I'm a student and got my GPS sensor working. This is my code which prints they x and the y in the arduino console.
void displayInfo()
Serial.print(F("Location: "));
delay(10000);
if (gps.location.isValid())
Serial.print(gps.location.lat(), 6);
Serial.print(F(","));
Serial.print(gps.location.lng(), 6);
delay(5000); // after testing please set the delay as 5000.
x = (gps.location.lat());
y = (gps.location.lng());
Serial.print("X");
Serial.println(x);
Serial.print("Y");
Serial.println(y);
Serial.print(F("INVALID"));
I want to send this to a server. I've decided to skip a GPRS module because it is simply to hard for me and I have a deadline next week. How can I send this data to a webserver? I tried ArduGate but the program is broken for me. Someone a suggestion?
I want to send the data like xxx/input.php?x=xxxx&y=xxxx
Thanks,
Marijn
Well if you want a quick and dirty solution, you could download realTerm. Have this running on your machine. realterm can echo the serial port to a tcp/ip port. Your webserver can then collect it from your machine. I'd suggest you get your arduino to use JSON format, then the webserver implementation would be a piece of cake.
But if you get realTerm to "echo" the serial port to, a tcp/ip, then it just acts as a bridge between your arduino and your webserver.
BTW you don't have to use port 23. You can pick any port you like. If you don't have any webserver running on your machine, port 80 is probably as good as any.
As far as I understand it, you have an Arduino program that can send data to a PC.
And you have a webserver running on a different PC, perhaps in a completely different location.
Then you need a PC program that can receive the Arduino data, connect to the webserver and send the data.
It will when you get done writing it. It is not terribly difficult to read from the serial port. It is not terribly difficult to make HTTP type requests - GET, PUT, or POST.
