Im using a ESP32 30P and I want to write MPU6050 data to a SD card. I have confirmed all of it works but I'm stumped on how to continuously write numbers.
float version = 1.00;
//Imports
#include <SPI.h>
#include <SD.h>
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
//Constants
#define BUTTON_PIN 26
#define PIN_SPI_CS 5
float Seconds = 0;
//SDCARD
File myFile;
//MPUG6050
Adafruit_MPU6050 mpu;
boolean Normal = true;
delay(2000);
Serial.println("SD card test...");
delay(10);
pinMode(BUTTON_PIN, INPUT_PULLUP);
if (!SD.begin(PIN_SPI_CS)) {
while (1) {
Serial.println("SD CARD FAILED, OR NOT PRESENT!");
Normal = false;
SD.remove("/Flight.txt");
Serial.println("SD CARD INITIALIZED.");
if (!SD.exists("/Flight.txt")) {
Serial.println("Flight.txt doesn't exist");
delay(1);
Serial.println("Flight.txt created....");
// create a new file by opening a new file and immediately close it
myFile = SD.open("/Flight.txt", FILE_WRITE);
myFile.close();
Normal = false;
Serial.println("Flight.txt doesn't exist on SD Card.");
Serial.println("Flight.txt exists on SD Card.");
delay(10);
Serial.println("Sd card Complete! Starting..");
Serial.println("Adafruit MPU6050 test!");
delay(10);
if (!mpu.begin()) {
Serial.println("Failed to find MPU6050 chip");
while (1) {
delay(10);
Serial.println("MPU6050 Found!");
mpu.setAccelerometerRange(MPU6050_RANGE_8_G);
Serial.print("Accelerometer range set to: ");
switch (mpu.getAccelerometerRange()) {
case MPU6050_RANGE_2_G:
Serial.println("+-2G");
case MPU6050_RANGE_4_G:
Serial.println("+-4G");
case MPU6050_RANGE_8_G:
Serial.println("+-8G");
case MPU6050_RANGE_16_G:
Serial.println("+-16G");
mpu.setGyroRange(MPU6050_RANGE_500_DEG);
Serial.print("Gyro range set to: ");
switch (mpu.getGyroRange()) {
case MPU6050_RANGE_250_DEG:
Serial.println("+- 250 deg/s");
case MPU6050_RANGE_500_DEG:
Serial.println("+- 500 deg/s");
case MPU6050_RANGE_1000_DEG:
Serial.println("+- 1000 deg/s");
case MPU6050_RANGE_2000_DEG:
Serial.println("+- 2000 deg/s");
mpu.setFilterBandwidth(MPU6050_BAND_5_HZ);
Serial.print("Filter bandwidth set to: ");
switch (mpu.getFilterBandwidth()) {
case MPU6050_BAND_260_HZ:
Serial.println("260 Hz");
case MPU6050_BAND_184_HZ:
Serial.println("184 Hz");
case MPU6050_BAND_94_HZ:
Serial.println("94 Hz");
case MPU6050_BAND_44_HZ:
Serial.println("44 Hz");
case MPU6050_BAND_21_HZ:
Serial.println("21 Hz");
case MPU6050_BAND_10_HZ:
Serial.println("10 Hz");
case MPU6050_BAND_5_HZ:
Serial.println("5 Hz");
if (Normal) {
Serial.println("All Systems Nomnial....");
Serial.println("All Systems NOT!!!!! Nomnial....");
delay(100);
if (myFile) {
myFile.println("Flight Controller and Data Collector aboard Pathway.");
myFile.println("Today Is..");
myFile.println("June 11 2024");
myFile.println("Data below will be rockets Velocity,Speed,Accelaration,and X and Y roll. All recorded by onboard MPU-6050");
myFile.println("Also data will include BPM180 Height.");
myFile.println("If you found this rocket and would like to return it please contact me here.");
myFile.println("Onboard GPS transmitter has started");
myFile.println("Marking Time for Launch...");
myFile.println(" How To Read data....");
myFile.println("Acceleration:");
myFile.println("Rotation X:");
myFile.println("Rotation Y:");
myFile.println("Rotation Z:");
myFile.println("Temperature:");
myFile.close();
Serial.print("TITLE SUCCSES");
Serial.print(F("SD Card: Issue encountered while attempting to open the file Flight.txt"));
myFile = SD.open("/Flight.txt", FILE_READ);
if (myFile) {
while (myFile.available()) {
char ch = myFile.read(); // read characters one by one from Micro SD Card
Serial.print(ch); // print the character to Serial Monitor
myFile.close();
sensors_event_t a, g, temp;
mpu.getEvent(&a, &g, &temp);
float TempF = 0;
float TempC = temp.temperature;
TempF = (TempC*1.8)+32;
savePosition();
int buttonState = digitalRead(BUTTON_PIN);
void savePosition() {
float TempF = 0;
myFile.println(a.acceleration.z);
myFile.println(g.gyro.x);
myFile.println(g.gyro.y);
myFile.println(g.gyro.z);
myFile.print(TempF);
myFile.close();
Now I expect the Sd card to have written the Data and Title heading i gave it. Instead it just looks like this:
9.24
-0.78
-0.44
0.85
79.08
which is good! but there is nothing else.... What am i doing wrong?
