Self balancing Robot not stable
Hello all, it has been a long time I have been working on my self balancing robot project. Started making a lot of mistakes but fixed and learnt a lot of concept along the way.
Currently, I have a good reading from the MPU 6050 via using a complementary filter. The gyro has also been calibrated. I use the angle to and scale it with a PID control loop to feed the PWM value going to the DC motors. I have added potentiometers for the setpoint, the KI, Kd, Kp value. All the measurement and the update of the PWM is done at a rate of 250 Hz (the code takes 3 ms, I just wait for 1 ms doing nothing). There is also an LED which light up when the robot is balanced, given some degree of tolerance. The mechanical frame is built properly because i can balance the robot on its own when powered off for like 15/20 seconds (which is impressive!).
The problem is that no matter how hard I try, the robot doesn't balance, its either too weak or aggressive. This is taking a toll to my mental health and my self esteem, I am willing to do anything to get this robot balancing.
P.S. : I don't want to just download libraries that do everything for me, I want to implement and understand what I do.
here is the code:
//Include I2C library and declare variables
#include <Wire.h>
//#include <MPU6050.h>
long loopTimer, loopTimer2;
int temperature;
double accelPitch;
double accelRoll;
long acc_x, acc_y, acc_z;
double accel_x, accel_y, accel_z;
double gyroRoll, gyroPitch, gyroYaw;
int gyro_x, gyro_y, gyro_z;
//long gyro_x_cal, gyro_y_cal, gyro_z_cal, acc_x_cal, acc_y_cal, acc_z_cal;  //dont need this after hard coding the offset
long gyro_x_cal = 181, gyro_y_cal = -655, gyro_z_cal = -39 , acc_x_cal, acc_y_cal, acc_z_cal;
double rotation_x, rotation_y, rotation_z;
double freq, dt;
double tau = 0.98;
double roll = 0;
double pitch = 0;
// 250 deg/s --> 131.0, 500 deg/s --> 65.5, 1000 deg/s --> 32.8, 2000 deg/s --> 16.4
long scaleFactorGyro = 65.5;
// 2g --> 16384 , 4g --> 8192 , 8g --> 4096, 16g --> 2048
long scaleFactorAccel = 8192;
//pins for the motor driver
#define M1_d 2
#define M1_dr 3
#define M1_speed 9
#define M2_d 4
#define M2_dr 5
#define M2_speed 10
#define min_speed 20
//Bunch of variables
int pwm;
float err, Kp = 14.0, Kd = 0, Ki = 0; //this sets the sensitivity of the motors in regards to tilt. Tune it with trial and error
bool fwd = false;  //decide to drive motor fwd or bkwd
float errd;  //variable to store derivative of error
float fltr = 0.1; //use this to smooth out rough data
double Ox=0;  //store previous reading for next cycle
float integral = 0; //store the cumulative error
float set_point_offset;  //allowing set point calibration
#define P_pot A0           //pot to set the Kp value 0 to 30
#define D_pot A1           //pot to set the Kd value 0 to 20
#define set_point_offset_pot A2   // use this pot to change the centre set point
#define I_pot A3           //pot to set the Ki value 0 to 5
#define BALANCE_LED 12    //LED that lights up when robot is balanced
  // Start
  Wire.begin();
  // Setup the registers of the MPU-6050 and start up
  setup_mpu_6050_registers();
  //calibrate_sensor();   //dont need this anymore
  // Display headers
  /*Serial.print("\nNote 1: Yaw is not filtered and will drift!\n");
  Serial.print("\nNote 2: Make sure sampling frequency is ~250 Hz\n");
  Serial.print("Sampling Frequency (Hz)\t\t");
  Serial.print("Roll (deg)\t\t");
  Serial.print("Pitch (deg)\t\t");
  Serial.print("Yaw (deg)\t\t\n");*/
  //set motor driver pin as output
  pinMode(M1_d , OUTPUT);
  pinMode(M1_dr , OUTPUT);
  pinMode(M1_speed , OUTPUT);
  pinMode(M2_d , OUTPUT);
  pinMode(M2_dr , OUTPUT);
  pinMode(M2_speed , OUTPUT);
  pinMode(P_pot , INPUT);
  pinMode(D_pot , INPUT);
  pinMode(I_pot , INPUT);
  pinMode(set_point_offset_pot , INPUT);
  // make surre the motors are OFF when powered up
  digitalWrite(M1_d , LOW);
  digitalWrite(M1_dr , LOW);
  digitalWrite(M1_speed , LOW);
  digitalWrite(M2_d , LOW);
  digitalWrite(M2_dr , LOW);
  digitalWrite(M2_speed , LOW);
  //set teh LED as output
  pinMode(BALANCE_LED, OUTPUT);
  // Reset the loop timer
  loopTimer = micros();
  loopTimer2 = micros();
  freq = 1/((micros() - loopTimer2) * 1e-6);
  dt = 1/freq;
  // Read the raw acc data from MPU-6050
  read_mpu_6050_data();
  // Subtract the offset calibration value
  gyro_x -= gyro_x_cal;
  gyro_y -= gyro_y_cal;
  gyro_z -= gyro_z_cal;
  // Convert to instantaneous degrees per second
