How do I send a string using Bluetooth? I used ble101char.setValue(0x02) to send 1 value and used the same function multiple times with different values to send a string but it is too slow.
I looked at BLECharacteristics.cpp and found
BLECharacteristic::setValue(const unsigned char value[], uint16_t length).
When I tried it an error occurred.
bleTest:37: error: no matching function for call to 'BLECharCharacteristic::setValue(char [4], int)'
ble101char.setValue(dataStream,4);
The rest of my code is below. I want to know how to send a string using Bluetooth
I just figured this out last night. Use the base class, BLECharacteristic. You can provide an initial string value via the constructor (although oddly, only takes a char *, not a char * and length), and then use .setValue(char *, int len) to provide a string afterwards. Note that because this is binary data, you need to know the length of the string rather than expecting it to be zero-terminated.
Hi dekduino, does that mean you have managed to send a string over bluetooth? If possible, could you post the code you used for the arduino and whatever program you use for the receiving bluetooth side?
zwyber:
Hi matiasjaure,
Did you ever manage to build a C# client to connect via BLE and receive data? would you have any code snippet in c#? It's been really hard to find a good example!
amarie:
Hi matiasjaure,
Thanks!
Hi Amarie, did you develop a C# app to connect via BLE and receive data?
I am trying to do that now.
