Send pressure from 2 esp32 boards to one and get all the values on each sender board to compare and turn on relay
How can i do it? espnow ? mesh ?
This would be simple using ESPNow but why do you need 3 boards to do it ? How far apart are the 2 boards with the pressure sensors ?
Use ESPNOW.
it's for an industrial application, the boards the distance between the boards can be up to 15 meters. We need a central board to receive every single pressure and send back all the pressure to each sender which will make the comparsion and the action.
Industrial application, better yet, use a Raspberry Pi as a MQTT Broker and have the ESP32's as MQTT clients.
problem is the espnow examples i see is just to send data from many to one but how to send back the data received on the receiver side to the senders?
Use a Raspberry Pi as a MQTT Broker and have the ESP32's as MQTT clients. As MQTT clients the ESP32's can send and receive info from the MQTT Broker.
The ESP32's can then only 'see' the Raspberry Pi as being the network. Keeping the ESP32's off the main network and then have only the Raspberry Pi be connected to the main network and source controller for the ESP's.
Node-Red can be used on the Raspberry Pi as a control center or write your own using C++ or Python. I used Python.
If the 2 boards with the pressure sensors can communicate over that distance then you don't need a third board
Take a look at 2 way communication in Getting Started with ESP-NOW (ESP32 with Arduino IDE) | Random Nerd Tutorials
in fact there is more than two boards that's why i need to process it on a central board.
You still only need as many boards as there are pressure sensors but with more than 2 the MQTT would be a neater way to do it
Use a PC or get a Raspberry Pi to use as a MQTT Broker. Setup the ESP32's as MQTT clients. Connect 1000's of clients.
do you have an example how to do that with MQTT ?
ESP32 MQTT client.
#include <WiFi.h>
#include <PubSubClient.h>
#include "certs.h" // include the connection infor for WiFi and MQTT
#include "sdkconfig.h" // used for log printing
#include "esp_system.h"
#include "freertos/FreeRTOS.h" //freeRTOS items to be used
#include "freertos/task.h"
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BME680.h"
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
#include <driver/adc.h>
#include "esp32-hal-ledc.h"
#include <HardwareSerial.h>
#include <SimpleKalmanFilter.h>
#include "MHZ19.h"
#include <ESP32Time.h>
#include <SolarCalculator.h>
ESP32Time rtc;
MHZ19 myMHZ19;
Adafruit_BME680 bme( GPIO_NUM_5 ); // use hardware SPI, set GPIO pin to use
//Adafruit_ST7789 tft = Adafruit_ST7789( TFT_CS     , TFT_DC    , TFT_MOSI   , TFT_SCLK   , TFT_RST     );
Adafruit_ST7789 tft   = Adafruit_ST7789( GPIO_NUM_15, GPIO_NUM_0, GPIO_NUM_13, GPIO_NUM_14, GPIO_NUM_22 );
WiFiClient   wifiClient; // do the WiFi instantiation thing
PubSubClient MQTTclient( mqtt_server, mqtt_port, wifiClient ); //do the MQTT instantiation thing
#define evtDoParticleRead     ( 1 << 0 ) // declare an event
#define evtWaitForBME         ( 1 << 1 )
#define evtParseMQTT          ( 1 << 3 )
EventGroupHandle_t eg; // variable for the event group handle
QueueHandle_t xQ_WindChillDewPoint;
QueueHandle_t xQ_eData; // environmental data to be displayed on the screen
struct stu_eData
  float  Temperature = 0.0f;
  float  Pressure    = 0.0f;
  float  Humidity    = 0.0f;
  float  IAQ         = 0.0f; // Index Air Quality
  float  RM0         = 0.0f; // Remaining Moisture from sensor 0
  float  PM2         = 0.0f; // particles in air
  float  WS          = 0.0f; // wind speed
  String WD          = "";   // wind direction
  float  RF          = 0.0f; // rainfall
  float  WSV         = 0.0f; // weather station volts
  float  WSC         = 0.0f; // weather station current
  float  WSP         = 0.0f; // weather station power
  float  WindChill   = 0.0f; //windchill
  float  DewPoint    = 0.0f; //dew point or dew index