  rotation_x = (double)gyro_x / (double)scaleFactorGyro;
  rotation_y = (double)gyro_y / (double)scaleFactorGyro;
  rotation_z = (double)gyro_z / (double)scaleFactorGyro;
  // Convert to g force
  accel_x = (double)acc_x / (double)scaleFactorAccel;
  accel_y = (double)acc_y / (double)scaleFactorAccel;
  accel_z = (double)acc_z / (double)scaleFactorAccel;
  // Complementary filter
  accelPitch = atan2(accel_y, accel_z) * RAD_TO_DEG;
  accelRoll = atan2(accel_x, accel_z) * RAD_TO_DEG;
  pitch = (tau)*(pitch + rotation_x*dt) + (1-tau)*(accelPitch);
  roll =  (tau)*(roll - rotation_y*dt) + (1-tau)*(accelRoll);
  /*gyroPitch += rotation_x*dt;
  gyroRoll -= rotation_y*dt;
  gyroYaw += rotation_z*dt;*/
  // Visualize just the roll
  // Serial.print(roll); Serial.print(",");
  // Serial.print(gyroRoll); Serial.print(",");
  // Serial.println(accelRoll);
  // Visualize just the pitch
  // Serial.print(pitch); Serial.print(",");
  // Serial.print(gyroPitch); Serial.print(",");
  // Serial.println(accelPitch);
  // Data out serial monitor
   Serial.print(freq,0);   Serial.print(",");
   Serial.println(roll - set_point_offset,1);   //Serial.print(", \t");
  //  Serial.print(" Kp = ");    Serial.print(Kp);
  //  Serial.print(" Ki = ");    Serial.print(Ki);
  //  Serial.print(" Kd = ");    Serial.println(Kd);
  set_PD_constants();   //reading pots to calibrate PD values
  calibrate_set_point_offset(); //read pot to adjust centre point
  balance_LED();         //light up an LED if robot is balanced
  // Wait until the loopTimer reaches 4000us (250Hz) before next loop
  while (micros() - loopTimer <= 4000);
void calibrate_set_point_offset(){
  set_point_offset = analogRead(set_point_offset_pot);
  set_point_offset = (float(set_point_offset / 1023) * 10) - 5 ; //the value goes from +- 5 degrees
void set_PD_constants(){
  Kp = analogRead(P_pot); //read Kp pot
  Kd = analogRead(D_pot); //read Kd pot
  Ki = analogRead(I_pot); //read Ki pot
  Kp = (Kp / 1023) * 30;  //map the values
  Kd = (Kd / 1023) * 20;
  Ki = (Ki / 1023) * 5;
void balance_LED(){
  if ((roll - set_point_offset) > -0.3 && (roll - set_point_offset) < 0.3){ //if almost balanced with 0.3 degrees of tollerance
    digitalWrite(BALANCE_LED ,1);
    stop();
  else{
    digitalWrite(BALANCE_LED ,0);
    // moved here because I dont wanna update motors if no need
    balance_robot();      //update the pwm and direction
void read_mpu_6050_data() {
  // Subroutine for reading the raw data
  Wire.beginTransmission(0x68);
  Wire.write(0x3B);
  Wire.endTransmission();
  Wire.requestFrom(0x68, 14);
  // Read data --> Temperature falls between acc and gyro registers
  acc_x = Wire.read() << 8 | Wire.read();
  acc_y = Wire.read() << 8 | Wire.read();
  acc_z = Wire.read() << 8 | Wire.read();
  temperature = Wire.read() <<8 | Wire.read();
  gyro_x = Wire.read()<<8 | Wire.read();
  gyro_y = Wire.read()<<8 | Wire.read();
  gyro_z = Wire.read()<<8 | Wire.read();
void setup_mpu_6050_registers() {
  //Activate the MPU-6050
  Wire.write(0x6B);
  Wire.write(0x00);
  // Configure the accelerometer
  // Wire.write(0x__);
  // Wire.write; 2g --> 0x00, 4g --> 0x08, 8g --> 0x10, 16g --> 0x18
  Wire.write(0x1C);
  Wire.write(0x08);
  // Configure the gyro
  // 250 deg/s --> 0x00, 500 deg/s --> 0x08, 1000 deg/s --> 0x10, 2000 deg/s --> 0x18
  Wire.write(0x1B);
  Wire.write(0x08);
void calibrate_sensor(){
  int readings_num = 1000;  //1000 samples
  // Calibration
  Serial.println("Calibrating sensor, place on level surface and do not move.");
  // Take  readings for each coordinate and then find average offset
  for (int cal_int = 0; cal_int < readings_num; cal_int ++){
    if(cal_int % 200 == 0)Serial.print(".");  //print . every 200 cycles
    gyro_x_cal += gyro_x;
    gyro_y_cal += gyro_y;
    gyro_z_cal += gyro_z;
    acc_x_cal += acc_x;
    acc_y_cal += acc_y;
    acc_z_cal += acc_z;
    delay(3);
  // Average the values
  gyro_x_cal /= readings_num;
  gyro_y_cal /= readings_num;
  gyro_z_cal /= readings_num;
  acc_x_cal /= readings_num;
  acc_y_cal /= readings_num;
  acc_z_cal /= readings_num;
void balance_robot(){
  err = float(roll) - set_point_offset;   //error from setpoint
  errd = err - Ox;                        //error for Kd
  Ox = err;                               //preparing for next cycle
  integral = integral + (Ki * err) ;
  integral = constrain(integral, -5, 5);
  if (err > 0){   //if tilted fw/bkw
    fwd = true;
