After a bluetooth connection between my smartphone and the bluetooth module, my arduino board sends some states as a string:
+BTSTATE:3 CONNECT:OK +BTSTATE:4
Can you please tell me, where the strings are defined in the code? I’d like to delete them.
void setupBlueToothConnection()
blueToothSerial.begin(38400); // Set BluetoothBee BaudRate to default baud rate 38400
blueToothSerial.print("\r\n+STWMOD=0\r\n"); // set the bluetooth work in slave mode
blueToothSerial.print("\r\n+STNA=SeeedBTSlave\r\n"); // set the bluetooth name as "SeeedBTSlave"
blueToothSerial.print("\r\n+STOAUT=1\r\n"); // Permit Paired device to connect me
blueToothSerial.print("\r\n+STAUTO=0\r\n"); // Auto-connection should be forbidden here
_delay_ms(2000);
// This delay is required.
blueToothSerial.print("\r\n+INQ=1\r\n"); // make the slave bluetooth inquirable
//Serial.println("The slave bluetooth is inquirable!");
_delay_ms(2000); // This delay is required.
blueToothSerial.flush();
→ maybe in the setupBlueToothConnection()? I tried to delete the bluetoothserial.print()-s -unfortunately the strings are still sent.
I contacted Seedstudio and they replied: "These outputs will be automatically printed indicating the status of connection, and it is driven by the firmware of the BT module. I guess the solution is to change its firmware but we cannot provide. Thanks! "
Very interesting, and I don't think it's much of an answer. That junk is your code in your mysterious programme and, even if it is output by firmware, I don't see why you are obliged to print it. I don't know why this is a problem anyway but, if you use a plain-vanilla $5 HC-05 bluetooth device, it's certainly a problem you will not have.
However, looking down that avenue does bring a problem of its own - what does the Seedstudio device offer that the HC-05 doesn't? This is perhaps a very short-lived problem.
The module Seeedstudio implemented in the shield is the “SLD63030P”. I got that shield from my lecturer for my project. That’s the reason I use this one.
So, any ideas how I can delete the states? Any experiences?
It doesn't seem a very good reason if it is causing you this grief. "SLD63030P" seems to be no more than a catalogue number. Since your problem is unique, and you make no attempt to clarify the situation, I'm afraid the best I can suggest is to read replies #3, #5 again.