  int    SunRiseHr   = 0;    // sunrise hour
  int    SunRiseMin  = 0;    //sunrise minute
  int    SunSetHr    = 0;    //sunset hour
  int    SunSetMin   = 0;    //sunset minute
  int    DuskHr      = 0;    //dusk
  int    DuskMin     = 0;    //dusk
  int    DawnHr      = 0;    // dawn
  int    DawnMin     = 0;    // dawn
  int    TransitHr   = 0;    // 'noon' time
  int    TransitMin  = 0;    // 'noon' time
  double azimuth     = 0.0f;   // Sun's azimuth, in degrees
  double elevation   = 0.0f;     // Sun's elevation, in degrees
  float  CO2         = 0.0f;
} x_eData; // environmental data
QueueHandle_t xQ_Message; // payload and topic queue of MQTT payload and topic
const int payloadSize = 100;
struct stu_message
  char payload [payloadSize] = {'\0'};
  String topic ;
} x_message;
const float oGasResistanceBaseLine = 149598.0f;
int mqttOK = 0;
volatile bool TimeSet = false;
esp_timer_handle_t oneshot_timer; //veriable to store the hardware timer handle
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_PublishPM;
SemaphoreHandle_t sema_mqttOK;
//serial(2) = pin25 RX, pin26 TX
HardwareSerial co2Serial ( 2 );
// interrupt service routine for WiFi events put into IRAM
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  switch (event) {
    default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
//void IRAM_ATTR oneshot_timer_callback( void* arg )
//    case SYSTEM_EVENT_STA_CONNECTED:
//      log_i("Connected to WiFi access point");
//      break;
//    case SYSTEM_EVENT_STA_DISCONNECTED:
//      log_i("Disconnected from WiFi access point");
//      break;
//    case SYSTEM_EVENT_AP_STADISCONNECTED:
//      log_i("WiFi client disconnected");
//  BaseType_t xHigherPriorityTaskWoken;
//  xEventGroupSetBitsFromISR( eg, evtDoParticleRead, &xHigherPriorityTaskWoken );
//} //void IRAM_ATTR oneshot_timer_callback( void* arg )
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
  memset( x_message.payload, '\0', payloadSize ); // clear payload char buffer
  x_message.topic = ""; //clear topic string buffer
  x_message.topic = topic; //store new topic
  int i = 0; // extract payload
  for ( i; i < length; i++)
    x_message.payload[i] = ((char)payload[i]);
  x_message.payload[i] = '\0';
  xQueueOverwrite( xQ_Message, (void *) &x_message );// send data to queue
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
  co2Serial.begin( 9600 , SERIAL_8N1, 25, 26 ); // pin25 RX, pin26 TX
  x_eData.WD.reserve(50);
  x_message.topic.reserve( payloadSize );
  xQ_WindChillDewPoint = xQueueCreate( 1, sizeof(stu_eData) );
  xQ_Message  = xQueueCreate( 1, sizeof(stu_message) );
  xQ_eData    = xQueueCreate( 1, sizeof(stu_eData) ); // sends a queue copy of the structure
  sema_PublishPM = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_PublishPM );
  sema_mqttOK    =  xSemaphoreCreateBinary();
  xSemaphoreGive( sema_mqttOK );
  ledcSetup( 4, 12000, 8 ); // ledc: 4  => Group: 0, Channel: 2, Timer: 1, led frequency, resolution  bits
  ledcAttachPin( GPIO_NUM_12, 4 );   // gpio number and channel
  ledcWrite( 4, 0 ); // write to channel number 4
  eg = xEventGroupCreate(); // get an event group handle
  // output mode
  gpio_config_t io_cfg = {}; // initialize the gpio configuration structure
  io_cfg.mode = GPIO_MODE_OUTPUT; // set gpio mode
  io_cfg.pin_bit_mask = ( (1ULL << GPIO_NUM_4) ); //bit mask of the pins to set
  gpio_config(&io_cfg); // configure the gpio based upon the parameters as set in the configuration structure
  gpio_set_level( GPIO_NUM_4, LOW); // set air particle sensor trigger pin to LOW
  // input mode
  io_cfg = {}; // reinitialize the gpio configuration structure
  io_cfg.mode = GPIO_MODE_INPUT; // set gpio mode. GPIO_NUM_0 input from water level sensor
  io_cfg.pin_bit_mask = ( (1ULL << GPIO_NUM_0) | (1ULL << GPIO_NUM_27)  ); //bit mask of the pins to set, assign gpio number to be configured
  // set up A:D channels, refer: https://dl.espressif.com/doc/esp-idf/latest/api-reference/peripherals/adc.html
