Sending inference data from esp32 camera to arduino mega
hi, i am working on sending the inference data from esp32 camera to the arduino mega and the wiring i used is similar to this
and for the inference i modified the code using this
my arduino doesnt receive the data from the esp32 even though i have properly written the code. I am still new with using edge impulse and esp32 so I just modified the code acccording to what I saw them do.
this is the code for the esp32
 * Copyright (c) 2022 EdgeImpulse Inc.
 * Permission is hereby granted, free of charge, to any person obtaining a copy
 * of this software and associated documentation files (the "Software"), to deal
 * in the Software without restriction, including without limitation the rights
 * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
 * copies of the Software, and to permit persons to whom the Software is
 * furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
 * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
 * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
 * SOFTWARE.
/* Includes ---------------------------------------------------------------- */
#include <capt_jade-project-1_inferencing.h>
#include "edge-impulse-sdk/dsp/image/image.hpp"
#include "esp_camera.h"
#define RXp2 14
#define TXp2 15
// Select camera model - find more camera models in camera_pins.h file here
// https://github.com/espressif/arduino-esp32/blob/master/libraries/ESP32/examples/Camera/CameraWebServer/camera_pins.h
#define CAMERA_MODEL_ESP_EYE // Has PSRAM
//#define CAMERA_MODEL_AI_THINKER // Has PSRAM
#if defined(CAMERA_MODEL_ESP_EYE)
#define PWDN_GPIO_NUM    -1
#define RESET_GPIO_NUM   -1
#define XCLK_GPIO_NUM    4
#define SIOD_GPIO_NUM    18
#define SIOC_GPIO_NUM    23
#define Y9_GPIO_NUM      36
#define Y8_GPIO_NUM      37
#define Y7_GPIO_NUM      38
#define Y6_GPIO_NUM      39
#define Y5_GPIO_NUM      35
#define Y4_GPIO_NUM      14
#define Y3_GPIO_NUM      13
#define Y2_GPIO_NUM      34
#define VSYNC_GPIO_NUM   5
#define HREF_GPIO_NUM    27
#define PCLK_GPIO_NUM    25
#elif defined(CAMERA_MODEL_AI_THINKER)
#define PWDN_GPIO_NUM     32
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
#else
#error "Camera model not selected"
#endif
/* Constant defines -------------------------------------------------------- */
#define EI_CAMERA_RAW_FRAME_BUFFER_COLS           320
#define EI_CAMERA_RAW_FRAME_BUFFER_ROWS           240
#define EI_CAMERA_FRAME_BYTE_SIZE                 3
/* Private variables ------------------------------------------------------- */
static bool debug_nn = false; // Set this to true to see e.g. features generated from the raw signal
static bool is_initialised = false;
uint8_t *snapshot_buf; //points to the output of the capture
static camera_config_t camera_config = {
    .pin_pwdn = PWDN_GPIO_NUM,
    .pin_reset = RESET_GPIO_NUM,
    .pin_xclk = XCLK_GPIO_NUM,
    .pin_sscb_sda = SIOD_GPIO_NUM,
    .pin_sscb_scl = SIOC_GPIO_NUM,
    .pin_d7 = Y9_GPIO_NUM,
    .pin_d6 = Y8_GPIO_NUM,
    .pin_d5 = Y7_GPIO_NUM,
    .pin_d4 = Y6_GPIO_NUM,
    .pin_d3 = Y5_GPIO_NUM,
    .pin_d2 = Y4_GPIO_NUM,
    .pin_d1 = Y3_GPIO_NUM,
    .pin_d0 = Y2_GPIO_NUM,
    .pin_vsync = VSYNC_GPIO_NUM,
    .pin_href = HREF_GPIO_NUM,
    .pin_pclk = PCLK_GPIO_NUM,
