Hello there.
My name is Adam, and I need your help. As a part of my graduation assignment in mechatronics, I have to make some sort of model featuring electronics, programming and mechanics. Most of the work is done. However, because of Corona, I was unable to consult the work with my teacher and have fallen behind because of uncertainity, if the graduation work will be required this year (materials cost a lot for a student so I halted the progress).
Right now I have the last part of the project left to do, but it is the most difficult one, and with my newly acquired skills I am not able to pull it off myself. Therefore, I please and ask you all for help. I am a student and with all my expenses I am not going to be able to reward anyone with money for the help provided ![]()
The project:
I am constructing a self-balancing motorcycle model with the help of a momentum wheel. Gyroscope takes is monitoring the tilt in one axis, and arduino processes the data and sends a signal to a 12V DC motor at the top of the model, which is connected to a momentum wheel, rotating it to counter balance the forces and tilts created, keeping the motorcycle upright. A video of a similar project is provided in the following link:
Available hardware:
Arduino Mega 2560 R3
Arduino Nano
2xServo Motors with ranged angle, 2x Full-rotating Servo motors
Dual Bridge L298N Control Module for motors
3-Axis Gyroscope DOF MPU-6050 - GY-521
Cytron 10Amp 5V-30V DC Motor Driver
12 V DC 900rmp motor with magnetic encoder
What is already done:
The whole 3d printed model,
Mobile app for controlling the model
Bluetooth model paired with the mobile app and servo motors ( so I can control the front wheel for direction and the back wheel for forward and backward movement)
What I need help with:
I need to hook the gyro module up and get the needed rotation along one axis ( roll axis) ( and I might be able to do that myself )
Next I need to somehow process this information and feed it to my 12V DC motor to rotate so that it keeps the whole motorcycle in balance with the balance wheel. The motor can be controlled very accurately as it has built-in encoder.
If needed, I can provide the up-to-date code from the work I have to control the two servo motors.
In case of any further questions I am here and you can also contact me via mail on ado.michalik@gmail.com
Thank you in advance to anyone even reading this far. I very much appreciate your help!
