Hey guys. Can anyone tell me how can I send data (to be precise, it is RFID card's UID that is read with MFRC522) to my database (that is connected to C# program) via ethernet using Mega2560 and ENC28J60? Or maybe anyone can tell me where is problem with my code? It doesn't send any data and I have no idea why...
Please help...
Here is my Arduino code (based on this project)
#include <EtherCard.h>
#include <SPI.h> // RC522 Module uses SPI protocol
#include <MFRC522.h> // Library for Mifare RC522 Devices
#include <DS1302RTC.h>
#include <Time.h>
static byte mymac[] = {0x74,0xDD,0xDD,0x00,0x00,0x01};
static byte server_IP[] = {192,168,0,102};
static int server_Port = 7745;
byte Ethernet::buffer[600];
// Init the DS1302 (external RTC)
// Set pins: CE, IO,CLK
DS1302RTC RTC(45, 43, 41);
// Optional connection for RTC module
#define DS1302_GND_PIN 39
#define DS1302_VCC_PIN 37
#define COMMON_ANODE
#define LED_ON HIGH
#define LED_OFF LOW
#define redLed 3
#define greenLed 5
#define blueLed 7
#define relay 4
int successRead; // Variable integer to keep if we have Successful Read from Reader
byte readCard[4]; // Stores scanned ID read from RFID Module
/* We need to define MFRC522's pins and create instance
* Pin layout should be as follows (on Arduino Mega 2560):
* MOSI: Pin 51 / ICSP-4
* MISO: Pin 50 / ICSP-1
* SCK : Pin 52 / ICSP-3
* SS : Pin 46 (Configurable)
* RST : Pin 34 (Configurable)
* look MFRC522 Library for
* pin configuration for other Arduinos.
#define SS_PIN1 46
#define RST_PIN1 34
MFRC522 mfrc522(SS_PIN1, RST_PIN1); // Create MFRC522 instance.
///////////////////////////////////////// Setup ///////////////////////////////////
Serial.begin(9600); // Initialize serial communications with PC
Serial.print("MAC: ");
for (byte i = 0; i < 6; ++i) {
Serial.print(mymac[i], HEX);
if (i < 5)
Serial.print(':');
if (ether.begin(sizeof Ethernet::buffer, mymac, 53)==0) {
Serial.println( "Failed to access Ethernet controller");
//while(1);
} else Serial.println("Ethernet controller initialized");
if (!ether.dhcpSetup()) {
Serial.println("Failed to get configuration from DHCP");
//while(1);
} else Serial.println("DHCP configuration done:");
ether.printIp("My IP: ", ether.myip);
ether.printIp("Netmask: ", ether.netmask);
ether.printIp("GW IP: ", ether.gwip);
ether.printIp("DNS IP: ", ether.dnsip);
ether.copyIp(ether.hisip, server_IP);
ether.hisport = server_Port;
//Arduino Pin Configuration
pinMode(redLed, OUTPUT);
pinMode(greenLed, OUTPUT);
pinMode(blueLed, OUTPUT);
pinMode(relay, OUTPUT);
digitalWrite(relay, LOW); // Make sure door is locked
digitalWrite(redLed, LED_OFF); // Make sure led is off
digitalWrite(greenLed, LED_OFF); // Make sure led is off
digitalWrite(blueLed, LED_OFF); // Make sure led is off
//Protocol Configuration
SPI.begin(); // MFRC522 Hardware uses SPI protocol
mfrc522.PCD_Init(); // Initialize MFRC522 Hardware
mfrc522.PCD_SetAntennaGain(mfrc522.RxGain_max); //Set Antenna Gain to Max- this will increase reading distance
// Activate RTC module
digitalWrite(DS1302_GND_PIN, LOW);
pinMode(DS1302_GND_PIN, OUTPUT);
digitalWrite(DS1302_VCC_PIN, HIGH);
pinMode(DS1302_VCC_PIN, OUTPUT);
RTC.haltRTC(1); //clock enable (1), clock disable (0)
RTC.writeEN(0); //Write protection OFF (1), write protection ON (0)
//Time set
//setTime(1,19,0,16,12,2014);
//time_t t = now();
//RTC.set(t);
delay(200);
///////////////////////////////////////// Main Loop ///////////////////////////////////
void loop () {
ether.packetLoop(ether.packetReceive());
do {
successRead = getID(); // sets successRead to 1 when we get read from reader otherwise 0
normalModeOn(); // Normal mode, blue Power LED is on, all others are off
while (!successRead); //the program will not go further while you not get a successful read
openDoor();
///////////////////////////////////////// Get PICC's UID ///////////////////////////////////
int getID() {
// Getting ready for Reading PICCs
if ( ! mfrc522.PICC_IsNewCardPresent()) { //If a new PICC placed to RFID reader continue
return 0;
if ( ! mfrc522.PICC_ReadCardSerial()) { //Since a PICC placed get Serial and continue
return 0;
//Serial.println("Scanned PICC's UID:");
for (int i = 0; i < 4; i++) { //
readCard[i] = mfrc522.uid.uidByte[i];
Serial.print(readCard[i], HEX);
Serial.println(readCard[4],HEX);
Stash stash;
byte sd = stash.create();
stash.print(readCard[4]);
stash.print('\r');
stash.save();
Stash::prepare(PSTR("$H"), sd);
ether.tcpSend();
Serial.println("Packet sent!");
Serial.println("");
mfrc522.PICC_HaltA(); // Stop reading
return 1;
//////////////////////////////////////// Normal Mode Leds ///////////////////////////////////
void normalModeOn () {
digitalWrite(blueLed, LED_ON); // Blue LED ON and ready to read card
digitalWrite(redLed, LED_OFF); // Make sure Red LED is off
digitalWrite(greenLed, LED_OFF); // Make sure Green LED is off
digitalWrite(relay, LOW); // Make sure Door is Locked
///////////////////////////////////////// Unlock Door ///////////////////////////////////
void openDoor() {
digitalWrite(blueLed, LED_OFF); // Turn off blue LED
digitalWrite(redLed, LED_OFF); // Turn off red LED
digitalWrite(greenLed, LED_ON); // Turn on green LED
digitalWrite(relay, HIGH); // Unlock door!
delay(1000); // Hold door lock open for given seconds
digitalWrite(relay, LOW); // Relock door
delay(1000); // Hold green LED on for 2 more seconds
///////////////////////////////////////// Failed Access ///////////////////////////////////
void failed() {
digitalWrite(greenLed, LED_OFF); // Make sure green LED is off
digitalWrite(blueLed, LED_OFF); // Make sure blue LED is off
digitalWrite(redLed, LED_ON); // Turn on red LED
delay(2000);
edit: I forgot to tell that I am using ethercard library (I also have UIPEthernet library but don't know how to use it)
