Appologies if this is considered a cross post between here and adafruit where I also asked the question. Just a newbie looking for some guidance.
I’m working with an Arduino UNO, the Sharp IR Sensor (GP2Y0A21YK0F), and a 3.5mm Stereo Headphone Jack (ADAFRUIT PRODUCT ID: 1699). My problem is that once I load the following code onto the arduino I receive a constant high pitched tick/pulse of audio, but when my sensor trips the threshold I recieve the proper tone from the playtone function. I would like for the ticking/pulsing to go away and be left with silence until my ‘distsensor’ is tripped (see code). Can someone point out what I’m doing wrong? Thanks in advance folks! >> I could always email an audio file to someone if that would help. Thought - it sounds like the
int pinSpeaker = 10; //Set up a speaker on a PWM pin (digital 9, 10, or 11)
int val = 0; // variable for reading the pin status
Serial.begin(9600); // set up Serial library at 9600 bps
Serial.println(F("Sonar test!"));
pinMode(pinSpeaker, OUTPUT); // declare speaker as output
int distsensor, i;
long time;
distsensor = 0;
for (i=0; i<8; i++) {
distsensor += analogRead(0);
//delay(500);
distsensor /= 8;
Serial.print(F("Sensor = ")); Serial.println(distsensor);
if (distsensor > 300) {
playTone(300, 160);
//delay(150);
//if (distsensor > 500) {
void playTone(long duration, int freq) {
duration *= 500;
int period = (1.0 / freq) * 1000000;
long elapsed_time = 0;
while (elapsed_time < duration) {
digitalWrite(pinSpeaker,HIGH);
delayMicroseconds(period / 2);
digitalWrite(pinSpeaker, LOW);
elapsed_time += (period);
Don't know what causes the ticks, however, you could try to use the Arduino Tone library, it uses timer interrupts instead of delays, which is a much 'cleaner' approach.
The high pitched noise is inherent in sticking a speaker on a digital output - you are hearing the
digital noise on the 5V supply caused by the microcontroller running or the Sharp sensor or both.
Listening to such noise can even be a useful way to debug code as the sounds depends on the
pattern of behaviour of the code.
Removing it is done by buffering the signal using an inverter/buffer chip powered from a clean
power supply used just for audio (best if that's not from a DC-DC converter direct, but from
a linear voltage regulator which can reject switching noise). That gives a clean version of the
logic signal without all the hash from the digital supply.
PieterP:
Don’t know what causes the ticks, however, you could try to use the Arduino Tone library, it uses timer interrupts instead of delays, which is a much ‘cleaner’ approach.
Hi and thanks for responding… I did try the tone library but encountered the same results (see code). What I did learn is that if I comment out the pinspeaker I do not get the ticking, but I also do not get the tone. To that end I think MarkT is correct in that the ticking I’m hearing is caused by the Sharp sensor. Unless this can be rseolved by code (which I don’t think is the case, I’m going to have to start looking into a linear voltage regulator.
//int pinSpeaker = 10; //Set up a speaker on a PWM pin (digital 9, 10, or 11)
//pinMode(pinSpeaker, OUTPUT); // declare speaker as output
int distsensor, i;
//long time;
distsensor = 0;
//delay(500);
distsensor /= 8;
//if (distsensor < 300) {
// noTone(A2);
//playTone(300, 160);
//delay(150);
tone(A2, 750, 250);
noTone(A2);
/*void playTone(long duration, int freq) {
duration *= 500;
MarkT:
Hi Mark and thanks for your reply. Perfect! The voltage regulator did the trick producing the exact results I was looking for. Guess who learned something new about digital output today
