I have a perilstatic pump that I'm able to control using Serial Monitor input. This method was explained by the manufacturer's guide.
So, issuing commands is as simple as typing, say: L,0 and pressing Enter (i.e. sending to the pump). Is there any way for these commands to be issued via sketch that I can upload to Ardiuno and that would issue different commands based on inputs from different sensors? In particular, I'm not sure how the syntax for this would look like, nor can I figure it out from the sample code that was provided by the manufacturer (attached).
Does anyone have any idea? I'd appreciate any inputs or even guesses.
//This code was written to be easy to understand.
//Modify this code as you see fit.
//This code will output data to the Arduino serial monitor.
//Type commands into the Arduino serial monitor to control the EZO-PMP Embedded Dosing Pump.
//This code was written in the Arduino 1.8.9 IDE
//An Arduino UNO was used to test this code.
//This code was last tested 6/2019
#include <SoftwareSerial.h> //we have to include the SoftwareSerial library, or else we can't use it
#define rx 2 //define what pin rx is going to be
#define tx 3 //define what pin tx is going to be
SoftwareSerial myserial(rx, tx); //define how the soft serial port is going to work
String inputstring = ""; //a string to hold incoming data from the PC
String devicestring = ""; //a string to hold the data from the Atlas Scientific product
boolean input_string_complete = false; //have we received all the data from the PC
boolean device_string_complete = false; //have we received all the data from the Atlas Scientific product
float ml; //used to hold a floating point number that is the volume
void setup() { //set up the hardware
Serial.begin(9600); //set baud rate for the hardware serial port_0 to 9600
myserial.begin(9600); //set baud rate for the software serial port to 9600
inputstring.reserve(10); //set aside some bytes for receiving data from the PC
devicestring.reserve(30); //set aside some bytes for receiving data from the Atlas Scientific product
void serialEvent() { //if the hardware serial port_0 receives a char
inputstring = Serial.readStringUntil(13); //read the string until we see a <CR>
input_string_complete = true; //set the flag used to tell if we have received a completed string from the PC
void loop() { //here we go...
if (input_string_complete == true) { //if a string from the PC has been received in its entirety
myserial.print(inputstring); //send that string to the Atlas Scientific product
myserial.print('\r'); //add a <CR> to the end of the string
inputstring = ""; //clear the string
input_string_complete = false; //reset the flag used to tell if we have received a completed string from the PC
if (myserial.available() > 0) { //if we see that the Atlas Scientific product has sent a character
char inchar = (char)myserial.read(); //get the char we just received
devicestring += inchar; //add the char to the var called devicestring
if (inchar == '\r') { //if the incoming character is a <CR>
device_string_complete = true; //set the flag
if (device_string_complete == true) { //if a string from the Atlas Scientific product has been received in its entirety
Serial.println(devicestring); //send that string to the PC's serial monitor
if (isdigit(devicestring[0]) || devicestring[0]== '-') { //if the first character in the string is a digit or a "-" sign
ml = devicestring.toFloat(); //convert the string to a floating point number so it can be evaluated by the Arduino
} //in this code we do not use "ml", But if you need to evaluate the ml as a float, this is how it’s done
devicestring = ""; //clear the string
device_string_complete = false; //reset the flag used to tell if we have received a completed string from the Atlas Scientific product
If you know what the commands are, why not simply Serial.print them to the device?