  else{
    fwd = false;
  err = abs(err); //dont want to feed a negative pwm value
  //Serial.println(err);  //debug line
  //Serial.println(set_point_offset);  //debug line
  //set motor speed
  pwm = err * Kp + errd * Kd + integral;  //value with PD loop
  pwm = constrain(pwm, min_speed , 255);  //make sure value fits input parameter
  analogWrite(M1_speed , pwm );  //set motor speed add a bit because this motor is weaker
  analogWrite(M2_speed , pwm);  //
  if (fwd){   //if tilted fw/bkw
    digitalWrite(M1_d , HIGH);
    digitalWrite(M2_d , HIGH);
  else{
    digitalWrite(M1_dr , HIGH);
    digitalWrite(M2_dr , HIGH);
void stop(){
You have to choose appropriate K values for the PID loop.
Use your favorite search engine, with the phrase "PID tuning" to find tutorials on how to do that systematically.
I already went trough multiple iterations to do that. I suspect there is more to it
But forgot to post any of the details, so forum members could help correct the mistakes?
I started with the Kp alone. I use a potentiometer to regulate it and use the serial monitor to print the value. a Kp of 14 is too weak, above 18 becomes too aggressive. I cannot find the right value in between them, I have tried even to map the pot to start from 14 and end at 18, still no luck. then I tried to compensate with the Kd term to help the robot detect suddent changes, again, started form 0 and went up slowly and no noticeable difference happened. I zeroed the Kd term and tried with the Ki, this time I noticed that the robot tries to balance a bit better as the oscillation is reduced, but this is still not enough, I already tried to get a combo with all three terms but no luck. I have seen that the robot should be able to balance just with the Kp term, the others are to remove small constant oscillations and to recover faster if pushed.
My first step is to be able to balance it with just the Kp term. I am a bit worried that the error could be also somewhere else. That's why I have reached out, hopefully you are kind with and able to point me to the right direction, I would appreciate it a lot.
It sounds like your approach to PID tuning is reasonable, and since it cannot be made to work, something else is very wrong. Possibilities include:
  1. Poor power supply decoupling. When the motors kick in, noise on the power lines corrupts the sensor data.
  2. Incorrect tilt angle measurement. If the accelerometer and the gyro data are not properly calibrated, combined and converted into tilt angle, motor activation will corrupt the angle measurement.
Your code is unnecessarily complex, and includes lots of calculations that do nothing useful, or the results are not used.
Get rid of unused calculations, like pitch and yaw. Put in Serial.print() statements to check that the tilt angle is as expected, when the robot is held in your hand and tilted in various ways, and that the calculated motor rotation direction is correct.
Another thing to look at is the mechanical setup - anything loose , or free play in linkages will make tuning the system very difficult
it was the mechanical setup. My robot has 2 layers, the bottom one for the heavy batteries and the top one for the circuitry. I just lowered the distance between the two layers and voila, the robot can balance again. The centre of mass was too high with my previous setup.
I also did other kind of measurements like check the stability of the data as suggested by @anon94801460. I already did it while the robot is stationary and the results were great, this time I checked the angle while I was tilting the robot backwards and forwards from +90 to -90 degree. I was recording all the data out the serial monitor in a file and then plotted them on excel. I was quite shocked by the results, if the robot was tilted with moderate speed, the average value was 0 (as expected). If the robot was shaken aggressively, the average value would not be 0 anymore. It does make sense, seems like most of the time the effect of the accelerometer is negligible in the complementary filter (98 % Gyro + 2 % Acc), but if the value of the Acc is too high it will overtake the Gyro value. I was even more impressed by the fact that the system would stabilise itself really fast if the robot was stationary.
Overall, it was a great project. I learnt that you cannot underestimate the mechanical aspects of a robot and not to rely too much on software to compensate hardware imperfections.
