I’m trying to write a sketch which logs humidity over time and records it to an SD card. It works fine with a fixed file name but I want it to write each record to a different file. I’ve used this to generate a new file name each time as a char[] string.
dt = clock.getDateTime();
sprintf(name, "%4d%02d%02d%02d%02d.csv", dt.year, dt.month, dt.day, dt.hour, dt.minute);
Serial.println(name);
I then use
myFile = SD.open(name, FILE_WRITE);
to create the file.
When I run the sketch It doesn’t actually create the file and prints “error opening 202401121822.csv”
Is it a problem using a string to create a file name?
The full sketch is below.
#include <dht_nonblocking.h>
#define DHT_SENSOR_TYPE DHT_TYPE_11
#include <SD.h>
#include <Wire.h>
#include <DS3231.h>
DS3231 clock;
RTCDateTime dt;
static const int DHT_SENSOR_PIN = 2;
DHT_nonblocking dht_sensor(DHT_SENSOR_PIN, DHT_SENSOR_TYPE);
int humid;
char name[18];
File myFile;
* Initialize the serial port.
/*while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
for (int x = 0; x < 10; x++) {
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
while (1)
Serial.println("initialization done.");
Serial.println("Initialize DS3231");
// Initialize DS3231
clock.begin();
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, LOW);
* Poll for a measurement, keeping the state machine alive. Returns
* true if a measurement is available.
static bool measure_environment(float *temperature, float *humidity) {
static unsigned long measurement_timestamp = millis();
if (millis() - measurement_timestamp > 5000ul) {
if (dht_sensor.measure(temperature, humidity) == true) {
return (true);
return (false);
* Main program loop.
float temperature;
float humidity;
char data[10];
/* Measure temperature and humidity. If the functions returns
true, then a measurement is available. */
if (measure_environment(&temperature, &humidity) == true) {
if (humidity != humid) {
digitalWrite(LED_BUILTIN, HIGH);
Serial.print(dt.hour);
Serial.print(":");
Serial.print(dt.minute);
Serial.print(":");
Serial.print(dt.second);
Serial.print("\t");
Serial.print(" ");
Serial.print("T = ");
Serial.print(temperature, 1);
Serial.print(" deg. C, H = ");
Serial.print(humidity, 1);
Serial.println("%");
if (myFile) {
myFile.print(dt.year);
myFile.print(",");
myFile.print(dt.month);
myFile.print(",");
myFile.print(dt.day);
myFile.print(",");
myFile.print(",");
myFile.print(dt.hour);
myFile.print(",");
myFile.print(dt.minute);
myFile.print(",");
myFile.print(dt.second);
myFile.print(",");
myFile.print(",");
myFile.print(temperature);
myFile.print(",");
myFile.println(humidity);
// close the file:
myFile.close();
// if the file didn't open, print an error:
Serial.print("error opening "); Serial.println(name);
humid = humidity;