  adc1_config_width(ADC_WIDTH_12Bit);
  adc1_config_channel_atten(ADC1_CHANNEL_0, ADC_ATTEN_DB_11);// using GPIO 36
  // https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/system/esp_timer.html?highlight=hardware%20timer High Resoultion Timer API
  //esp_timer_create_args_t oneshot_timer_args = {}; // initialize High Resoulition Timer (HRT) configuration structure
  //oneshot_timer_args.callback = &oneshot_timer_callback; // configure for callback, name of callback function
  //esp_timer_create( &oneshot_timer_args, &oneshot_timer ); // assign configuration to the HRT, receive timer handle
  xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 7000,  NULL, 5, NULL, 1 );
  xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 5000, NULL, 6, NULL, 1 );
  xTaskCreatePinnedToCore( DoTheBME680Thing, "DoTheBME280Thing", 20000, NULL, 5, NULL, 1);
  //xTaskCreatePinnedToCore( fDoParticleDetector, "fDoParticleDetector", 6000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 5000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fDoTheDisplayThing, "fDoTheDisplayThing", 23000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fScreenBlanking, "fScreenBlanking", 2000, NULL, 2, NULL, 1 );
  xTaskCreatePinnedToCore( fGetCO2, "fGetCO2", 4500, NULL, 2, NULL, 1 );
  xTaskCreatePinnedToCore( fParseDewPointWindChill, "fParseDewPointWindChill", 4500, NULL, 2, NULL, 1 );
  xTaskCreatePinnedToCore( fSolarCalculations, "fSolarCalculations", 10000, NULL, 2, NULL, 1 );
} //void setup()
void fSolarCalculations ( void *pvParameters )
  double sunrise;  // Sunrise, in hours (UTC)
  double transit;  // Solar noon, in hours (UTC)
  double sunset;   // Sunset, in hours (UTC)
  double dawn;     // Civil dawn, in hours (UTC)
  double dusk;     // Civil dusk, in hours (UTC)
  //double rt_ascension;  // Sun's right ascension, in degrees
  //double declination;   // Sun's declination, in degrees
  const  float time_zone = -7.0f;
  TickType_t xLastWakeTime = xTaskGetTickCount();
  const TickType_t xFrequency = 1000; //delay for mS
  int count  = 3590;
  int monthX = 1;
  int dayX   = 1;
  for (;;)
    if ( count % 60 == 0 )
      if ( (rtc.getHour(true) >= 12) & (rtc.getHour(true) <= 23) )
        dayX = 0;
        dayX = 1;
      calcSunriseSunset( rtc.getYear(), (rtc.getMonth() + monthX) , (rtc.getDay() + dayX), latitude, longitude, transit, sunrise, sunset );  // Calculate the times of sunrise, transit and sunset
      sunrise += time_zone;
      sunset  += time_zone;
      SolarTimeFormat( sunrise, 0 );
      SolarTimeFormat( sunset, 1 );
      calcCivilDawnDusk( rtc.getYear(), (rtc.getMonth() + monthX) , rtc.getDay(), latitude, longitude, transit, dawn, dusk); // Calculate the times of civil dawn and dusk (UTC)
      transit += time_zone;
      dawn    += time_zone;
      dusk    += time_zone;
      SolarTimeFormat( dawn, 2 );
      SolarTimeFormat( dusk, 3 );
      SolarTimeFormat( transit, 4 );
      calcHorizontalCoordinates( rtc.getYear(), (rtc.getMonth() + monthX) , rtc.getDay(),  rtc.getHour(true) , rtc.getMinute(), rtc.getSecond(), latitude, longitude, x_eData.azimuth, x_eData.elevation );
      x_eData.azimuth   = double(round(x_eData.azimuth * 100)) / 100; // Round to two decimal places
      x_eData.elevation = double(round(x_eData.elevation * 100)) / 100;
      if (count >= 3600 )
        SolarTimeFormat( 0.0f, 5 ); // publish MQTT
        log_i( "Hour:%d Azimuth %f, elevation %f, transit %dhr %dmin, dawn %dhr %dmin, dusk %dhr %dmin", rtc.getHour(true), x_eData.azimuth, x_eData.elevation, x_eData.TransitHr, x_eData.TransitMin, x_eData.DawnHr, x_eData.DawnMin, x_eData.DuskHr, x_eData.DuskMin );
        count = 0;
    //log_i( " high watermark % d",  uxTaskGetStackHighWaterMark( NULL ) );
    vTaskDelayUntil( &xLastWakeTime, xFrequency );
    count++;
  } //for (;;)
  vTaskDelete( NULL );
} //void fSolarCalculations ( )
