I am trying to send data from an Arduino Uno to Processing.
Video of situation: - YouTube
I made a simple sketch which does this no problem. It is only when I try to have the Arduino send data to Processing in an "if conditional" from an analog sensor reading that I run into trouble.
For instance, the simple send from Arduino looks like this:
int ledPin = 13;
pinMode(ledPin, OUTPUT);
Serial.write(1);
digitalWrite(ledPin, HIGH);
delay(200);
Serial.write(0);
digitalWrite(ledPin, LOW);
delay(200);
And the corresponding Processing code looks like this:
import processing.serial.*;
Serial myPort; // Create object from Serial class
int val;
//change the 0 to a 1 or 2 etc. to match your port
String portName = Serial.list()[2];
myPort = new Serial(this, portName, 9600);
rectMode(CENTER);
void draw()
background(0);
fill(255);
if (myPort.available()>0)
val = myPort.read();
println(val);
if (val == 1) {
rect(width/2, height/2, 30, 30);
It makes a white square appears when the number "1" is sent to Processing. It works so simple. It works every time. I was so pleased.
However, when I try it with the next Arduino sketch, nothing ever happens. It always stays on "0" even though I can see on the Arduino the LED turns on showing that yes, this piece of code has run. The Processing portion can stay exactly the same.
Why am I not seeing it work right? I have tried so many things. This tells me it's either painfully obvious or I've done something horribly karmically wrong and this is my punishment.
Thank you for nay tips.
// Used to interface with electronic drum pads
// Using a piezo sensor
// Casey Scalf 2015
int ledPin = 13;
int padPin = 0; // Red
// Black is Ground
byte val;
byte a = 0;
int THRESHOLD = 20;
val = analogRead(padPin);
if (val <= THRESHOLD) {
a = 0;
Serial.write(a);
if (val >= THRESHOLD) {
a = 1;
Serial.write(a);
