Hi !
I just cant write or print at a choosen place in a SD file.
seek() change position() and read() access but write() and print() stay at end of file.
Is it a way to access elsewhere ?
Thanks
Hi !
Thanks
Post the code that exhibits this behavior.
#include <SPI.h>
#include <SD.h>
#define FNAME "toto"
#define FSIZE 128
File myFile;
#define SOMEWHERE 16
#define SOMETHING "something"
#define ANOTHERTHING "anotherthing"
Serial.begin(115200);delay(100);
Serial.println("start\n");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
/* create file and fill 256 bytes */
SD.remove(FNAME);
myFile=SD.open(FNAME,FILE_WRITE);
if(!myFile){Serial.print(" OPEN WRITE KO");}
byte c=0x01;
for(int i=0;i<FSIZE;i++){myFile.write(c);}
myFile.close();
/* verify it */
byte a[FSIZE*2];memset(a,0x32,FSIZE); /* fill field with 0x32 to verify that 0x01 is written */
Serial.println("data in the field");dumpStr(a,FSIZE);
myFile=SD.open(FNAME,FILE_READ);
if(!myFile){Serial.print(" OPEN READ KO");}
for(int i=0;i<FSIZE;i++){a[i]=myFile.read();}
myFile.close();
Serial.println("data read");
dumpStr(a,FSIZE);
/* try to write somewhere */
myFile.seek(0);
Serial.print(" position=");Serial.print(myFile.position());
myFile.seek(SOMEWHERE);
Serial.print(" ; position after seek=");Serial.print(myFile.position());
Serial.print(" ; write ");Serial.print(strlen(SOMETHING));Serial.print(" char");
myFile.write(SOMETHING);
Serial.print(" ; position after write=");Serial.print(myFile.position());
myFile.close();
Serial.println("\n");
/* verify it */
memset(a,0xff,FSIZE);
for(int i=0;i<FSIZE*2;i++){a[i]=myFile.read();}
myFile.close();
Serial.println("modified data read");dumpStr(a,FSIZE*2);
/* try to print somewhere */
myFile.seek(0);
Serial.print(" ; print ");Serial.print(strlen(SOMETHING));Serial.print(" char");
myFile.write(ANOTHERTHING);
Serial.print(" ; position after print=");Serial.print(myFile.position());
myFile.close();
/* verify it */
myFile.close();
while(1){}
void dumpStr(byte* a,int len)
for(int i=0;i<len/16;i++){
Serial.print(i*16);Serial.print(" ");
if(i==0){Serial.print(" ");}
if((i*16)<100){Serial.print(" ");}
for(int j=0;j<16;j++){
if(a[i*16+j]<16){Serial.print("0");}
Serial.print(a[i*16+j],HEX);
Serial.print(" ");
Serial.print(" ");
byte b=a[i*16+j];
if(b<0x20 || b>0x7e){Serial.print(".");}
else Serial.print((char)b);