    //XCLK 20MHz or 10MHz for OV2640 double FPS (Experimental)
    .xclk_freq_hz = 20000000,
    .ledc_timer = LEDC_TIMER_0,
    .ledc_channel = LEDC_CHANNEL_0,
    .pixel_format = PIXFORMAT_JPEG, //YUV422,GRAYSCALE,RGB565,JPEG
    .frame_size = FRAMESIZE_QVGA,    //QQVGA-UXGA Do not use sizes above QVGA when not JPEG
    .jpeg_quality = 12, //0-63 lower number means higher quality
    .fb_count = 1,       //if more than one, i2s runs in continuous mode. Use only with JPEG
    .fb_location = CAMERA_FB_IN_PSRAM,
    .grab_mode = CAMERA_GRAB_WHEN_EMPTY,
/* Function definitions ------------------------------------------------------- */
bool ei_camera_init(void);
void ei_camera_deinit(void);
bool ei_camera_capture(uint32_t img_width, uint32_t img_height, uint8_t *out_buf) ;
* @brief      Arduino setup function
    Serial2.begin(115200, SERIAL_8N1, RXp2, TXp2);
    //comment out the below line to start inference immediately after upload
    while (!Serial);
    Serial.println("Edge Impulse Inferencing Demo");
    if (ei_camera_init() == false) {
        ei_printf("Failed to initialize Camera!\r\n");
    else {
        ei_printf("Camera initialized\r\n");
    ei_printf("\nStarting continious inference in 2 seconds...\n");
    ei_sleep(2000);
* @brief      Get data and run inferencing
* @param[in]  debug  Get debug info if true
    // instead of wait_ms, we'll wait on the signal, this allows threads to cancel us...
    if (ei_sleep(5) != EI_IMPULSE_OK) {
        return;
    snapshot_buf = (uint8_t*)malloc(EI_CAMERA_RAW_FRAME_BUFFER_COLS * EI_CAMERA_RAW_FRAME_BUFFER_ROWS * EI_CAMERA_FRAME_BYTE_SIZE);
    // check if allocation was successful
    if(snapshot_buf == nullptr) {
        ei_printf("ERR: Failed to allocate snapshot buffer!\n");
        return;
    ei::signal_t signal;
    signal.total_length = EI_CLASSIFIER_INPUT_WIDTH * EI_CLASSIFIER_INPUT_HEIGHT;
    signal.get_data = &ei_camera_get_data;
    if (ei_camera_capture((size_t)EI_CLASSIFIER_INPUT_WIDTH, (size_t)EI_CLASSIFIER_INPUT_HEIGHT, snapshot_buf) == false) {
        ei_printf("Failed to capture image\r\n");
        free(snapshot_buf);
        return;
    // Run the classifier
    ei_impulse_result_t result = { 0 };
    EI_IMPULSE_ERROR err = run_classifier(&signal, &result, debug_nn);
    if (err != EI_IMPULSE_OK) {
        ei_printf("ERR: Failed to run classifier (%d)\n", err);
        return;
    // print the predictions
    ei_printf("Predictions (DSP: %d ms., Classification: %d ms., Anomaly: %d ms.): \n",
                result.timing.dsp, result.timing.classification, result.timing.anomaly);
#if EI_CLASSIFIER_OBJECT_DETECTION == 1
    bool bb_found = result.bounding_boxes[0].value > 0;
    for (size_t ix = 0; ix < result.bounding_boxes_count; ix++)
        auto bb = result.bounding_boxes[ix];
        if (bb.value == 0) { continue; }
        ei_printf("    %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\n", bb.label, bb.value, bb.x, bb.y, bb.width, bb.height);
        if (result.classification[ix].value > 0.1)
          Serial2.println("Detected");
          Serial.println("Detected"); //local serial print
    if (!bb_found) { ei_printf("    No objects found\n");  }
#else
    for (size_t ix = 0; ix < EI_CLASSIFIER_LABEL_COUNT; ix++)
        ei_printf("    %s: %.5f\n", result.classification[ix].label,
