SD card on ESP32S3
I have a 3.5” TFT with an 8 bit parallel bus (WC32-SC01 Plus). The processor is an ESP32S3.
The screen is supper fast. The board is also equipped with an SD card holder.
I can't get the SD procedure to work because the SPI pins are imposed differently than with the standard ESP32.
How can I reconfigure the SD.h so that it works with the pin assignment below
The SPI bus :
MISO GPIO_NUM_38
MOSI GPIO_NUM_40
SD_SCLK GPIO_NUM_39
SD_CS GPIO_NUM_41
This is how I configure SPI for a LoRa device to use arbitary pins on a ESP32CAM
#define NSS 12                //select on LoRa device
#define NRESET 15             //reset pin on LoRa device
#define SCK 4                 //SCK on SPI3
#define MISO 13               //MISO on SPI3
#define MOSI 2                //MOSI on SPI3
SPI.begin(SCK, MISO, MOSI, NSS);
Maybe it works on the C3 ?
SPI.begin(39, 38, 40, -1);
if(!SD.begin(41)){
  Serial.println("SD Mount Failed");
Thanks for this help. It is now working. You are my live saver!
Cheers
