Hi guys
I'm working on this project that involves using some calculations in processing that stores values for x,y,z that are float variables. I need to be able to send this to arduino, store them and use them for further processing in my arduino sketch.
At the moment, I can print the values of my calculation(in processing) and I've established a simple serial link between both parties to light up the Arduino onboard LED using a mouse click on processing.
- Is what I'm attempting feasible?
- Is it possible to send float values over serial connection? if not, how do you convert it to a string and then read necessary characters in Arduino?
Please find both sketches for Processing and Arduino respectively below
// Processing Read & Write Program incl. Lorenz Attractor
import peasy.;
import processing.serial.;
Serial myPort; // create object from serial class
String val; // data recieved from serial port
boolean firstContact = false;
// Main Program
float x = 0.01;
float y = 0;
float z = 0;
float a = 10;
float b = 28;
float c = 8.0/3.0;
ArrayList points = new ArrayList();
PeasyCam cam;
size(200,200);
String portName = Serial.list()[1]; //change the 0 to a 1 or 2 etc. to match your port
myPort = new Serial(this, "/dev/cu.usbmodem1421", 9600);
myPort.bufferUntil('\n');
void serialEvent( Serial myPort) {
//put the incoming data into a String -
//the '\n' is our end delimiter indicating the end of a complete packet
val = myPort.readStringUntil('\n');
//make sure our data isn't empty before continuing
if (val != null) {
//trim whitespace and formatting characters (like carriage return)
val = trim(val);
println(val);
//look for our 'A' string to start the handshake
//if it's there, clear the buffer, and send a request for data
if (firstContact == false) {
if (val.equals("A")) {
myPort.clear();
firstContact = true;
myPort.write("A");
println("contact");
else { //if we've already established contact, keep getting and parsing data
println(val);
if (mousePressed == true)
{ //if we clicked in the window
myPort.write('1'); //send a 1
println("1");
// when you've parsed the data you have, ask for more:
myPort.write("A");
void draw()
float dt = 0.01;
float dx = (a * (y - x))*dt;
float dy = (x * (b - z) - y)*dt;
float dz = (x * y - c * z)*dt;
x = x + dx;
y = y + dy;
z = z + dz;
int q = Math.round(x);
int w = Math.round(y);
int e = Math.round(z);
// println(x,y,z);
//println(q,w,e);
Arduino:
char val; // Data received from the serial port
int ledPin = 13; // Set the pin to digital I/O 13
boolean ledState = LOW; //to toggle our LED
pinMode(ledPin, OUTPUT); // Set pin as OUTPUT
Serial.begin(9600); // Start serial communication at 9600 bps
establishContact(); // send a byte to establish contact until receiver responds
if (Serial.available() > 0) { // If data is available to read,
val = Serial.read(); // read it and store it in val
if(val == '1') //if we get a 1
ledState = !ledState; //flip the ledState
digitalWrite(ledPin, ledState);
delay(100);
else {
Serial.println("A dog"); //send back a hello world
delay(50);
void establishContact() {
while (Serial.available() <= 0) {
Serial.println("A"); // send a capital A
delay(300);