                                    result.classification[ix].value);
#endif
#if EI_CLASSIFIER_HAS_ANOMALY == 1
        ei_printf("    anomaly score: %.3f\n", result.anomaly);
#endif
    free(snapshot_buf);
 * @brief   Setup image sensor & start streaming
 * @retval  false if initialisation failed
bool ei_camera_init(void) {
    if (is_initialised) return true;
  pinMode(13, INPUT_PULLUP);
  pinMode(14, INPUT_PULLUP);
#endif
    //initialize the camera
    esp_err_t err = esp_camera_init(&camera_config);
    if (err != ESP_OK) {
      Serial.printf("Camera init failed with error 0x%x\n", err);
      return false;
    sensor_t * s = esp_camera_sensor_get();
    // initial sensors are flipped vertically and colors are a bit saturated
    if (s->id.PID == OV3660_PID) {
      s->set_vflip(s, 1); // flip it back
      s->set_brightness(s, 1); // up the brightness just a bit
      s->set_saturation(s, 0); // lower the saturation
#if defined(CAMERA_MODEL_M5STACK_WIDE)
    s->set_vflip(s, 1);
    s->set_hmirror(s, 1);
#elif defined(CAMERA_MODEL_ESP_EYE)
    s->set_vflip(s, 1);
    s->set_awb_gain(s, 1);
#endif
    is_initialised = true;
    return true;
 * @brief      Stop streaming of sensor data
void ei_camera_deinit(void) {
    //deinitialize the camera
    esp_err_t err = esp_camera_deinit();
    if (err != ESP_OK)
        ei_printf("Camera deinit failed\n");
        return;
    return;
 * @brief      Capture, rescale and crop image
 * @param[in]  img_width     width of output image
 * @param[in]  img_height    height of output image
 * @param[in]  out_buf       pointer to store output image, NULL may be used
 *                           if ei_camera_frame_buffer is to be used for capture and resize/cropping.
 * @retval     false if not initialised, image captured, rescaled or cropped failed
bool ei_camera_capture(uint32_t img_width, uint32_t img_height, uint8_t *out_buf) {
    bool do_resize = false;
    if (!is_initialised) {
        ei_printf("ERR: Camera is not initialized\r\n");
        return false;
    camera_fb_t *fb = esp_camera_fb_get();
    if (!fb) {
        ei_printf("Camera capture failed\n");
        return false;
   bool converted = fmt2rgb888(fb->buf, fb->len, PIXFORMAT_JPEG, snapshot_buf);
   esp_camera_fb_return(fb);
   if(!converted){
       ei_printf("Conversion failed\n");
       return false;
    if ((img_width != EI_CAMERA_RAW_FRAME_BUFFER_COLS)
        || (img_height != EI_CAMERA_RAW_FRAME_BUFFER_ROWS)) {
        do_resize = true;
    if (do_resize) {
        ei::image::processing::crop_and_interpolate_rgb888(
        out_buf,
        EI_CAMERA_RAW_FRAME_BUFFER_COLS,
        EI_CAMERA_RAW_FRAME_BUFFER_ROWS,
        out_buf,
        img_width,
        img_height);
    return true;
static int ei_camera_get_data(size_t offset, size_t length, float *out_ptr)
    // we already have a RGB888 buffer, so recalculate offset into pixel index
    size_t pixel_ix = offset * 3;
    size_t pixels_left = length;
    size_t out_ptr_ix = 0;
    while (pixels_left != 0) {
        out_ptr[out_ptr_ix] = (snapshot_buf[pixel_ix] << 16) + (snapshot_buf[pixel_ix + 1] << 😎 + snapshot_buf[pixel_ix + 2];
        // go to the next pixel
        out_ptr_ix++;
        pixel_ix+=3;
        pixels_left--;
    // and done!
