//RS-485 Modbus Slave (Arduino UNO)
//Circuit OZOX
#include<ModbusRtu.h> //Library for using Modbus in Arduino
#include <Servo.h> //Library for using Servo Motor
#include <SD.h> //Library for using SD Card
#include <SPI.h> //Library for using SPI IO
#define led1 2 //Define as 2 led1
#define led2 5 //Define as 5 led2
#define led3 7 //Define as 7 led3
#define led4 8 //Define as 8 led4
#define but 3 //Define as 3 but as Button
#define CS_PIN 9 //Define as 9 CS pin for SPI
File myFile;
Servo servo; //Initilize servo object for class Servo
Modbus bus; //Define Object bus for class modbus
uint16_t modbus_array[10]; //Array initilized
const int chipSelect = 10;
int btnSta = 0;
int myFi[10];
String s = " ";
String myf[10];
pinMode(led1,OUTPUT); //Led1 set as OUTPUT
pinMode(led2,OUTPUT); //Led2 set as OUTPUT
pinMode(led3,OUTPUT); //Led2 set as OUTPUT
pinMode(led4,OUTPUT); //Led2 set as OUTPUT
pinMode(9, OUTPUT);
pinMode(3, INPUT);
SD.begin(CS_PIN);
myFile = SD.open("test.txt", FILE_READ);
if(myFile)
for(int i=0;i<10;i++)
myFi[i]=myFile.parseInt();
modbus_array[i] = myFi[i];
myFile.close();
else{
modbus_array[i] = 0x00;
Serial.print("File didnt open...");
delay(20);
servo.attach(6); //Servo PWM pin 6
bus = Modbus(1,1,4); //Modbus slave ID as 1 and 1 connected via RS-485 and 4 connected to DE & RE pin of RS-485 Module
bus.begin(9600); //Modbus slave baudrate at 9600
bus.poll(modbus_array,sizeof(modbus_array)/sizeof(modbus_array[0])); //Used to receive or write value from Master
if (modbus_array[0] == 0)
digitalWrite(led1,LOW);
digitalWrite(led1,HIGH);
if (modbus_array[1] == 0)
digitalWrite(led2,LOW);
digitalWrite(led2,HIGH);
if (modbus_array[2] == 0)
digitalWrite(led3,LOW);
digitalWrite(led3,HIGH);
if (modbus_array[3] == 0)
digitalWrite(led4,LOW);
digitalWrite(led4,HIGH);
int pwm = modbus_array[4];
servo.write(pwm);
btnSta = digitalRead(but);
if(btnSta==LOW)
SD.remove("test.txt");
delay(10);
write_(myFile);
//oku(myFile)); // Eğer dosyayı okumak isterseniz.
delay(250);
void write_(File ff)
String dd="";
ff = SD.open("test.txt", FILE_WRITE);
if(ff)
myFi[i] = (int)modbus_array[i];
dd += myFi[i] + s;
ff.print(dd);
ff.close();
Serial.print("Yazılan değerler: " + dd);
Serial.print("File didnt open..");
delay(20);
void read_(File ff)
String gg="";
ff = SD.open("test.txt", FILE_READ);
if(ff)
myFi[i] = ff.parseInt();
gg += myFi[i] + s;
ff.close();
Serial.print("Okunan değerler: " + gg);
delay(20);
So… what’s the problem ?
What doesn’t your program do ?
Where’s the power coming from ?
