Sd card still overwrite the data
I was checking this code, and trying some others, and the one thing i can`t do is like, if you find this file continue writing on it, i have tried with other commands, and still keep deleting (overwriting) what a I had.
I have made, that in one sesion writes like a countdown like 1, 2, 3, 4, but if I turn off and turn on, it deletes and write again all the data.
 *  SD Card Access
 * platformio.ini
 [env:esp wrover kit]
platform = espressif32
framework = arduino
board = esp-wrover-kit
monitor_speed = 115200
build_flags = -D LED_BUILTIN=21  -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue
#include <SPI.h>
#include <SD.h>
#include <Arduino.h>
#define SD_CS         13
#define SPI_MOSI      15
#define SPI_MISO      2
#define SPI_SCK       14
File root;
void printDirectory(File dir, int numTabs);
long previousblinkTime = 0;
int ledState = LOW;
  // Begin
  dir.rewindDirectory();
  while(true)
     File entry =  dir.openNextFile();
     if (! entry)
       // no more files
     for (uint8_t i=0; i<numTabs; i++)
       Serial.print('\t');   // we'll have indentation
     Serial.print(entry.name());
     // Recurse for directories, otherwise print the file size
     if (entry.isDirectory())
       Serial.println("/");
       printDirectory(entry, numTabs+1);
       // files have sizes, directories do not
       Serial.print("\t\t");
       Serial.println(entry.size(), DEC);
     entry.close();
  pinMode(12, OUTPUT);
  SPI.begin(SPI_SCK, SPI_MISO, SPI_MOSI, SD_CS);
  Serial.println("starting");
  if(!SD.begin(SD_CS, SPI))
      Serial.println("Card Mount Failed");
      return;
  uint8_t cardType = SD.cardType();
  if(cardType == CARD_NONE)
      Serial.println("No SD card attached");
      return;
  //card details
  uint64_t cardSize = SD.cardSize() / (1024 * 1024);
  Serial.printf("SD Card Size: %lluMB\n", cardSize);
  Serial.println("-----");
  //list files
  root = SD.open("/");
  if (root)
    printDirectory(root, 0);
    root.close();
    Serial.println("error opening root");
  //File write
  root = SD.open("/test.txt", FILE_WRITE);
  if (root)
    root.println("Hello worl4!");
    root.flush();
    root.close();
    Serial.println("error opening test.txt");
  //File Read
  root = SD.open("/test.txt");
  if (root)
    while (root.available())
      Serial.write(root.read());
    root.close();
  Serial.println("done!");
  // Blink task - 1000ms task
  unsigned long CurrentblinkTime = millis();
  if(CurrentblinkTime - previousblinkTime > 1000)
    previousblinkTime = CurrentblinkTime;
    if (ledState == LOW)
      ledState = HIGH;
      ledState = LOW;
    digitalWrite(12, ledState);
have you tried file.append() ?
A handy table for fopen at cppreference; an excerpt
Meaning Explanation Action if file
already exists
Action if file
does not exist
read Open a file for reading read from start return NULL and set error
write Create a file for writing destroy contents create new
append Append to a file write to end create new
So instead of FILE_WRITE, try FILE_APPEND
Thank you i didnt know about that!!
Thanks I will try it! <3
