I'm working on a project where i can measure the temperature and send this to a nice webpage. This webpage will contain a nice interface which can show the real time temperature on the arduino. Unfortunately i have a really lack of knowledge of HTML and it's really hard for me to finish this school project. I hope you guys can help me out the current situation.
Currently i'm able to send a .htm webpage to the IP of the arduino and view this webpage with a nice interface. Now i'm trying to get real life temperature off the arduino and my brother helped me out to code the HTML website. This is what it looks like atm:
192.168.0.103 --> When i type this, the webpage appears. The code i wrote is to get the temperature from another .htm server, like 192.168.0.103/temp.htm
This is what i'm using atm:
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
// client.println("Host: 192.169.0.103/index.htm");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println();
webFile = SD.open("index.php"); // open web page file
if (webFile) {
while (webFile.available()) {
client.write(webFile.read()); // send web page to client
webFile.close();
Now i want to open a second page with 192.168.0.103/temp.htm to show the index.htm can request the temperature from that page. Does anyone know how to do this?
You can not "send data to a web page". A web page is something that a browser displays. If the Arduino is a server, it can serve up a web page whose content is the temperature (possibly among other things).
If the Arduino is a client, it can send data to a server, as part of a GET request. The server can store the data somewhere where other code can get at is, such as in a RDBMS.
No, you can't. You can NOT send a htm page to an IP address. That is NOT what a browser does.
Not really sure what you are talking about, but you can embed a web page in a frame inside of the main web page. Bekow is some server test code with embedded pages.
// zoomkat's meta refresh data frame test page 5/25/13
// use http://192.168.1.102:84 in your brouser for main page
// http://192.168.1.102:84/data static data page
// http://192.168.1.102:84/datastart meta refresh data page
// for use with W5100 based ethernet shields
// set the refresh rate to 0 for fastest update
// use STOP for single data updates
#include <SPI.h>
#include <Ethernet.h>
const int analogInPin0 = A0;
const int analogInPin1 = A1;
const int analogInPin2 = A2;
const int analogInPin3 = A3;
const int analogInPin4 = A4;
const int analogInPin5 = A5;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // arduino ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
unsigned long int x=0; //set refresh counter to 0
String readString;
void setup(){
// disable SD SPI if memory card in the uSD slot
pinMode(4,OUTPUT);
digitalWrite(4,HIGH);
Ethernet.begin(mac, ip, gateway, gateway, subnet);
server.begin();
Serial.println("meta refresh data frame test 5/25/13"); // so I can keep track of what is loaded
void loop(){
if (client) {
if (readString.length() < 100) {
readString += c;
//check if HTTP request has ended
if (c == '\n') {
//check get atring received
Serial.println(readString);
//output HTML data header
client.println();
//generate data page
if(readString.indexOf("data") >0) { //checks for "data" page
x=x+1; //page upload counter
client.print("<HTML><HEAD>");
//meta-refresh page every 1 seconds if "datastart" page
if(readString.indexOf("datastart") >0) client.print("<meta http-equiv='refresh' content='1'>");
//meta-refresh 0 for fast data
if(readString.indexOf("datafast") >0) client.print("<meta http-equiv='refresh' content='0'>");
client.print("<title>Zoomkat's meta-refresh test</title></head><BODY>
client.print("page refresh number: ");
client.print(x); //current refresh count
client.print("
//output the value of each analog input pin
client.print("analog input0 is: ");
client.print(analogRead(analogInPin0));
client.print("
analog input1 is: ");
client.print(analogRead(analogInPin1));
client.print("
analog input2 is: ");
client.print(analogRead(analogInPin2));
client.print("
analog input3 is: ");
client.print(analogRead(analogInPin3));
client.print("
analog input4 is: ");
client.print(analogRead(analogInPin4));
client.print("
analog input5 is: ");
client.print(analogRead(analogInPin5));
client.println("
</BODY></HTML>");
//generate main page with iframe
client.print("<HTML><HEAD><TITLE>Zoomkat's frame refresh test</TITLE></HEAD>");
client.print("Zoomkat's Arduino frame meta refresh test 5/25/13");
client.print("
Arduino analog input data frame:
client.print(" <a href='http://192.168.1.102:84/datastart' target='DataBox' title=''yy''>META-REFRESH</a>");
client.print(" <a href='http://192.168.1.102:84/data' target='DataBox' title=''xx''>SINGLE-STOP</a>");
client.print(" <a href='http://192.168.1.102:84/datafast' target='DataBox' title=''zz''>FAST-DATA</a>
client.print("<iframe src='http://192.168.1.102:84/data' width='350' height='250' name='DataBox'>");
client.print("</iframe>
</HTML>");
delay(1);
//stopping client
client.stop();
//clearing string for next read
readString="";
PaulS:
If your brother thought that was a host NAME or IP, he's an idiot.
I just tried out the last piece myself just to see what would happen. I just asked for some help because of my lack of knowledge, there is absolutely no reason to talk about my brother like that.
Anyway, i found out i can use ThingSpeak to show graphs etc. which i will use from now on.
