Sending long values through CAN Bus
Hello
I need to pass large values ​​by can bus and receive them. Both in arduino.
I am using the Seed Studio library
They are values ​​that I pass are in int32_t format
For example, the altitude given by a gps in feet is 18000.45 ft, I would have to pass 1800045, or some gps coordinates, for example -83.481029, 179.950935 which would have to pass as -83481029, 179950935
My question is how to put in an 8 byte char array and how to read it.
//Send Code
#include <mcp_can.h>
#include <SPI.h>
const int SPI_CS_PIN = 10;
MCP_CAN CAN(SPI_CS_PIN);
unsigned char canMsgAlt[8] = {0, 0, 0, 0, 0, 0, 0, 0};
int32_t altData = 1800045;
    while (CAN_OK != CAN.begin(CAN_500KBPS)) {            // init can bus : baudrate = 500k
        Serial.println("CAN BUS Shield init fail");
        Serial.println(" Init CAN BUS Shield again");
        delay(100);
    Serial.println("CAN BUS Shield init ok!");
    canMsgAlt[0] = altData;
    canMsgAlt[1] = altData >> 8;
    canMsgAlt[2] = altData >> 16;
    CAN.sendMsgBuf(321, 0, 3, canMsgAlt);
    Serial.println(altData);//Print for debug
//Receive and print code
#include <SPI.h>
#include "mcp_can.h"
MCP_CAN CAN(SPI_CS_PIN);                                    // Set CS pin
        delay(100);
    unsigned char len = 0;
    unsigned char buf[8];
    if (CAN_MSGAVAIL == CAN.checkReceive()) {         // check if data coming
        CAN.readMsgBuf(&len, buf);    // read data,  len: data length, buf: data buf
        if (CAN.getCanId()== 321){
            float altitude = (buf[0])|(buf[1]<<8)|(buf[2]<<16);
            Serial.print("Altitude: ");
            Serial.println(altitude/100);
jcduino:
what's the issue with the code you posted?
I'm printing another value, 30573 instead 1800045. It seems that there is not printing the full value in this expression:
Serial.println(altitude);
If I print each buf value I print 1b776d (in three lines, one por each buf*) that its 1800045, but if I print the code above I print 776d that is 30573. This is my problem...*
jcduino:
If I print each buf _value I print 1b776d (in three lines, one por each buf*) that its 1800045, but if I print the code above I print 776d that is 30573. This is my problem...*_
_*[/quote]*_
<em><em>That probably because of the data type you chose for 'altitude' to be **float**. try changing that to uint32_t first. that probably will fix you problem IMHO</em></em>
_*hope that helps...*_
I've change it to uint32_t and int32_t and write the same value, 30573 (776d) instead 1800045 (1b776d).
jcduino:
forgot to mention you probably would have needed 'type casting' as well ie:
uint32_t altitude = ((uint32_t)buf[0])|((uint32_t)buf[1]<<8)|((uint32_t)buf[2]<<16);
I've tried it but it's the same result.
jcduino:
that is strange... you could always try a different appoach to re-combining the bytes; something like this maybe:
int32_t altitude = buf[2];
altitude = (altitude<<8)|buf[1];
altitude = (altitude<<8)|buf[0];
hope that helps...
sherzaad:
hope that helps...
Yes! this works perfectly!! Thank you!
The original approach was do it in a single line, but this method works well.
Thank you again!
Best regards!
There is a little update.
I've seen the key for my seach in google.
sherzaad:
is the key for searching, I'm not fluent in english...
I've got some improvements
This works for me:
long altitude = (long)buf[3]<<24|(long)buf[2]<<16|(long)buf[1]<<8|(long)buf[0];
The cast, as you told me and do not put the buf*<<n into ()*
(long)buf*<<n[/b] works*
(long)(buf*<<n) [/b]not works*
I've changed the type to long, thats I think is arduino native and I've added (long)buf[3]<<24 because may be I need some negatives values that I coudn't obtain with (long)buf[2]<<16
And now works fine.
