Can someone please advise how to enrol an expert on this forum who can provide advice on designing my circuit board? I already have a working model for my robot but I would like someone with expertise to advise what improvements (i.e. component recommendations) can be made and help me to design a circuit board that can be printed.
A) post your circuit boards here, the one that is working and your attempts to design the new one, let the professionals and non professionals give you advice on the specific questions you have; or
What exactly do you have in mind when you refer to a circuit board that can be printed? Just because something is called a printed circuit board does not mean it is printed in today's world.
This is the first (old) drawing I done, however I have since removed all the TXS0108E and replaced them with 2 x CD74ACT541E for the logic level conversion. And I now only have 1 x CYT1076 (with the resistors removed).
A print circuit on a pcb with connectors and (ideally) the majority of the components printed on the board (instead of individual components). I would like to tidy things up and ensure that the circuit is stable.
Here is the reality. Components are soldered to the copper traces on your circuit board. Your part of the project is selecting the components, including the particular size of the components and the other parameters of each component.
You will most likely have to test and rework your design perhaps 5 or more times to get it the way you want.
I already have a working project (circuit board) therefore I have already selected the components, I want to simplify things i.e. instead of having an individual CNC shield motor driver - have the components (i.e. capacitors & TMC2209) on one main circuit board. And possibly choose a different micro controller as I am currently using an ESP32 (for it's speed & BLE) but if there is something better that I can use that has a lot more pins which would enable me to ditch the 4 x mcp23017 port expanders.
From what I can see from your 'schematic' you do not believe in bypass capacitors. You will need to determine which individual components you are going to use, most come in several different packages. Your breadboard will add a lot of capacitance that will not be on the printed circuit board.
Most similar "pro" circuits seem to stick with some apparently-standardized "modules" for the motor drivers. This enables you to switch drivers if your motor requirements change (voltage, current), and presumably allows easy repairs if a drive burns out.
A lot of the issues associated with your overall board layout are going to be related to what sort of connectors you want to use to connect your various motors and sensors, and how you want them placed, so that's probably your first "component choice" to think about. Connectors, especially for high-current devices, take up a depressing amount of PCB real estate.
There are a lot of existing boards aimed at 3d printers that seem like they'd do similar things to what your overall project does. I'm not sure how customizable they are. For instance, there is an impressive lineup at 3D Printer Control Board – Biqu Equipment - most seem to use assorted high-end STM32F processors (theoretically programmable with Arduino.) It might be easier to start with something like that and add a cooperating microcontroller to fulfill any additional needs, than to design something from scratch.
What is that in the ground connection on the eSP32 and other parts, it looks like a diode on the drawing missing part of its symbol. The only cap I see is in series with your LED.
