Hello,
I'm trying to write a program (UNO) that collects data from two different sensors and stores the data in an SD card (adafruit datalogging shield). I was able to get the two sensors to work separately and successfully ran for more than two days. However, when I modified the program to work with both sensors, the IDE issued a warning and the SD.open() kept failing. Though it did create a file.
Here is the warning when complied: "Sketch uses 27132 bytes (84%) of program storage space. Maximum is 32256 bytes.
Global variables use 1706 bytes (83%) of dynamic memory, leaving 342 bytes for local variables. Maximum is 2048 bytes.
Low memory available, stability problems may occur."
Any input on optimizing memory is also appreciated!
Thanks!!
#include<SoftwareSerial.h>
#include<SD.h>
#include<SPI.h>
#include "RTClib.h"
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BME680.h"
#define BME_SCK 7
#define BME_MISO 6
#define BME_MOSI 5
#define BME_CS 4
#define SEALEVELPRESSURE_HPA (1013.25)
RTC_Millis rtc;
SoftwareSerial dustSensorSerial(2, 3); //RX,TX
Sd2Card card;
SdVolume volume;
SdFile root;
const int chipSelect = 10;
char dataFileName[] = "one.txt";
bool dustSensorStatus = false;
byte dustSensorGetReading[] = {0x42, 0x4D, 0xE2, 0x00, 0x00, 0x01, 0x71};
Adafruit_BME680 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK); // hardware SPI
File myFile;
//Initialize dust sensor
dustSensorSerial.begin(9600);
byte dustSensorSwitchMode[] = {0x42, 0x4D, 0xE1, 0x00, 0x00, 0x01, 0x70};
dustSensorSerial.write(dustSensorSwitchMode, 7);
while (!dustSensorModeStatus(&dustSensorSerial)) {
//Serial.println(F("in dust loop"));
//delay(1000);
//initialize bme680 sensor
while (!bme.begin()) {
//Serial.println(F("Could not find a valid BME680 sensor, check wiring!"));
//delay(1000);
// Set up oversampling and filter initialization
bme.setTemperatureOversampling(BME680_OS_8X);
bme.setHumidityOversampling(BME680_OS_2X);
bme.setPressureOversampling(BME680_OS_4X);
bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
bme.setGasHeater(320, 150); // 320*C for 150 ms
//Initialize da timer
rtc.begin(DateTime(F(__DATE__), F(__TIME__)));
//initialize SD card
while (!initializeSD(chipSelect)) {
myFile = SD.open(dataFileName, FILE_WRITE);
if (myFile) {
DateTime now = rtc.now();
myFile.print(now.month(), DEC); myFile.print("-");
myFile.print(now.day(), DEC); myFile.print("-");
myFile.println(now.year(), DEC);
myFile.println("Time,dustDataPM10,dustDataPM25,dustDataPM100,Temperature,Pressure,Humidity,Gas,Altitude");
Serial.println(F("Initial Saving Success"));
while (!(myFile = SD.open(dataFileName, FILE_WRITE))) {
Serial.println(F("FileFailed"));
myFile.close();
struct dustSensorData {
uint16_t framelen;
uint16_t pm10_standard, pm25_standard, pm100_standard;
uint16_t pm10_env, pm25_env, pm100_env;
uint16_t particles_03um, particles_05um, particles_10um, particles_25um, particles_50um, particles_100um;
uint16_t unused;
uint16_t checksum;
struct dustSensorData dustData;
serialFlush(&dustSensorSerial);
if (myFile) {
//Serial.println("myFile True");
myFile.print(now.unixtime(), DEC); myFile.print(",");
dustSensorSerial.write(dustSensorGetReading, sizeof(dustSensorGetReading));
dustSensorStatus = readDustSensordata(&dustSensorSerial);
if (dustSensorStatus) {
myFile.print(dustData.pm10_standard); myFile.print(",");
myFile.print(dustData.pm25_standard); myFile.print(",");
myFile.print(dustData.pm100_standard); myFile.print(",");
Serial.println(F("in dust"));
else {
while (!dustSensorStatus) {
if (bme.performReading()) {
myFile.print(bme.temperature); myFile.print(",");
myFile.print(bme.pressure); myFile.print(",");
myFile.print(bme.humidity); myFile.print(",");
myFile.print(bme.gas_resistance / 1000); myFile.print(",");
myFile.println(bme.readAltitude(SEALEVELPRESSURE_HPA));
/* Serial.print("Temperature = ");
Serial.print(bme.temperature);
Serial.println(" *C");
Serial.print("Pressure = ");
Serial.print(bme.pressure / 100.0);
Serial.println(" hPa");
Serial.print("Humidity = ");
Serial.print(bme.humidity);
Serial.println(" %");
Serial.print("Gas = ");
Serial.print(bme.gas_resistance / 1000.0);
Serial.println(" KOhms");
Serial.print("Approx. Altitude = ");
Serial.print(bme.readAltitude(SEALEVELPRESSURE_HPA));
Serial.println(" m");*/
else {
Serial.println(F("BME 680 Failed"));
myFile.print("0,");
myFile.print("0,");
myFile.print("0,");
myFile.print("0,");
myFile.println("0");
myFile.close();
else {
Serial.println(F("myFile False"));
delay(60000);
// Dust Sensor Functions //
void serialFlush(Stream *s) {
while (s->available() > 0) {
char t = s->read();
boolean dustSensorModeStatus(Stream *s) {
if (! s->available()) {
return false;
// Read a byte at a time until we get to the special '0x42' start-byte
if (s->peek() != 0x42) {
s->read();
return false;
// Now read all 32 bytes
if (s->available() < 8) {
return false;
uint8_t buffer[8];
uint16_t sum = 0;
s->readBytes(buffer, 8);
// get checksum ready
for (uint8_t i = 0; i < 6; i++) {
sum += buffer[i];
uint16_t checksum = buffer[6] << 8 | buffer[7];
if (sum != checksum) {
Serial.println("Checksum failure");
return false;
// success!
return true;
boolean readDustSensordata(Stream *s) {
return false;
s->read();
return false;
if (s->available() < 32) {
return false;
uint8_t buffer[32];
uint16_t sum = 0;
s->readBytes(buffer, 32);
for (uint8_t i = 0; i < 30; i++) {
sum += buffer[i];
// The data comes in endian'd, this solves it so it works on all platforms
uint16_t buffer_u16[15];
for (uint8_t i = 0; i < 15; i++) {
buffer_u16[i] = buffer[2 + i * 2 + 1];
buffer_u16[i] += (buffer[2 + i * 2] << 8);
// put it into a nice struct :)
memcpy((void *)&dustData, (void *)buffer_u16, 30);
if (sum != dustData.checksum) {
return false;
// success!
return true;
// SD Card Functions //
bool initializeSD(int chipSelect) {
if (SD.begin(chipSelect)) {
Serial.println(F("SD Initialization Success"));
return true;
else {
Serial.println(F("SD Initialization Failed"));
return false;