    return 0;
#if !defined(EI_CLASSIFIER_SENSOR) || EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_CAMERA
#error "Invalid model for current sensor"
#endif
and the code for the mega which will receive the signal
// Arduino Mega serial1 test
// mega pin 18 is Tx
//      pin 19 is Rx
// for loopback test connect pin 18 to pin 19
// for RS232 shield connect pin 18 to Tx and pin 19 to Rx
// for loopback test connect 9 pin D connector pins 2 and 3
unsigned long time;
  Serial.begin(115200);   // initialise serial monitor port
  Serial1.begin(115200);  // initialise Serial1
  Serial.write("Arduino Mega Serial1 test -  for loopback test connect pin 18 to pin 19\n");
  if (Serial1.available())        // read from Serial1 output to Serial
    Serial.write(Serial1.read());
  if (Serial.available()) {       // read from Serial outut to Serial1
    int inByte = Serial.read();
    //Serial.write(inByte);     // local echo if required
    Serial1.write(inByte);
type or paste code here
1. I would suggest that you first manage to send a simple byte type (say: 0x05) data from ESP32-CAM Module to MEGA using U0T(TX0, Fig-2)) -pin of ESP32-CAM. You can connect U0T(TX0, Fig-2)-pin of ESP32-CAM directly with RX2-pin of MEGA without any level shifter, but the UOR(RX0)-pin of ESP32-CAM would require level shifter for which you can use simple voltage divider or the following one (Fig-1).
Figure-1:
2. Note: For some of the ESP32-CAM board, the GND-pin near the right-bottom is a false GND-pin; so, use the GND-pin near the 5V-pin at the left-top (Fig-2).
Figure-2:
3. Receiving "I am ESP32-CAM!" message from ESP32-CAM by MEGA at 2-sec interval; MEGA shows the message on its Serial Monitor. After sending the message, ESP32-CAmM just makes a short blink on it onboard LED1 (Fig-4).
(1) Upload the following sketch into ESP32-CAM Board using ESP32-CAM-MB adapter module (Fig-3).
ESP32-CAM Sender Sketch:
#define LED1 33
  pinMode(LED1, OUTPUT);
  Serial.println("I am ESP32-CAM!");
  digitalWrite(LED1, HIGH);
  delay(100);
  digitalWrite(LED1, LOW);
  delay(100);
  delay(2000);
Figure-3:
(2) Upload the following sketch in MEGA.
MEGA Receiver Sketch:
char myData[30];
  Serial2.begin(9600);
  byte n = Serial2.available();
  if(n != 0)
    byte m = Serial2.readBytesUntil('\n', myData, sizeof myData-1);
    Serial.println(myData);
    myData[m] = '\0';
(3) Remove ESP32-CAM Board from the ESP32-CAM-MB adapter module.
(4) Connect MEGA and ESP32-CAM boards as per Fig-4.
Figure-4:
(5) Press RST buttons of both MEGA and ESP32-CAM.
(6) Open SM of MEGA Bd = 9600.
(7) Check that SM of MEGA shows the following message at 2-sec interval
I am ESP32-CAM!
I am ESP32-CAM!
8. This is (Fig-5) the recommended conncetion between MEGA and ESP32-CAM using level shifter.
Figure-5:
Logic level shifters are required for communications between 3.3V and 5V processors. Without them, you cannot expect communications to work and you risk doing damage to both CPUs.
One similar to this will work.
Likely the ESP32-CAM Board and NOT the MEGA which will reliably recognize 3.3V as HIGH.
did you try the simple serial test programs for transmitting data between the Mega and ESP32-CAM in post communication-between-esp32-cam-and-arduino-uno
get the basic communications test working before attempting any advanced processing
the Mega uses 5V logic the ESP32 3.3V logic you therefore require a potential divider on the Mega serial Tx to ESP-32-CAM Rx line (as shown in the diagram in the post) or a level shifter as suggested by @GolamMostafa
The Mega can be damaged by excessive current flow from the 5V TX output pin.
The very best approach is to connect processors that both operate at the same logic voltages.
The data sheets of ATmega2650 says: IIH = 1 uA which means that the maximum leakage current to the input of the RX-pin (any I/O pin) of MEGA is 1 uA at VIH.
Using level shifter (Fig-1):
Figure-1:
Please read the above line again. It is a serious mistake to connect a 5V output to a 3.3V input, which can damage both the 5V processor and the 3.3V processor.
Yes! Now, I have understood as the above parapharased line has contained other objects which were missing in the original sentence.
