Hi. I've been trying to get 8 Adafruit RGB Sensors (TCS34725) to simultaneously log data to an SD card using an Adafruit multiplexer (TCA9548A) and an Arduino mini pearl data logger. When one sensor is directly connected to the data logger, I can get data written to the SD card a couple times a second. However, when I try to use a multiplexer and multiple sensors, with code modified to try and allow this, no data is written at all. When directly connected to a computer and sensor outputs are printed to serial monitor, the data is displayed with no issues. It's just when writing to the SD card that the issue occurs.
The wiring for the mini pearl data logger is exactly as in this schematic; the VCC, GND, SDA, and SCL pins for the real time clock are connected to the multiplexer. The 8 RGB sensors' 3V3 and GND pins are also connected to the VCC and GND pins of the multiplexer, and the sensors' SDA and SCL pins are wired to the corresponding pins on the multiplexer.
I am a relative novice to Arduino programming and so I modified the example code that is provided for the mini pearl data logger to try to function with the multiplexer. I believe this is where the error is coming from. This modified code is pasted below.
#include <SPI.h>
#include <Wire.h>
#include <SdFat.h> // https://github.com/greiman/SdFat/
#include <RTClib.h> // https://github.com/adafruit/RTClib/
#include "Adafruit_TCS34725.h"
RTC_DS3231 RTC; // RTC will be the RTC_DS3231 object
#define DS3231_I2C_ADDRESS 0x68 // RTC address
#define donePin A3 // This pin signals to the TPL51100 to cut power
#define TCAADDR 0x70 //multiplexer
Adafruit_TCS34725 tcs1 = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_614MS, TCS34725_GAIN_1X);
Adafruit_TCS34725 tcs2 = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_614MS, TCS34725_GAIN_1X);
Adafruit_TCS34725 tcs3 = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_614MS, TCS34725_GAIN_1X);
Adafruit_TCS34725 tcs4 = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_614MS, TCS34725_GAIN_1X);
Adafruit_TCS34725 tcs5 = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_614MS, TCS34725_GAIN_1X);
Adafruit_TCS34725 tcs6 = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_614MS, TCS34725_GAIN_1X);
Adafruit_TCS34725 tcs7 = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_614MS, TCS34725_GAIN_1X);
Adafruit_TCS34725 tcs8 = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_614MS, TCS34725_GAIN_1X);
SdFat SD; // SD will be the SdFat object
#define MOSIpin 11 // for SD card
#define MISOpin 12 // for SD card
char TmeStrng[] = "0000/00/00,00:00:00"; // string template for RTC time stamp
// variables for the RTC:
float rtcTemp;
float rtcTempC;
byte tMSB = 0;
byte tLSB = 0;
// Helper function for changing TCA output channel
void tcaselect(uint8_t channel) {
if (channel > 7) return;
Wire.beginTransmission(TCAADDR);
Wire.write(1 << channel);
Wire.endTransmission();
pinMode(donePin, OUTPUT); // This pin sends output to the TPL5110 timer to cut power
digitalWrite(donePin, LOW); // LOW until its time to cut power
Serial.begin(9600); // Open serial communications
Wire.begin(); // initialize the I2C interface
RTC.begin(); // initialize the RTC
if (!SD.begin(10)) { // initialize the SD card
Serial.println("No SD card");
return;
Serial.println("SD OK");
Set the RTC time to the time this sketch was last compiled. Uncomment the following line.
Load the sketch onto the logger (using the Arduino IDE which compiles the sketch).
