Send data via serial communication from nodeMCU to Arduino Uno
My project is an IoT based, ambient variables monitoring project. What I need to achieve is send information from 3 "rooms" (humidity and temperature), to a gateway device.
The 3 rooms have a nodemcu esp8266 with a dht22 sensor attached to each of them, and all those 3 devices send the information to another nodemcu which is the receiver of this data, via WiFi (the project must be wireless except for the gateway-arduino connection). What I'm struggling with is trying to further this data via serial communication to an Arduino Uno R3 device, so I can process and upload the entire dataset later via Google drive. The problem is whenever I try this operation, the Arduino doesn't receive anything from the nodemcu device. I attempted to try readBytes and also directly printing in an ESPserial variable via the SoftwareSerial.h library.
This is the code for the nodeMCU device:
#include <ESP8266WiFi.h>
#include <espnow.h>
#include <SoftwareSerial.h>
SoftwareSerial ESPserial(4, 5); // RX, TX
// Digital pin connected to the DHT sensor
#define DHTPIN 2
// Uncomment the type of sensor in use:
//#define DHTTYPE    DHT11     // DHT 11
//#define DHTTYPE    DHT22     // DHT 22 (AM2302)
//#define DHTTYPE    DHT21     // DHT 21 (AM2301)
// Updates DHT readings every 4 seconds
const long interval = 4000;
unsigned long previousMillis = 0;    // will store last time DHT was updated
typedef struct Data{
  int id;
  float temperature;
  float humidity;
} Data;
Data myData;
Data nodeMCU_D98F;
Data nodeMCU_A942;
Data nodeMCU_15B5;
Data nodeMCUStruct[3] = {nodeMCU_D98F, nodeMCU_A942, nodeMCU_15B5};
// Callback when data is received
void OnDataRecv(uint8_t * mac, uint8_t *incomingData, uint8_t len) {
  char macStr[18];
  Serial.print("Packet received from: ");
  snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x",
  mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
  Serial.println(macStr);
  memcpy(&myData, incomingData, sizeof(myData));
  nodeMCUStruct[myData.id-1].temperature = myData.temperature;
  nodeMCUStruct[myData.id-1].humidity = myData.humidity;
void printIncomingReadings(){
  Serial.println(nodeMCUStruct[0].temperature);
  Serial.println(nodeMCUStruct[0].humidity);
  Serial.println(nodeMCUStruct[1].temperature);
  Serial.println(nodeMCUStruct[1].humidity);
  Serial.println(nodeMCUStruct[2].temperature);
  Serial.println(nodeMCUStruct[2].humidity);
  ESPserial.println(nodeMCUStruct[0].temperature);
  ESPserial.println(nodeMCUStruct[0].humidity);
  ESPserial.println(nodeMCUStruct[1].temperature);
  ESPserial.println(nodeMCUStruct[1].humidity);
  ESPserial.println(nodeMCUStruct[2].temperature);
  ESPserial.println(nodeMCUStruct[2].humidity);
  // Init Serial Monitor
  ESPserial.begin(115200);
  // Set device as a Wi-Fi Station
  WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  // Init ESP-NOW
  if (esp_now_init() != 0) {
    Serial.println("Error initializing ESP-NOW");
    return;
  // Set ESP-NOW Role
  esp_now_set_self_role(ESP_NOW_ROLE_COMBO);
  // Register for a callback function that will be called when data is received
  esp_now_register_recv_cb(OnDataRecv);
  if (currentMillis - previousMillis >= interval) {
    printIncomingReadings();
And down below is the Arduino Uno code:
#include <DHT.h>
#include <stdlib.h>
#include <ESP8266_Lib.h>
//SoftwareSerial ESPserial(7, 8); // RX, TX
#define MQ2PIN 2
#define DHTPIN 5
#define BUZZER 3
#define timeSecondsBuzzer 0.5
#define timeSecondsAll 4
#define DEBUG true
DHT dht(DHTPIN, DHTTYPE);
float mq2Value;
float humidity;
float temperature;
float data;
int i;
int trigger;
int error;
unsigned long now = millis();