void SolarTimeFormat( double h, int i  )
  int hours   = 0;
  int minutes = 0;
  if ( h != 0.0f )
    int m = int(round(h * 60));
    hours = (m / 60) % 24;
    minutes = m % 60;
  switch ( i )
    case 0:
      x_eData.SunRiseHr = hours;
      x_eData.SunRiseMin = minutes;
    case 1:
      x_eData.SunSetHr = hours;
      x_eData.SunSetMin = minutes;
    case 2:
      x_eData.DawnHr = hours;
      x_eData.DawnMin = minutes;
    case 3:
      x_eData.DuskHr = hours;
    case 4:
      x_eData.TransitHr = hours;
      x_eData.TransitMin = minutes;
    case 5:
      String sTopic = "";
      sTopic.reserve( 35 );
      sTopic.concat( String(x_eData.SunRiseHr) + "," );
      sTopic.concat( String(x_eData.SunRiseMin) + "," );
      sTopic.concat( String(x_eData.SunSetHr) + "," );
      sTopic.concat( String(x_eData.SunSetMin) + "," );
      sTopic.concat( String(x_eData.DawnHr) + "," );
      sTopic.concat( String(x_eData.DawnMin) + "," );
      sTopic.concat( String(x_eData.TransitHr) + "," );
      sTopic.concat( String(x_eData.TransitMin) );
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY );
      MQTTclient.publish( topicSRSSDDT, sTopic.c_str() );
      xSemaphoreGive( sema_MQTT_KeepAlive );
      sTopic = "";
      sTopic.concat( String(x_eData.azimuth) + "," + String(x_eData.elevation) );
      MQTTclient.publish( topicAzEle, sTopic.c_str() );
      sTopic = "";
  } // switch ( i ) {
} // void SolarTimeFormat( double h, int i  )
  250-400ppm Normal background concentration in outdoor ambient air
  400-1,000ppm  Concentrations typical of occupied indoor spaces with good air exchange
  1,000-2,000ppm  Complaints of drowsiness and poor air.
  2,000-5,000 ppm Headaches, sleepiness and stagnant, stale, stuffy air. Poor concentration, loss of attention, increased heart rate and slight nausea may also be present.
  5,000 Workplace exposure limit (as 8-hour TWA) in most jurisdictions.
  >40,000 ppm Exposure may lead to serious oxygen deprivation resulting in permanent brain damage, coma, even death.
void fParseDewPointWindChill( void *pvParameters )
  while ( !MQTTclient.connected() )
    vTaskDelay( 250 );
  struct stu_message px_message;
  String sDewPoint = "";
  String sWindChill = "";
  sDewPoint.reserve( payloadSize );
  sWindChill.reserve( payloadSize );
  for (;;)
    if ( xQueueReceive(xQ_WindChillDewPoint, &px_message, portMAX_DELAY) == pdTRUE )
      sDewPoint = px_message.payload;
      int commaIndex = sDewPoint.indexOf(',');
      sWindChill.concat ( sDewPoint.substring(0, commaIndex) );
      sDewPoint.remove( 0, (commaIndex + 1) );
      x_eData.WindChill = sWindChill.toFloat();
      x_eData.DewPoint = sDewPoint.toFloat();
      sDewPoint = "";
      sWindChill = "";
void fGetCO2 ( void *pvParameters )
  uint64_t TimePastKalman  = esp_timer_get_time();
  myMHZ19.begin( co2Serial );
  myMHZ19.autoCalibration();
  SimpleKalmanFilter KF_CO2( 1.0f, 1.0f, .01f );
  for ( ;; )
    KF_CO2.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f );
    x_eData.CO2 = KF_CO2.updateEstimate( myMHZ19.getCO2() ); // apply simple Kalman filter
    MQTTclient.publish( topicCO2, String(round(x_eData.CO2)).c_str() );
    // process wind chill and dew point
} //void fMHZ19B ( void *pvParameters )
void fScreenBlanking( void *pvParameters )
  int       TimeOfPause = 10000 * 1000;
  uint64_t  PauseStartTime = esp_timer_get_time();
  bool      Pause = false;
  const int brightness = 250;
  int       countUpDown = brightness;
  for ( ;; )
    if (!Pause )
      //if motion detect then show display otherwise blank display
      if ( !(gpio_get_level( GPIO_NUM_27)) )
        for ( countUpDown; countUpDown-- > 0; )
          ledcWrite( 4, countUpDown ); // write to channel number 4, dim backlight
          vTaskDelay( 7 );
        Pause = true;
        ledcWrite( 4, brightness );
      // still detecting movement reset blanking pause time
      if ( gpio_get_level( GPIO_NUM_27) )
