Hello guys,
I have been doing a lot of research about this and I haven't found a solution yet. My problem is the next one:
I am using I2C to interface an Arbotix Robocontroller (16MHz AVR microcontroller (ATMEGA644p)) with a RPI and I want to use C++ in the RPI side (Not Python). The reason why is basically because I have an entire algorithm that I need to run in RPI (using OpenCV) and written in C++, that's why I need C++ in RPI. I found this code online (Sending float from arduino to raspberry pi using Wire (arduino) and smbus (python) libraries · GitHub), that works perfectly but uses Python in RPI. I am wondering if I could do something similar in C++.
In addition I have tried this code too (Connecting an Arduino to a Raspberry PI using I2C – Peter Mount's Blog) that uses C++ in RPI, but it receives only 1 byte, no negative values, no floats, only from 0-255. I have tried to modify the code by requesting more than 1 byte but no luck, it seems that is stores always in the same buffer.
I attach here the last code that I have tried in Arduino, trying to send the number in different packages but for some reason the RPI always skips the first number sent (b1) and only displays b2. I guess is more a problem with the receiver side rather than the sender side, but I would like to know your opinion and if anyone can help me. BTW the RPI is the Master and the Arbotix the Slave.
Thank you so much.
#include <Wire.h>
#define SLAVE_ADDRESS 0x04
unsigned int number = 0;
int state = 0;
int num;
int rem;
double temp;
pinMode(0, OUTPUT);
// initialize i2c as slave
Wire.begin(SLAVE_ADDRESS);
// define callbacks for i2c communication
Wire.onReceive(receiveData);
Wire.onRequest(sendData);
delay(100);
// callback for received data
void receiveData(int byteCount){
while(Wire.available()) {
number = Wire.read();
if (number == 1){
if (state == 0){
digitalWrite(0, HIGH); // set the LED on
state = 1;
} else{
digitalWrite(0, LOW); // set the LED off
state = 0;
if(number==2) {
number = 0x123;
//int n=256;
//num=number/n;
//rem=number%n;
//Serial.println(b1);
//Serial.println(b2);
//num=num<<4;
//rem+=num;
//Wire.write(num);
//Wire.write(rem);
// callback for sending data
void sendData(){
//Wire.write(num);
unsigned char b1=0x12;
unsigned char b2=0x34;
//b1=(0xFF&number);
//b2=((0xFF00&number)>>8);
Wire.write(b1);
Wire.write(b2);
Serial.println(b1);
Serial.println(b2);
//Wire.write(number);
