Hi again.
What I am expecting: Reading a txt file on SD Card that contains URL's for Internet radio that can be used in a program.
The Issue: Reading in data from a text file to an array ( const char*URL PROGMEM ={"","",""} as a global array ) Array works, printing out the text file to Serial Monitor also works within the While(file.available) loop, the trouble comes when accessing the URL[Current_URL] data previously stored in this URL, the data is gone
```cpp
#include "SD.h"
#include "FS.h"
#include <SPI.h>
#define HSPI_SS 5
// SD Card
#define TFT_SD_CS 5
#define TFT_SD_SCK 18
#define TFT_SD_MISO 19
#define TFT_SD_MOSI 23
int Current_URL = 0;
int Max_Current_URL = 5; // Number of URL's in array - 1
bool SD_State_Status = false;
const char *URL[] PROGMEM = {"","","","","","","","","",""};
SPIClass *hspi = NULL;
File root;
File file;
/* * Function Name:- SD_Init() * */
/* * Description:- Creates a new SPI Class for use with the built in * */
/* * SD Card reader/writer tests what card it is and initialises the card * */
/* * for use with this program * */
void SD_Init() {
hspi = new SPIClass(HSPI);
hspi->begin(TFT_SD_SCK, TFT_SD_MISO, TFT_SD_MOSI, TFT_SD_CS);
if (!SD.begin(TFT_SD_CS, *hspi)) {
Serial.printf("Card Mount Failed\n");
return;
Serial.printf("Card mounted successfully....\n");
uint8_t cardType = SD.cardType();
if (cardType == CARD_NONE) {
Serial.println("No SD card attached");
return;
Serial.printf("SD Card Type: ");
if (cardType == CARD_MMC) {
Serial.printf("MMC\n\n");
} else if (cardType == CARD_SD) {
Serial.printf("SDSC\n\n");
} else if (cardType == CARD_SDHC) {
Serial.printf("SDHC\n\n");
Serial.printf("UNKNOWN\n\n");
uint64_t cardSize = SD.cardSize() / (1024 * 1024);
Serial.printf("SD Card Size: %lluGB\n\n", cardSize / 1000);
SD_State_Status = true;
delay(4000);
return;`
/* * Reads back the URLs from Station_List.cfg and stores them in an Array * */
/* * called URL[] each line of text is a URL and is stored * */
void Read_Config_File_Station_List() {
long Seek_Pos = 0;
char *URL_Tmp[200] = {""};
Max_Current_URL = 0;
file = SD.open("/Station_List.cfg", FILE_READ);
if (!file) Serial.println("Unable to open file");
do {
} while (!file);
Serial.println("File Opened");
String temp_Str;
while (file.available() > 0) {
file.seek(Seek_Pos);
delay(100);
temp_Str = file.readStringUntil('\r');
delay(100);
temp_Str.trim();
URL[Current_URL] = temp_Str.c_str();
delay(100);
Serial.printf("URL[%d]:- %s | This Station Position Within File:- %d\n", Current_URL, URL[Current_URL], Seek_Pos);
Seek_Pos += temp_Str.length() + 2, Max_Current_URL ++, Current_URL ++;
file.flush();
Max_Current_URL --;
int Station_Count = Max_Current_URL;
Serial.println("File Closed");
Serial.printf("Max_Current_URL:- %d | Station_Count:- %d\n", Max_Current_URL, Station_Count);
for ( int c = 0 ; c <= Station_Count ; c ++ ) {
Serial.printf("URL[%d]:- %s\n", c, URL[c]);
file.close();
/* *Creates a list on SD called Station_List.cfg and fills this file with */
/* *Internet Radio URLs * */
void Create_Station_Config_File() {
root = SD.open("/");
file = SD.open("/Station_List.cfg", FILE_WRITE);
do {
} while (!file);
for ( int c = 0; c <= Max_Current_URL; c ++) {
file.println(URL[c]);
file.flush();
file.close();
int Station_Count = 0;
SD_Init();
// Create_Station_Config_File(); // Creates a config file for this program
Read_Config_File_Station_List(); // Opens and extracts Station URL's for use in this program.
The output from this code snippet is the following:-
SD Card Size: 1GB
Unable to open file
File Opened
URL[0]:- http://edge-bauerall-01-gos2.sharp-stream.com/absoluteradio.mp3?aw_0_1st.skey=1748828163&aw_0_1st.playerid=BMUK_RPi
URL[1]:- http://edge-bauerall-01-gos2.sharp-stream.com/absoluteclassicrockhigh.aac?aw_0_1st.skey=1748993576&aw_0_1st.playerid=BMUK_RPi
URL[2]:- http://edge-bauerall-01-gos2.sharp-stream.com/net2southwales.mp3?aw_0_1st.skey=1748828453
URL[3]:- http://edge-bauerall-01-gos2.sharp-stream.com/magicnational.mp3?aw_0_1st.skey=1748828719
URL[4]:- http://listen-nation.sharp-stream.com/nationwest.mp3?ref=RF | This Station Position Within File:- 425
16:15:55.478 -> URL[5]:- | This Station Position Within File:- 486
16:15:55.478 -> File Closed
16:15:55.478 -> Max_Current_URL:- 5 | Station_Count:- 5
16:15:55.478 -> URL[0]:-
16:15:55.478 -> URL[1]:-
16:15:55.478 -> URL[2]:-
16:15:55.478 -> URL[3]:-
16:15:55.478 -> URL[4]:-
16:15:55.519 -> URL[0]:-
The first 5 URL's Above (Following the File Opened Statement) is the initial point at which the data is retrieved, as you can see this works as expected, the 2nd block of Data following the File Closed statement is the for loop at the foot of the Read_Config_File_Station_List() function. The function Create_Station_Config_File() creates the config file (obviously), the Station_List.cfg file contains the listed URLs, one to a line with a \r and \n following them.
Does anyone know why this data is being lost? or have a solution to remedy it, I have also tried padding the Array with '0' ( character 0) up to the size of the Array elements (URL[10][200])
Thanks in advance an apologies if I've messed up the post formatting.