        PauseStartTime = esp_timer_get_time(); // extend pause blanking time
      if ( (esp_timer_get_time() - PauseStartTime) >= TimeOfPause )
        Pause = false;
    vTaskDelay( 250 );
} //void fScreenBlanking( void *pvParameters )
void fparseMQTT( void *pvParameters )
  for (;;)
    if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
      xSemaphoreTake( sema_mqttOK, portMAX_DELAY );
      mqttOK = 0;
      if ( px_message.topic == topicRemainingMoisture_0 )
        x_eData.RM0  = String(px_message.payload).toFloat();
      if ( px_message.topic == topicWindSpeed )
        x_eData.WS = String(px_message.payload).toFloat();
      if ( px_message.topic == topicWindDirection )
        x_eData.WD = "";
        x_eData.WD = String(px_message.payload);
      if ( px_message.topic == topicRainfall )
        x_eData.RF = String(px_message.payload).toFloat();
      if ( px_message.topic == topicWSVolts )
        x_eData.WSV = String(px_message.payload).toFloat();
      if ( px_message.topic == topicWSCurrent )
        x_eData.WSC = String(px_message.payload).toFloat();
      if ( px_message.topic == topicWSPower )
        x_eData.WSP = String(px_message.payload).toFloat();
      if ( px_message.topic == topicDPnWI )
        xQueueSend( xQ_WindChillDewPoint, (void *) &px_message, 1 );
      if ( String(px_message.topic) == topicOK )
        if ( !TimeSet)
          String temp = "";
          temp.reserve(50);
          temp.concat( String(px_message.payload[0]) );
          temp.concat( String(px_message.payload[1]) );
          temp.concat( String(px_message.payload[2]) );
          temp.concat( String(px_message.payload[3]) );
          int year =  temp.toInt();
          temp = "";
          temp.concat( String(px_message.payload[5]) + String(px_message.payload[6]) );
          int month =  temp.toInt();
          temp =  "";
          temp.concat(String(px_message.payload[8]) + String(px_message.payload[9]) );
          int day =  temp.toInt();
          temp = "";
          temp.concat( String(px_message.payload[11]) + String(px_message.payload[12]) );
          int hour =  temp.toInt();
          temp = "";
          temp.concat( String(px_message.payload[14]) + String(px_message.payload[15]) );
          int min =  temp.toInt();
          rtc.setTime( 0, min, hour, day, month, year );
          log_i( "rtc  %s Year %d month %d day %d", rtc.getTime(), rtc.getYear(), (rtc.getMonth() + 1), rtc.getDay() );
          TimeSet = true;
    } //if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
  } //for(;;)
} // void fparseMQTT( void *pvParameters )
void fDoTheDisplayThing( void * parameter )
  tft.init( 240, 320 ); // Init ST7789 320x240
  tft.setRotation( 3 );
  tft.setTextSize( 3 );
  tft.fillScreen( ST77XX_BLACK );
  tft.setTextWrap( false );
  struct stu_eData px_eData;
  ledcWrite( 4, brightness ); //backlight set
  const int MaxString      = 20;
  String oldTempString     = "";
  String oldHumidityString = "";
  String oldAQIString      = "";
  String oldRainfall       = "";
  String oldWindDirection  = "";
  String oldAirPressure    = "";
  String oldRMO            = "";
  String oldPM2            = "";
  //String oldPower          = "";
  String oldC02 = "";
  oldHumidityString.reserve( MaxString );
  oldWindDirection.reserve( MaxString );
  oldAirPressure.reserve( MaxString );
  oldTempString.reserve( MaxString );
  oldAQIString.reserve( MaxString );
  oldRainfall.reserve( MaxString );
  //oldPower.reserve( MaxString );
  oldRMO.reserve( MaxString );
  oldPM2.reserve( MaxString );
  oldC02.reserve( MaxString );
  bool Tick = true;
  const int numOfColors = 40;
  /* https://chrishewett.com/blog/true-rgb565-colour-picker/#:~:text=A%20true%20RGB565%20colour%20picker%2021st%20Oct%202017,in%205%20bits%20and%20green%20in%206%20bits. */
  int colors[numOfColors] = { ST77XX_BLACK, ST77XX_RED, ST77XX_WHITE, ST77XX_BLUE, ST77XX_GREEN, ST77XX_CYAN, ST77XX_MAGENTA, ST77XX_YELLOW, 0xd55b, 0xee09,
