Hi, I know absolutely zero about Arduino, I don't even know if this is the correct subforum to post to..
I'm work at a theatre as a "soundguy". I looking for a solution where actors on stage have small triggers on them to trigger some audio cues in the software, Qlab, which can take OSC. Wirelessly.
From my googling I've found that ESP8266 and Switch is a combo, from seeing this:
Unfortunately I don't know how anything of this works together, and there's no link or anything in the YT video.
So, this is a very "I know absolutely nothing question".
I want the setup which sends OSC to be as small as possible.
Where do I start when it comes to components in the arduino end?
Thanks! That's a start. So there needs to be a slave and master. I can't have a slave sending messages directly to a Mac, connected through a router?
I'd need to have slave(s) transmit to a master, which how then relays these signals to the Mac? In my mind this would go through a wireless router/AP on the stage, and sends signal to the Mac via ethernet cable.
I found an off the shelf product which probably does what I need, and has the small form factor.
I ordered some Flic-buttons. Which will send BT to a nearby laptop (BT-range). Software in that laptop will convert button presses to keyboard presses, which will trigger cues in that Qlab, which then will send OSC to Qlab at the mixing desk making all the noises, via an ethernet cable.
