Send data via BLE server
hi
I create a project with ESP32-pico-mini
I want to use it as BLE server that when it receive a request from client, send a string as an answer.
At first I use BLE Arduino example and send a byte every 0.5 second. I use cellphone as a client and i use LightBlue and nRF connect app. in both of them I should press a key to receive data( in LightBlue I should press Read Again and in nRF I should press down key)
and none of them can not receive data automatically.
And also I have another problem.
when I change CHARACTERISTIC_UUID or its properties, they don't change any more and they remain what ever they were.
    Video: https://www.youtube.com/watch?v=oCMOYS71NIU
    Based on Neil Kolban example for IDF: https://github.com/nkolban/esp32-snippets/blob/master/cpp_utils/tests/BLE%20Tests/SampleNotify.cpp
    Ported to Arduino ESP32 by Evandro Copercini
   Create a BLE server that, once we receive a connection, will send periodic notifications.
   The service advertises itself as: 6E400001-B5A3-F393-E0A9-E50E24DCCA9E
   Has a characteristic of: 6E400002-B5A3-F393-E0A9-E50E24DCCA9E - used for receiving data with "WRITE"
   Has a characteristic of: 6E400003-B5A3-F393-E0A9-E50E24DCCA9E - used to send data with  "NOTIFY"
   The design of creating the BLE server is:
   1. Create a BLE Server
   2. Create a BLE Service
   3. Create a BLE Characteristic on the Service
   4. Create a BLE Descriptor on the characteristic
   5. Start the service.
   6. Start advertising.
   In this example rxValue is the data received (only accessible inside that function).
   And txValue is the data to be sent, in this example just a byte incremented every second.
#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
#include <BLE2901.h>
#include "OP750.h"
BLEServer *pServer = NULL;
BLECharacteristic *pCharacteristic = NULL;
BLE2901 *descriptor_2901 = NULL;
bool deviceConnected = false;
bool oldDeviceConnected = false;
uint8_t txValue = '0';
uint8_t DataAvailable = 0;
// See the following for generating UUIDs:
// https://www.uuidgenerator.net/
#define SERVICE_UUID              "74b9dd20-0f16-460f-a5ed-40e5a3cde6a0"  // UART service UUID
#define CHARACTERISTIC_UUID       "bf8796f1-64f7-70b5-1e41-09bb46d79105"
class MyServerCallbacks : public BLEServerCallbacks {
  void onConnect(BLEServer *pServer) {
    deviceConnected = true;
    digitalWrite(BT_LED, HIGH);
    Serial.println("BLE Connected");
  void onDisconnect(BLEServer *pServer) {
    digitalWrite(BT_LED, LOW);
    Serial.println("BLE DisConnected");
  setCpuFrequencyMhz(80);
  Configurations();
  digitalWrite(METER_SELECT, HIGH);
  digitalWrite(SELF_SHUTDOWN, HIGH);
  digitalWrite(GREEN_LED, HIGH);
  BLEDevice::init("ESP64");
  // Create the BLE Server
  pServer = BLEDevice::createServer();
  pServer->setCallbacks(new MyServerCallbacks());
  // Create the BLE Service
  BLEService *pService = pServer->createService(SERVICE_UUID);
  // Create a BLE Characteristic
  pCharacteristic = pService->createCharacteristic(
                      CHARACTERISTIC_UUID,
                      BLECharacteristic::PROPERTY_READ   |
                      BLECharacteristic::PROPERTY_WRITE  |
                      BLECharacteristic::PROPERTY_NOTIFY |
                      BLECharacteristic::PROPERTY_INDICATE
  // https://www.bluetooth.com/specifications/gatt/viewer?attributeXmlFile=org.bluetooth.descriptor.gatt.client_characteristic_configuration.xml
  // Create a BLE Descriptor
  // Creates BLE Descriptor 0x2902: Client Characteristic Configuration Descriptor (CCCD)
  pCharacteristic->addDescriptor(new BLE2902());
  // Adds also the Characteristic User Description - 0x2901 descriptor
  descriptor_2901 = new BLE2901();
  descriptor_2901->setDescription("My own description for this characteristic.");
  descriptor_2901->setAccessPermissions(ESP_GATT_PERM_READ);  // enforce read only - default is Read|Write
  pCharacteristic->addDescriptor(descriptor_2901);
  // Start the service
  pService->start();
  // Start advertising
  BLEAdvertising *pAdvertising = BLEDevice::getAdvertising();
  pAdvertising->addServiceUUID(SERVICE_UUID);
  pAdvertising->setScanResponse(false);
  pAdvertising->setMinPreferred(0x0);  // set value to 0x00 to not advertise this parameter
  BLEDevice::startAdvertising();
  Serial.println("Waiting a client connection to notify...");
  if (deviceConnected){
    pCharacteristic->setValue(&txValue,1);
    pCharacteristic->notify(true);
    Serial.write(txValue);
    txValue++;
  // disconnecting
  if (!deviceConnected && oldDeviceConnected) {
    delay(500);                   // give the bluetooth stack the chance to get things ready
    pServer->startAdvertising();  // restart advertising
    Serial.println("start advertising");
    oldDeviceConnected = deviceConnected;
  // connecting
  if (deviceConnected && !oldDeviceConnected) {
    // do stuff here on connecting
void Configurations(void)
// config ports
  ConfigPorts();
  Serial.begin(115200, SERIAL_8N1);
// config serial port
  Serial1.begin(300, SERIAL_7E1,RXPIN,TXPIN);
void ConfigPorts(void)
  pinMode(POWER_CHECK, INPUT);
  pinMode(KEY_STATUS,INPUT);
  pinMode(BATTERY_VOLTAGE, INPUT);
  pinMode(OP_LED, OUTPUT);
  pinMode(BT_LED, OUTPUT);
  pinMode(GREEN_LED, OUTPUT);
  pinMode(RED_LED, OUTPUT);
  pinMode(METER_SELECT,OUTPUT);
  pinMode(SELF_SHUTDOWN,OUTPUT);
  pinMode(BOOT,OUTPUT);
I moved your topic to a more appropriate forum category @shadi1979.
The Nano ESP32 category you chose is only used for discussions directly related to the Arduino Nano ESP32 board.
In the future, please take the time to pick the forum category that best suits the subject of your question. There is an "About the _____ category" topic at the top of each category that explains its purpose.
Thanks in advance for your cooperation.