                              0x2e15, 0xcb43, 0x6bad, 0x126f, 0x1264, 0xe264, 0xe7e4, 0x87e4, 0x87fe, 0x876a,
                              0xe304, 0x1cc4, 0xf4c4, 0xf4da, 0xcf66, 0xa879, 0x7f28, 0x4f37, 0xfa97, 0x6195,
                              0X8162, 0xc962, 0x517b, 0x325b, 0xea5b, 0x179b, 0xff80, 0xf960, 0x416d, 0x7bd1
  int colorCounter = 1;
  for (;;)
    if ( xQueueReceive(xQ_eData, &px_eData, portMAX_DELAY) == pdTRUE )
      tft.setCursor( 0, 0 );
      tft.setTextColor( colors[0] );
      tft.print( oldTempString );
      tft.setTextColor( colors[colorCounter] );
      oldTempString = "";
      if ( Tick )
        oldTempString.concat( "iTemp " + String(px_eData.Temperature) + "F" );
        oldTempString.concat( "Wind Chill " + String(px_eData.WindChill) + "F" );
      tft.println( oldTempString );
      tft.setCursor( 0, 30 );
      tft.print( oldHumidityString );
      if ( Tick )
        oldHumidityString.concat( "iHum  " + String(px_eData.Humidity) + "%" );
        if ( (px_eData.SunRiseHr < 10) & (px_eData.SunRiseMin < 10) )
          oldHumidityString.concat( "sRise 0" + String(px_eData.SunRiseHr) + "0" + String(px_eData.SunRiseMin) );
        if ( (px_eData.SunRiseHr >= 10) & (px_eData.SunRiseMin < 10) )
          oldHumidityString.concat( "sRise " + String(px_eData.SunRiseHr) + "0" + String(px_eData.SunRiseMin) );
        if ( (px_eData.SunRiseHr < 10) & (px_eData.SunRiseMin >= 10) )
          oldHumidityString.concat( "sRise 0" + String(px_eData.SunRiseHr) + String(px_eData.SunRiseMin) );
        if ( (px_eData.SunRiseHr >= 10) & (px_eData.SunRiseMin >= 10) )
          oldHumidityString.concat( "sRise " + String(px_eData.SunRiseHr) + String(px_eData.SunRiseMin) );
      tft.println( oldHumidityString );
      tft.setCursor( 0, 60 );
      tft.print( oldAirPressure );
      if ( Tick )
        //oldAirPressure.concat( "Pres " + String(px_eData.Pressure) + "mmHg" );
        oldAirPressure.concat( "Dew Pt. " + String(px_eData.DewPoint) + "F" );
        if ( px_eData.SunSetMin < 10 )
          oldAirPressure.concat( "sSet " + String(px_eData.SunSetHr) + "0" + String(px_eData.SunSetMin) );
        if ( px_eData.SunRiseMin >= 10 )
          oldAirPressure.concat( "sSet " + String(px_eData.SunSetHr) + String(px_eData.SunSetMin) );
      tft.println( oldAirPressure );
      tft.setCursor( 0, 90 );
      tft.print( oldAQIString );
      oldAQIString = "";
      oldAQIString.concat( "iAQI " + String(px_eData.IAQ) + "%" );
      tft.println( oldAQIString );
      tft.setCursor( 0, 120 );
      tft.print( oldRMO );
      oldRMO = "";
      //if ( Tick )
        oldRMO.concat( "iRM0 " + String(px_eData.RM0) + "%" );
      //} else {
      //  oldRMO.concat( "iCO2 " + String(CO2) + "ppm" );
      tft.println( oldRMO );
      tft.setCursor( 0, 150 );
      tft.print( oldPM2 );
      oldPM2 = "";
      oldPM2.concat( "PM2 " + String(px_eData.PM2) + "ug/m3" );
      tft.println( oldPM2 );
      tft.setCursor( 0, 180 );
      //tft.print( oldPower );
      tft.print( oldC02 );
      //oldPower = "";
      oldC02 = "";
      //oldPower.concat(  String(px_eData.WSV) + " Volts" );
      oldC02.concat(  "iCO2 " + String(x_eData.CO2) + "ppm" );
      //oldPower.concat(  String(px_eData.WSV) + "V " + String(int(px_eData.WSC * 1000.0f)) + "mA " + String((int(px_eData.WSP * 1000.0f))) + "mW" );
      //tft.println( oldPower );
      tft.println( oldC02 );
      colorCounter++;
      if ( colorCounter > (numOfColors - 1) )
        colorCounter = 1;
      Tick = !Tick;
    } //if ( xQueueReceive(xQ_eData, &px_eData, portMAX_DELAY) == pdTRUE )
  } //for (;;)
} //void fDoTheDisplayTHing( void * parameter )
void fmqttWatchDog( void * paramater )
  int UpdateImeTrigger = 86400; //seconds in a day
  int UpdateTimeInterval = 86300; // 1st time update in 100 counts
  int maxNonMQTTresponse = 15;
  for (;;)
    vTaskDelay( 1000 );
    if ( mqttOK >= maxNonMQTTresponse )
