I used TCP command to send data to the server whose URL is http://(Server IP):Port/test/2000/98/2017-04-14
We have configured server in such way that it will automatically captures the values from the URL e.g. from url http://(Server IP):Port/test/2000/98/2017-04-14 following values are being captured at server end-
2000/98/2017-04-14
I try to send data using following AT commands-
AT+CGATT?
AT+CIPMUX=1
AT+CSTT="airtelgprs.com","",""
AT+CIICR
AT+CIFSR
AT+CIPSTART="TCP","Server IP",Port
AT+CIPSEND
GET /test/2000/98/2017-04-14 HTTP/1.1
AT+CIPCLOSE
AT+CIPSHUT
In above commands 2000/98/2017-04-14 is the data which I want to send. Unfortunately I'm not able to send it. Can somebody please help me to resolve this issue. Im new to A6 and not expert for the AT commands. So kindly explain the solution accordingly. If someone can suggest the AT commands to do the same ,then it will be highly appreciated.
Is there any way to access http URL directly using A6 module? As far as I know A6 doesn't support http protocol. Please let me know the solution.
Thanks and Regards,
Tushar