unsigned long lastTriggerBuzzer = 0;
unsigned long lastTriggerAll = 0;
int state = 0;
#define LED 12
  int id;
  float temperature;
  float humidity;
} Data;
Data myData;
Data nodeMCU_D98F;
Data nodeMCU_A942;
Data nodeMCU_15B5;
void prompt(){
   for(int i=1;i<=10;i++)
      now = millis();
      if(state == 0)
        if(now - lastTriggerBuzzer > (timeSecondsBuzzer*1000))
          digitalWrite(BUZZER,HIGH);
      else digitalWrite(BUZZER,LOW);
  //ESPserial.begin(115200);
  dht.begin();
  pinMode(LED, OUTPUT);
  digitalWrite(LED, HIGH);
  start:
  state = 1;
  error = 0;
  humidity=dht.readHumidity();
  temperature=dht.readTemperature();
  mq2Value = analogRead(MQ2PIN);
  mq2Value=map(mq2Value,0,850,0,100);
  char buffer[10];
  if(error==1) goto start;
  now = millis();
  if((now - lastTriggerAll > (timeSecondsAll*1000))){
    temperature = dht.readTemperature();
    humidity = dht.readHumidity();
    //Serial.print("Temperature: ");
    Serial.println(temperature);
    //Serial.println(" C");
    //Serial.print("Humidity: ");
    Serial.println(humidity);
    //Serial.println(" %");
    //Serial.print("Gas: ");
    Serial.println(mq2Value);
    lastTriggerAll = millis();
    prompt();
//    if(ESPserial.available() >= sizeof(Data)){
//    ESPserial.readBytes((uint8_t*)&nodeMCUStruct, sizeof(Data));
//    Serial.println(nodeMCUStruct[0].temperature);
//    Serial.println(nodeMCUStruct[0].humidity);
//    Serial.println(nodeMCUStruct[1].temperature);
//    Serial.println(nodeMCUStruct[1].humidity);
//    Serial.println(nodeMCUStruct[2].temperature);
//    Serial.println(nodeMCUStruct[2].humidity);
    if(Serial.available()){
      Serial.write(Serial.read());
  /*if(mq2Value>50)
     state = 0;
My previous attempt with ESPserial.println() like shown (code is commented) didn't send the data on the Arduino device at all. The code shown above in regards to the serial communication was adapted from this Tutorial. I use different RX-TX pins for this project than the video presents
My question here is: what's the best way to send the nodeMCU data over to the Arduino device via serial communication related to my example and how should I implement it? Perhaps using readBytes if it's a possibility. I would greatly appreciate any help.
Welcome to the forum
Have you taken the different operating voltages between the Uno and nodeMCU into account ?
Which pins of the Uno are you using for the Serial connection ?
Thanks, and yes I did, the voltages are no longer an issue in this instance. As written in the code, for the Arduino device I'm using pins 7 and 8 as RX-TX. I did initial testing with this configuration and it works just fine (by sending a hardcoded variable)
Give an example of a set of data (for example: 23.5, 45.7) that you want to transfer from NodeMCU to UNO over (software) Serial Port.
The data stream I want to send looks like this (example):
23.70
65.40
24.90
70.10
27.00
60.90
All the variables are float type.
Why not ?
The data sent and received is accurate, and I ran several debug prints to ensure the devices work accordingly. In my project there are no electronic related issues, it's a programming/debugging issue
Quote from web:
When wiring anything from room to room, there is a danger that the earth ground for each room is NOT at the same zero voltage. Check before connecting grounds together.
The power supply for each device comes from a phone charger (5V-2A or 5V-1A), via microUSB cable. I'm not wiring anything directly to the house electrical wiring.
But again, my issue here is not in regards to wiring, electrical connections etc. I only cannot send the data from NodeMCU to Uno via serial communication.