      ESP.restart();
    mqttOK++;
    UpdateTimeInterval++; // trigger new time get
    if ( UpdateTimeInterval >= UpdateImeTrigger )
      TimeSet = false; // sets doneTime to false to get an updated time after a days count of seconds
      UpdateTimeInterval = 0;
float fCalulate_IAQ_Index( int gasResistance, float Humidity)
  float hum_baseline = 40.0f;
  float hum_weighting = 0.25f;
  float gas_offset = 0.0f;
  float hum_offset = 0.0f;
  float hum_score = 0.0f;
  float gas_score = 0.0f;
  gas_offset = oGasResistanceBaseLine - float( gasResistance );
  hum_offset = float( Humidity ) - hum_baseline;
  // calculate hum_score as distance from hum_baseline
  if ( hum_offset > 0.0f )
    hum_score = 100.0f - hum_baseline - hum_offset;
    hum_score /= ( 100.0f - hum_baseline );
    hum_score *= ( hum_weighting * 100.0f );
    hum_score = hum_baseline + hum_offset;
    hum_score /= hum_baseline;
    hum_score *= ( 100.0f - (hum_weighting * 100.0f) );
  //calculate gas score as distance from baseline
  if ( gas_offset > 0.0f )
    gas_score = float( gasResistance ) / oGasResistanceBaseLine;
    gas_score *= ( 100.0f - (hum_weighting * 100.0f ) );
    gas_score = 100.0f - ( hum_weighting * 100.0f );
  return ( hum_score + gas_score );
} //void fCalulate_IAQ_Index( int gasResistance, float Humidity):
//void fDoParticleDetector( void * parameter )
//    ug/m3     AQI                 Lvl AQ (Air Quality)
//    (air Quality Index)
//    0-35     0-50                1   Excellent
//    35-75    51-100              2   Average
//    75-115   101-150             3   Light pollution
//    115-150  151-200             4   moderate
//    150-250  201-300             5   heavy
//    250-500  >=300               6   serious
//  float ADbits = 4095.0f;
//  float uPvolts = 3.3f;
//  float adcValue = 0.0f;
//  float dustDensity = 0.0f;
//  float Voc = 0.6f; // Set the typical output voltage, when there is zero dust.
//  const float K = 0.5f; // Use the typical sensitivity in units of V per 100ug/m3.
//  xEventGroupWaitBits (eg, evtWaitForBME, pdTRUE, pdTRUE, portMAX_DELAY );
//  TickType_t xLastWakeTime = xTaskGetTickCount();
//  const TickType_t xFrequency = 100; //delay for mS
//  for (;;)
//    //enable sensor led
//    gpio_set_level( GPIO_NUM_4, HIGH ); // set gpio 4 to high to turn on sensor internal led for measurement
//    esp_timer_start_once( oneshot_timer, 280 ); // trigger one shot timer for a 280us timeout, warm up time.
//    xEventGroupWaitBits (eg, evtDoParticleRead, pdTRUE, pdTRUE, portMAX_DELAY ); // event will be triggered by the timer expiring, wait here for the 280uS
//    adcValue = float( adc1_get_raw(ADC1_CHANNEL_0) ); //take a raw ADC reading from the dust sensor
//    gpio_set_level( GPIO_NUM_4, LOW );//Shut off the sensor LED
//    adcValue = ( adcValue * uPvolts ) / ADbits; //calculate voltage
//    dustDensity = (adcValue / K) * 100.0; //convert volts to dust density
//    if ( dustDensity < 0.0f )
//      dustDensity = 0.00f; // make negative values a 0
//    if ( xSemaphoreTake( sema_PublishPM, 0 ) == pdTRUE )  // don't wait for semaphore to be available
//      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY );
//      //log_i( "ADC volts %f Dust Density = %ug / m3 ", adcValue, dustDensity ); // print the calculated voltage and dustdensity
//      MQTTclient.publish( topicInsidePM, String(dustDensity).c_str() );
//      xSemaphoreGive( sema_MQTT_KeepAlive );
//      x_eData.PM2 = dustDensity;
//    xLastWakeTime = xTaskGetTickCount();
//    vTaskDelayUntil( &xLastWakeTime, xFrequency );
//    //log_i( " high watermark % d",  uxTaskGetStackHighWaterMark( NULL ) );
//  vTaskDelete( NULL );
//}// end fDoParticleDetector()
void DoTheBME680Thing( void *pvParameters )
  SPI.begin(); // initialize the SPI library
  vTaskDelay( 10 );
  if (!bme.begin()) {
    log_i("Could not find a valid BME680 sensor, check wiring!");
    while (1);
  // Set up oversampling and filter initialization
