Scheduler.h and Nano
I want to have two sets of LEDs flashing at different rates running at the same time. Since scheduler.h is not compatible with Nano, how else may I achieve this as easy as it would be if said program was compatible? Thank you. Attached is my current code in which only the 1st set of LEDs flash. Thank you in advance, and I have search forum but wanted some more help.
int ledDelay = 50; // delay by 50ms
int red2 = 2;
int red3 = 3;
int wig4 = 4;
int wig5 = 5;
int onTime1 = 500; //Declare on time as .5 second
int offTime1 = 500; //Declare on time as .5 second
pinMode(red2, OUTPUT);
pinMode(red3, OUTPUT);
pinMode(wig4, OUTPUT);
pinMode(wig5, OUTPUT);
// 1st set of alternating strobe (2 flash per LED) LEDs
digitalWrite(red2, HIGH); // turn the red light on
delay(ledDelay); // wait 50 ms
digitalWrite(red2, LOW); // turn the red light off
delay(75); // midpoint by 75ms
digitalWrite(red3, HIGH); // turn the blue light on
digitalWrite(red3, LOW); // turn the blue light off
void loop2()
// 2nd second set of alternating (one flash each) LEDs
digitalWrite(wig4, LOW);
delay(onTime1);
digitalWrite(wig5, HIGH);
delay(offTime1);
Welcome to the forum
Use [color = red]code tags[/color] (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
See Using millis() for timing. A beginners guide, Several things at the same time and the BlinkWithoutDelay example in the IDE
Thank you Bob. I will be sure to use the code tags next time. I did read some about millis already but I was hoping for something even simpler. I will check out BlinkWithoutDelay and the guide again as well. Thanks again.
Please edit your original post and add the code tags. It really does make it easier to see and copy your code
Hello, @misterbee1.
This is your sketch in a simulation:
I like to point to YouTube/ProgrammingElectronicsAcademy for learning Arduino programming. Here is the first video of their multi-part series on millis() (mentioned above)... (about 15 minutes per video)
Thank you. Studying it all now...
Ok, I hate to sound ignorant, but this non millis coding shows the exact two programs I want running at the same time, but of course can't do without the help of millis. 1st program is two LEDs flashing two times each while alternating and 2nd program is two LEDs flashing once each alternately. Need it running at the same time with millis:
int ledDelay = 70;
int red2 = 2;
int red3 = 3;
int wig4 = 4;
int wig5 = 5;
void loop1() {
void loop2()
  digitalWrite(wig4, HIGH);
  delay(50);
  digitalWrite(wig5, LOW);
  delay(250);
  delay(50);
  delay(250);
void loop() { // call other functions from here to make a modular sketch
  loop1(); // was inside loop()... moved it to its own function
  loop2(); // was not called in original sketch
Look at how this example works and adjust it to do what you need
struct ledData
    byte pin;
    unsigned long period;
    unsigned long lastChange;
const byte NUM_LEDS = 2;
ledData leds[NUM_LEDS];
    leds[0] = { 3, 200, 0 };    //pin, period, last change time
    leds[1] = { 5, 1500, 0 };
    for (int led = 0; led < NUM_LEDS; led++)
        pinMode(leds[led].pin, OUTPUT);
    unsigned long currentTime = millis();
        if (currentTime - leds[led].lastChange >= leds[led].period)
            digitalWrite(leds[led].pin, !digitalRead(leds[led].pin));
            leds[led].lastChange = currentTime;
Thank you Bob. Others reading my thread please feel free to respond with the exact coding I need for this to work - so that I can see it correctly and understand it finally.
Better still, run the sketch using your pin numbers then adjust the parameters in the leds array until you understand what they do and set them accordingly to do what you want
At the risk of doing your homework for you...
Thanks, but all that does is blink pin 13 constantly. I feel like you guys are my grandfather from when I was 13 just throwing math books at me and saying figure it out. Some people, like myself, learn differently and need to see the final product and work backward.
Have you tried the code in post #9 with your pin numbers substituted for mine ?
I am actually working on it right now with that code. I added two more LEDs and this is what I have currently:
struct ledData
    byte pin;
const byte NUM_LEDS = 4;
    leds[0] = { 3, 200, 00 };    //pin, period, last change time
    leds[1] = { 5, 200, 75 };
    leds[2] = { 11, 75, 00 };    //pin, period, last change time
    leds[3] = { 12, 75, 75 };
Pins 3 and 5 are alternating perfectly. I have pins 11 and 12 alternating fast. Just need them to double blink while doing that...
A slightly different approach
const byte ledPins[] = {3,5,6,9};
const byte NUMBER_OF_LEDS = sizeof(ledPins);
unsigned long startTimes[NUMBER_OF_LEDS] = {};
byte indexes[NUMBER_OF_LEDS] = {0};
const byte MAX_NUMBER_OF_PERIODS = 10;
long periods[][MAX_NUMBER_OF_PERIODS] =    //on/off periods for each LED.  -1 indicates end of sequence
  {1000, 2000, 1500, 2500, -1},  //on/off/on/off/start again
  {500, 200, 1000, 2000, 3000, 4000, -1},  //on/off/on/off/on/off/start again
  {400, 1000, 1500, 2000, -1}, //on/off/on/off/start again
  {500, 500, -1} //on/off/start again
  for (int led = 0; led < NUMBER_OF_LEDS; led++)
    pinMode(ledPins[led], OUTPUT);
  for (int led = 0; led < NUMBER_OF_LEDS; led++)  //iterate through the LEDs
    if (currentTime - startTimes[led] >= periods[led][indexes[led]])  //? time to change ?
      digitalWrite(ledPins[led], !digitalRead(ledPins[led]));  //flip led state
      startTimes[led] = currentTime;  //save start time of state
      indexes[led]++;                    //increment index
    if (periods[led][indexes[led]] == -1)  //if next period is zero (end of sequence)
      indexes[led] = 0;        //reset period index for this LED
  }  //end for loop
Here is what the code does that you posted in post #16:
I can't figure out how to adjust those times to have 3 and 5 alternate with a single flash each and to have 6 and 9 alternate with a double flash each...
I wouldn`t recommend driving LEDs without current limiting resistors, especially from GIOs, you can damage the mcu.
Probably should have resistors, but they are flashing so it's not as bad as you think for MCU. I also am in a room that is 32°F, so that helps.
Each line in the periods array holds the timing for a single LED. Each entry in a line determines the on/off pattern timing for that LED
For a double flash just add more on/off periods to a line
      { 0, 1000, 1000, -1 },                      //on/off/on/start again
      { 1000, 1000, 0, -1 },                      //on/off/on/start again
      { 0, 1000, 100, 100, 100, 100, 1000, -1 },  //double flash
      { 1000, 100, 100, 100, 100, 1000, 0, -1 }   //double flash
NOTE the use of zero timing periods to force alternating between LED pairs
It would help if you posted a timing diagram, one row per LED, showing what on/off periods you want for each