SoftwareSerial has its limitations; use 19200 is a reasonable choice that will work most of the time.
I understand that is not today's problem. But this description says ALL your connections, from room to room are floating antennas picking up noise. Even the common ground between all devices is now an antenna.
Here is a demonstrative example of the use of strtok() function for receiving/extracting float items from an incoming comma (,) separated and Newline terminated string.
char myString[50] = {0};
char delimiter[2] = ",";
char *token;
  byte n = Serial.available();
  if (n != 0)
    byte m = Serial.readBytesUntil('\n', myString, 50);
    myString[m] = '\0'; //insert null-byte
    //-------extract individual float items-------
    token = strtok(myString, delimiter);
    float y1 = atof(token);
    Serial.println(y1, 2);
    token = strtok(NULL, delimiter);
    float y2 = atof(token);
    Serial.println(y2, 2);
Output:
23.70
65.40
If I use this I could probably change the delimiter to newline as I'm not using any commas between my data variables. Each temperature and humidity is printed on a new line
All I'm getting by using this code is just the Uno sensor readings which are local. Nothing goes through from NodeMCU
1. Make connection among sensors, NodeMCU, and UNO (Fig-1). Send data from NodeMCU to UNO over Soft Serial Port using print() method. For example:
ESPserial.print(temperature, 2); //2-digit after decimal point.
ESPserial,print(',');   //delimiter
ESPserial.print(humidity, 2);
ESPserial.print('\n');   //message terminator
2. Suggested connection between NodeMCU and UNO:
uartNodeUNO
Figure-1:
So the data needs to be sent from NodeMCU to Arduino, and I want to see it on the Arduino's port. The port shows nothing from the NodeMCU likely due to your argument, basically just pushing the data away instead of collecting it. The pins are the following:
NodeMCU: GPIO5-GPIO4 (RX-TX)
Uno: D7-D8 (RX-TX)
Should I print what I'm reading on the port instead, meaning Serial.println(Serial.read()) and not Serial.write(Serial.read())?
Why is there so contradiction in the above?
Arduino UNO has no legends like D7-D8; have you wanted to mean -- 7, 8?
I just fixed the problem, and made the project work the way I wanted to. Changed the ESPserial baud rate to 9600, and used the following code in the Uno receiver:
while (ESPserial.available()>0){
      serialData = ESPserial.read();
      //if(serialData=='\n') break;
      //else incomingData += serialData;
      Serial.print(incomingData);
      incomingData = "";
      serialData = 0;
While on the nodeMCU sender I printed the data on the serial like this:
  ESPserial.println(nodeMCUStruct[0].temperature); //ESPserial.print("A");
  ESPserial.println(nodeMCUStruct[0].humidity); //ESPserial.print("B");
  ESPserial.println(nodeMCUStruct[1].temperature); //ESPserial.print("C");
  ESPserial.println(nodeMCUStruct[1].humidity); //ESPserial.print("D");
  ESPserial.println(nodeMCUStruct[2].temperature); //ESPserial.print("E");
  ESPserial.println(nodeMCUStruct[2].humidity); //ESPserial.print("F");
  //ESPserial.print("\n");
//  str = String(nodeMCUStruct[0].temperature) + String("\n") + String(nodeMCUStruct[0].humidity) + String("\n") + String(nodeMCUStruct[1].temperature) + String("\n") + String(nodeMCUStruct[1].humidity) + String("\n") + String(nodeMCUStruct[2].temperature) + String("\n") + String(nodeMCUStruct[2].humidity);
//  ESPserial.println(str);
To clarify here, yes, I meant 7 and 8 for the Uno pins. There is however no contradiction because 4 and 5 are GPIO4 and GPIO5 on the NodeMCU used to communicate to Uno. So GPIO4 (RX) on the NodeMCU communicates with 7 (RX) on the Uno, and GPIO5 (TX) NodeMCU communicates with 8 (RX) Uno
I can continue with the project now, thank you everyone for the help and suggested steps to discover the issue.
