Save the ADC data to SDRAM of Portenta H7 not works
Hi. we are trying to save the ADC data to SDRAM of Portenta H7, but not works.
As you can see in the end of the code we use digitalWrite(LEDG, LOW); to see if the code go to there, but we never reach it.
We don't know why.
Any suggestion?
Thanks
//#include "FATFileSystem.h"
//#include "SDMMCBlockDevice.h"
#include "SDRAM.h"
#define analogPin A5
//SDMMCBlockDevice block_device;
//mbed::FATFileSystem fs("fs");
// REDIRECT_STDOUT_TO(Serial);
  pinMode(A5, INPUT);
  pinMode(LEDB, OUTPUT);
  pinMode(LEDG, OUTPUT);
//    while(1){
//    int err =  fs.mount(&block_device);
//    if(err){
//     digitalWrite(LEDR, LOW); // Not detect the SD CARD
//     delay(50);
//    }else{
//     digitalWrite(LEDR, HIGH); //detect the SD CARD
//     break;
//     // int err = fs.reformat(&block_device);  // seriously don't want to format your good data
  SDRAM.begin();
  while (!Serial);
  analogReadResolution(16);
  digitalWrite(LEDB, LOW);
  int arrSize = 1000, iter;
  unsigned int previousTime = 0;
  float ref_voltage = 5.0;
  uint16_t *analogVal =
      (uint16_t *)SDRAM.malloc(arrSize * sizeof(uint16_t)); // 2MB array;
  if (analogVal == NULL) {
    Serial.print("Oops, too big :)");
  //int a = analogRead(analogPin);
  Serial.print("000");
  for (int iter = 0; iter < arrSize; iter++) {
    analogVal[iter] = analogRead(analogPin);
//    while (1) {
      // Pause 50 microseconds (the samping rate is 20000 sampling/s)
//      unsigned int currentTime = micros();
//      if (currentTime - previousTime >= 50) {
//        previousTime = currentTime;
//        break;
//  char myFileName[] = "fs/01.txt";   // "fs/" needs to be there, think fileSystem
//  FILE *myFile = fopen(myFileName, "w");          // "a" for append (add to file), "w" write, "r" read ??
//  float adc_voltage = 0;
//  //int tem = 0;
//  for(iter = 0; iter < arrSize; iter++){
//  //adc_voltage  = (*(analogVal+iter) * ref_voltage) / 65536.0 * 1000.0;
//  fprintf(myFile,"%d\r\n",analogVal[iter]);
//  fclose(myFile);
  //Serial.print(analogVal[5326]);
  SDRAM.free(analogVal);
  //Serial.print("Finish");
  while (1)
I think the issue is: SDRAM is a class. You call .begin() directly on the class, NOT at an object.
I do this in my code:
#include <SDRAM.h>
Sorry, too early...
#include <SDRAM.h>
SDRAMClass sdram;
    //initialize SDRAM, even we do not use yet
    sdram.begin();
#if 0
    GsdramStart = (uint8_t*)sdram.malloc((8 * 1024 * 1024)/8 - 12);     //first 12 bytes are used for malloc?
#else
    GsdramStart = (uint8_t*)0x60000000;                                 //hard-coded start of SDRAM (bank 1, NOR/PSRAM)
#endif
    if (GsdramStart)
        strcpy((char*)GsdramStart, (const char *)"SDRAM");              //0x60000000, but string starts at 0x6000000C
    //before, on 0x60000008 seems to be the allocated length
I think, you need an instance of SDRAM, not SDRAM.begin() (on the class directly).
The fact, that you never reach this digitalWrite(LEDG, LOW) is:
  • you crash when trying to write to SDRAM
  • your code ends up in HardFaultHandler (do you see a red "morse-coding" LED?)
  • your SDRAM was initialized (not enabled) via SDRAM.begin() (because you need instance of SDRAM and then sdram.begin())
This is the "trouble" with OOP, C++ on embedded system. You can have a CLASS.begin() method (a static function), but it is not the same as SDRAM sdram.begin() - now the constructor, the static function is not really a constructor).
You do not get a compile error when doing SDRAM.begin() ? Very strange, it should complain if static member function is not defined.
Try really:
SDRAM sdram;
sdram.begin();
instead of:
SDRAM.begin();
(and have an instance, object of SDRAM, not just the class definition only).
