SD card? retrive needed
Hi
I accedentaly deleted some SD card files. Is there any "software'in the sd library to retrive? Thank you.
No, but you may be able to find software online to undelete the files using a PC as long as you have not written anything to the card since deleting them
They SHOULD be DOS Fat 8.3 formatted. Any DOS "undelete" utility should help. YMMV
From the command prompt:
UNDELETE [d:][path][filename] [/DT|/DS|/DOS]
but the files are from a gopro.
I have a gopro. the sd card reads on a PC. Try undelete, what do you have to lose?
