Hi all,
i have a long list of variables i want to save and load using EEPROM. Currently i am saving and loading each variable by the method shown below...
uint16_t totalBytes = 0;
EEPROM.put(totalBytes, var1);
totalBytes += sizeof(var1);
EEPROM.put(totalBytes, var2);
totalBytes += sizeof(var2);
EEPROM.put(totalBytes, var3);
totalBytes += sizeof(var3);
What i'd like to do is create an array with all of the variable names in it and then substitute those names into the code. That way i could do something like this...
string arrayNames[] = {"var1", "var2", "var3", "etc"};
uint8_t numberOfVariables = 10;
for (int i = 0; i < numberOfVariables; i++) {
EEPROM.put(totalBytes, arrayNames[i]);
totalBytes += sizeof(arrayNames[i]);
I realise that the EEPROM.put will just save the value of "var1", "var2" etc to the EEPROM and the sizeof() will just tell me the size of arrayNames[i]. Is there any way to make the compiler read the text as a variable name and not just treat it as a variable in it's own right.
There would be lots of benefits to doing it the second way and not the first way but despite a lot of Google searching i can't find if this is possible or not. I used to code PHP and this sort of thing was possible in that language which is why i had the idea to try it in Arduino as well.
If this just isn't possible it would be good to know so i can stop searching and leave my code as it is.
Cheers
NM
