Hi! I met some problem when I try to send email with the Leonardo ETH board. My code is here which is from the playground. I don't know why it doesn't work. Can anyone give me a help? It always fail to connect the SMTP server. Thank you very much!
Email client sketch for IDE v1.0.5 and w5100/w5200
Posted 7 May 2015 by SurferTim
#include <SPI.h>
#include <Ethernet2.h>
// #include<Ethernet.h>
// this must be unique
byte mac[] = { 0x90, 0xA2, 0xDA, 0x11, 0x21, 0xFE };
// change network settings to yours
IPAddress ip(10, 118, 16, 233);
IPAddress gateway( 10, 118, 19, 250 );
IPAddress subnet( 255, 255, 252, 0 );
char server[] = "smtpcorp.com";
int port = 2525;
EthernetClient client;
pinMode(4,OUTPUT);
digitalWrite(4,HIGH);
Ethernet.begin(mac, ip, gateway, subnet);
delay(2000);
Serial.println(F("Ready. Press 'e' to send."));
byte inChar;
inChar = Serial.read();
if(inChar == 'e')
if(sendEmail()) Serial.println(F("Email sent"));
else Serial.println(F("Email failed"));
byte sendEmail()
byte thisByte = 0;
byte respCode;
client.connect(server,port);
if(client.connected() == 1) {
Serial.println(F("connected"));
Serial.println(F("connection failed"));
return 0;
if(!eRcv()) return 0;
Serial.println(F("Sending hello"));
// replace 1.2.3.4 with your Arduino's ip
client.println("EHLO 10.118.16.233");
Serial.println(F("Sending auth login"));
client.println("auth login");
Serial.println(F("Sending User"));
// Change to your base64 encoded user
client.println("eXV4dWRvbmcwNzE2QGdtYWlsLmNvbQ==");
Serial.println(F("Sending Password"));
// change to your base64 encoded password
client.println("QVRQMTk5NjA3MTZ4");
// change to your email address (sender)
Serial.println(F("Sending From"));
client.println("MAIL From: xxxxx@gmail.com");
// change to recipient address
Serial.println(F("Sending To"));
client.println("RCPT To: yyyyy@yourdomain.com");
Serial.println(F("Sending DATA"));
client.println("DATA");
Serial.println(F("Sending email"));
client.println("To: You yyyyy@yourdomain.com");
// change to your address
client.println("From: Me xxxxx@gmail.com");
client.println("Subject: Arduino email test\r\n");
client.println("This is from my Arduino!");
client.println(".");
Serial.println(F("Sending QUIT"));
client.println("QUIT");
client.stop();
Serial.println(F("disconnected"));
return 1;
byte eRcv()
byte respCode;
byte thisByte;
int loopCount = 0;
while(!client.available()) {
delay(1);
loopCount++;
// if nothing received for 10 seconds, timeout
if(loopCount > 10000) {
client.stop();
Serial.println(F("\r\nTimeout"));
return 0;
respCode = client.peek();
while(client.available())
thisByte = client.read();
Serial.write(thisByte);
if(respCode >= '4')
efail();
return 0;
return 1;
void efail()
byte thisByte = 0;
int loopCount = 0;
client.println(F("QUIT"));
delay(1);
loopCount++;
client.stop();
return;
client.stop();
