Greetings:
Has anyone worked with the arduino and the Sensirion SHT11 humidity and temperature sensor? I have working code for basic stamp but not the arduino.
Thanks for any help you can offer,
JLK
Greetings:
JLK
hi
try this
http://framistats.com/arduino-projects/the-mashup-arduino-mini-sht11-bluesmirf/
good luck
Will do. Thank you!
I am trying to work this problem out as well, but ultimately I need the values to be read by Max, Msp. The ultrasound sensor was simple- It had an analogue output.. likewise the photocell could be overocme with a simple voltage divider.
This more complicated sensor is ..well.. more complicated.
any help appreciated.
The link above has helped a lot so far. I will post my results when I am done.
