Trying to create directory and file on the arduino Card Info can be retrieved it can list down the existing files it says the file has been created but if i try to check the sd card on computer, no file is found. Though it lists down the recently created file in the same session. But restarting the board willnt display the recently created file.
here is the code
SD card basic file example
This example shows how to create and destroy an SD card file
The circuit:
* SD card attached to SPI bus as follows:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4
created Nov 2010
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
File myFile;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
if (SD.exists("example.txt")) {
Serial.println("example.txt exists.");
if(SD.mkdir("/Arduino")){
Serial.println("Directory with name Arduino has been created");
Serial.println("couldnt create the directoy...");
Serial.println("example.txt doesn't exist.");
// open a new file and immediately close it:
Serial.println("Creating example.txt...");
myFile = SD.open("example.txt", FILE_WRITE);
myFile.close();
// Check to see if the file exists:
// delete the file:
// Serial.println("Removing example.txt...");
// SD.remove("example.txt");
// nothing happens after setup finishes.
