanks for any help