Must then immediately comment out the line and reload or the RTC time will be wrong:
//RTC.adjust(DateTime((__DATE__), (__TIME__)));
//initialize sensor 1
tcaselect(0); // TCA channel for bme1
if (tcs1.begin(0x29)) // address = 0x29
Serial.println("Found sensor 1");
Serial.println("No TCS34725 1 found ... check your connections");
while (1);
//initialize sensor 2 ... and so on
tcaselect(1); // TCA channel for bme2
if (tcs2.begin(0x29)) // address = 0x29
Serial.println("Found sensor 2");
Serial.println("No TCS34725 2 found ... check your connections");
while (1);
tcaselect(2);
if (tcs3.begin(0x29)) // address = 0x29
Serial.println("Found sensor 3");
Serial.println("No TCS34725 3 found ... check your connections");
while (1);
tcaselect(3);
if (tcs4.begin(0x29)) // address = 0x29
Serial.println("Found sensor 4");
Serial.println("No TCS34725 4 found ... check your connections");
while (1);
tcaselect(4);
if (tcs5.begin(0x29)) // address = 0x29
Serial.println("Found sensor 5");
Serial.println("No TCS34725 5 found ... check your connections");
while (1);
tcaselect(5);
if (tcs6.begin(0x29)) // address = 0x29
Serial.println("Found sensor 6");
Serial.println("No TCS34725 6 found ... check your connections");
while (1);
tcaselect(6);
if (tcs7.begin(0x29)) // address = 0x29
Serial.println("Found sensor 7");
Serial.println("No TCS34725 7 found ... check your connections");
while (1);
tcaselect(7);
if (tcs8.begin(0x29)) // address = 0x29
Serial.println("Found sensor 8");
Serial.println("No TCS34725 8 found ... check your connections");
while (1);
delay(50); //
} // end of setup
uint16_t r1, g1, b1, c1, r2, g2, b2, c2, r3, g3, b3, c3, r4, g4, b4, c4, r5, g5, b5, c5, r6, g6, b6, c6, r7, g7, b7, c7, r8, g8, b8, c8;
DateTime now = RTC.now(); // read the time from the RTC, then construct a data string:
sprintf(TmeStrng, "%04d/%02d/%02d,%02d:%02d:%02d", now.year(), now.month(), now.day(), now.hour(), now.minute(), now.second());
// write the data to the SD card:
File dataFile = SD.open("datalogTPL.txt", FILE_WRITE);
dataFile.print(TmeStrng);dataFile.print(",");
tcaselect(0);
tcs1.getRawData(&r1, &g1, &b1, &c1);
dataFile.print(r1);dataFile.print(","); //sensor 1
dataFile.print(g1);dataFile.print(",");
dataFile.print(b1);dataFile.print(",");
dataFile.print(c1);dataFile.print(",");
tcaselect(1);
tcs2.getRawData(&r2, &g2, &b2, &c2);
dataFile.print(r2);dataFile.print(","); //sensor 2
dataFile.print(g2);dataFile.print(",");
dataFile.print(b2);dataFile.print(",");
dataFile.print(c2);dataFile.print(",");
tcaselect(2);
tcs3.getRawData(&r3, &g3, &b3, &c3);
dataFile.print(r3);dataFile.print(","); //sensor 3
dataFile.print(g3);dataFile.print(",");
dataFile.print(b3);dataFile.print(",");
dataFile.print(c3);dataFile.print(",");
tcaselect(3);
tcs4.getRawData(&r4, &g4, &b4, &c4);
dataFile.print(r4);dataFile.print(","); //sensor 4
dataFile.print(g4);dataFile.print(",");
dataFile.print(b4);dataFile.print(",");
dataFile.print(c4);dataFile.print(",");
tcaselect(4);
tcs5.getRawData(&r5, &g5, &b5, &c5);
dataFile.print(r5);dataFile.print(","); //sensor 5
dataFile.print(g5);dataFile.print(",");
dataFile.print(b5);dataFile.print(",");
dataFile.print(c5);dataFile.print(",");
tcaselect(5);
tcs6.getRawData(&r6, &g6, &b6, &c6);
dataFile.print(r6);dataFile.print(","); //sensor 6
dataFile.print(g6);dataFile.print(",");
dataFile.print(b6);dataFile.print(",");
dataFile.print(c6);dataFile.print(",");
tcaselect(6);
tcs7.getRawData(&r7, &g7, &b7, &c7);
dataFile.print(r7);dataFile.print(","); //sensor 7
dataFile.print(g7);dataFile.print(",");
dataFile.print(b7);dataFile.print(",");
dataFile.print(c7);dataFile.print(",");
tcaselect(7);
tcs8.getRawData(&r8, &g8, &b8, &c8);
dataFile.print(r8);dataFile.print(","); //sensor 8
dataFile.print(g8);dataFile.print(",");
dataFile.print(b8);dataFile.print(",");
dataFile.print(c8);dataFile.print(",");
dataFile.println();
dataFile.flush(); // wait for serial data to complete transmission
dataFile.close();
delay(1);
while (1) // The toggling does not seem to be required, but...
{ // toggle donePin so TPL5110 will cut power and turn off logger
digitalWrite(donePin, HIGH);
delay(1);
delay(1);
} // end of the MAIN LOOP