  bme.setTemperatureOversampling(BME680_OS_8X);
  bme.setHumidityOversampling(BME680_OS_2X);
  bme.setPressureOversampling(BME680_OS_4X);
  bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
  bme.setGasHeater(320, 150); // 320*C for 150 ms
  //wait for a mqtt connection
    vTaskDelay( 250 );
  xEventGroupSetBits( eg, evtWaitForBME );
  const TickType_t xFrequency = 1000 * 15; //delay for mS
  String bmeInfo = "";
  bmeInfo.reserve( 100 );
  for (;;)
    x_eData.Temperature  = bme.readTemperature();
    x_eData.Temperature  = ( x_eData.Temperature * 1.8f ) + 32.0f; // (Celsius x 1.8) + 32
    x_eData.Pressure     = bme.readPressure();
    x_eData.Pressure     = x_eData.Pressure / 133.3223684f; //converts to mmHg
    x_eData.Humidity     = bme.readHumidity();
    x_eData.IAQ          = fCalulate_IAQ_Index( bme.readGas(), x_eData.Humidity );
    //log_i( " temperature % f, Pressure % f, Humidity % f IAQ % f", x_eData.Temperature, x_eData.Pressure, x_eData.Humidity, x_eData.IAQ);
    bmeInfo.concat( String(x_eData.Temperature, 2) );
    bmeInfo.concat( "," );
    bmeInfo.concat( String(x_eData.Pressure, 2) );
    bmeInfo.concat( String(x_eData.Humidity, 2) );
    bmeInfo.concat( String(x_eData.IAQ, 2) );
    if ( MQTTclient.connected() )
      MQTTclient.publish( topicInsideInfo, bmeInfo.c_str() );
    xSemaphoreGive( sema_PublishPM ); // release publish of dust density
    mqttOK ++;
    xQueueOverwrite( xQ_eData, (void *) &x_eData );// send data to display
    bmeInfo = ""; // empty the string buffer
    findDewPointWithHumidity( x_eData.Humidity, x_eData.Temperature );
    // log_i( "DoTheBME280Thing high watermark % d",  uxTaskGetStackHighWaterMark( NULL ) );
  vTaskDelete ( NULL );
  Important to not set vTaskDelay/vTaskDelayUntil to less then 10. Errors begin to develop with the MQTT and network connection.
  makes the initial wifi/mqtt connection and works to keeps those connections open.
void MQTTkeepalive( void *pvParameters )
  sema_MQTT_KeepAlive   = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
  MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
  const TickType_t xFrequency = 250; //delay for ms
  for (;;)
    //check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
    if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
      MQTTclient.loop();
    else {
      log_i( "MQTT keep alive found MQTT status % s WiFi status % s", String(wifiClient.connected()), String(WiFi.status()) );
      if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
        connectToWiFi();
      connectToMQTT();
void connectToMQTT()
  byte mac[5]; // create client ID from mac address
  WiFi.macAddress(mac); // get mac address
  String clientID = String(mac[0]) + String(mac[4]) ; // use mac address to create clientID
    MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password );
    vTaskDelay( 250 );
  MQTTclient.setCallback( mqttCallback );
  MQTTclient.subscribe  ( topicOK );
  MQTTclient.subscribe  ( topicRemainingMoisture_0 );
  MQTTclient.subscribe  ( topicWindSpeed );
  MQTTclient.subscribe  ( topicWindDirection );
  MQTTclient.subscribe  ( topicRainfall );
  MQTTclient.subscribe  ( topicWSVolts );
  MQTTclient.subscribe  ( topicWSCurrent );
  MQTTclient.subscribe  ( topicWSPower );
  MQTTclient.subscribe  ( topicDPnWI );
} //void connectToMQTT()
void connectToWiFi()
  int TryCount = 0;
  while ( WiFi.status() != WL_CONNECTED )
    TryCount++;
    WiFi.disconnect();
    WiFi.begin( SSID, PASSWORD );
    vTaskDelay( 4000 );
    if ( TryCount == 10 )
      ESP.restart();
  WiFi.onEvent( WiFiEvent );
////vo
float findDewPointWithHumidity( float humi, float temperature )
  //Celcius
  float ans =  (temperature - (14.55 + 0.114 * temperature) * (1 - (0.01 * humi)) - pow(((2.5 + 0.007 * temperature) * (1 - (0.01 * humi))), 3) - (15.9 + 0.117 * temperature) * pow((1 - (0.01 * humi)), 14));
  //log_i( "%f", ans );
  return ans;
void loop() { }
