I am working on an intelligent plant watering system. It should water the plants when the moisture value gets too low. It says "lv" and "hv" are not declared in this scope. Here are 2 screenshots:
Please don't post pictures of code.
Your problem is you declared variables local to the code blocks for the if and else statements.
Declare hv and lv as global and then just assign values to them in the if/else statement
It still gives me the same errors.
const int pumpPin = 12;
const int lv = 246; //change this to 123 if you are watering plants that are not vegetables
const int hv = 491; //change this to 246 if you are watering plants that are not vegetables
int m = analogRead(0);
if (m <= lv){
digitalWrite(pumpPin,HIGH);
if (m >= hv){
digitalWrite(pumpPin, LOW);
The variables lv and hv were declared as local variables.
To be used in various functions they need to be declared as global.
Follow @ruilviana suggestion and
Change it to this:
const int pumpPin = 12; // declare pump pin
// no more code needed here for now
int m = analogRead(0); // get analog input value
if (m <= lv){ // check if analog input is lower then low value
digitalWrite(pumpPin,HIGH); // turn pump on
if (m >= hv){ // check if analog input is higher then high value
digitalWrite(pumpPin, LOW);// turn pump off
if (m <= lv){
if (m >= hv){
Try this. The change is small but it makes GLOBAL variables.
void setup() is a function. Variables declared inside of functions or inner loops STAY inside of them. If the variables are declared static, they keep their values otherwise they're gone when the function returns or the inner loop ends. Temporary variables are put on the stack and static variables go on the heap. On AVR's, conserve your RAM to not using an int where a byte (unsigned) or a char (signed) will do. Pin numbers should be bytes forinstance.
