If FTP isn't acceptable, let me know. I won't waste time on it.
Seems to be working ok. I can download and read the file.
It is FTP with user and password auth.
Edit: Here is the code. Enter 'f' to download. 'r' to read the file from the SD.
Change the user, password, and fileName. I cleaned up the code a bit. Left the response troubleshooting stuff for you.
#include <SD.h>
#include <Ethernet.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x59, 0x67 };
IPAddress ip( 192, 168, 1, 2 );
IPAddress gateway( 192, 168, 1, 1 );
IPAddress subnet( 255, 255, 255, 0 );
IPAddress server(192,168,1,29);
EthernetClient client;
EthernetClient dclient;
char outBuf[128];
char outCount;
char user[] = "myUser";
char password[] = "myPassword";
char fileName[] = "test.txt";
pinMode(4,OUTPUT);
digitalWrite(4,HIGH);
pinMode(10,OUTPUT);
digitalWrite(10,HIGH);
if(SD.begin(4) == 0)
Serial.println("SD init fail");
Ethernet.begin(mac, ip, gateway, gateway, subnet);
delay(2000);
Serial.println("Ready. Press f or r");
byte inChar;
inChar = Serial.read();
if(inChar == 'f')
if(doFTP()) Serial.println("FTP OK");
else Serial.println("FTP FAIL");
if(inChar == 'r')
readSD();
File fh;
byte doFTP()
SD.remove(fileName);
fh = SD.open(fileName,FILE_WRITE);
if(!fh)
Serial.println("SD open fail");
return 0;
Serial.println("SD open");
if (client.connect(server,21)) {
Serial.println("Command connected");
else {
fh.close();
Serial.println("Command connection failed");
return 0;
if(!eRcv()) return 0;
client.write("USER ");
client.write(user);
client.write("\r\n");
client.write("PASS ");
client.write(password);
client.write("SYST\r\n");
client.write("TYPE I\r\n");
client.write("PWD\r\n");
// client.write("CWD ./htdocs\r\n");
// client.write("PWD\r\n");
// if(!eRcv()) return 0;
client.write("PASV\r\n");
char *tStr = strtok(outBuf,"(,");
int array_pasv[6];
for ( int i = 0; i < 6; i++) {
tStr = strtok(NULL,"(,");
array_pasv[i] = atoi(tStr);
if(tStr == NULL)
Serial.println("Bad PASV Answer");
unsigned int hiPort,loPort;
hiPort = array_pasv[4] << 8;
loPort = array_pasv[5] & 255;
Serial.print("Data port: ");
hiPort = hiPort | loPort;
Serial.println(hiPort);
if (dclient.connect(server,hiPort)) {
Serial.println("Data connected");
else {
Serial.println("Data connection failed");
client.stop();
fh.close();
return 0;
client.write("RETR ");
client.println(fileName);
if(!eRcv())
dclient.stop();
return 0;
while(dclient.connected())
while(dclient.available())
byte c = dclient.read();
fh.write(c);
Serial.write(c);
fh.close();
Serial.println("SD closed");
dclient.stop();
Serial.println("Data disconnected");
client.write("QUIT\r\n");
client.stop();
Serial.println("Command disconnected");
return 1;
byte eRcv()
byte respCode;
byte thisByte;
while(!client.available()) delay(1);
respCode = client.peek();
outCount = 0;
while(client.available())
thisByte = client.read();
Serial.write(thisByte);
if(outCount < 127)
outBuf[outCount] = thisByte;
outCount++;
outBuf[outCount] = 0;
if(respCode >= '4')
efail();
return 0;
return 1;
void efail()
byte thisByte = 0;
client.stop();
fh.close();
void readSD()
Serial.println("SD read");
fh = SD.open(fileName,FILE_READ);
if(!fh)
return;
while(fh.available())
Serial.write(fh.read());
fh.close();
Serial.println("Done");
