Hello from Ontario Canada,
I am new to Arduino but excited to start on a new project idea
This project is focused on detecting very small objects.
I know ultrasonic sensors can detect proximity but my question is is it capable of differentiating between different objects?
i.e. can we have it to react differently to a specific very tiny object while there are other objects in close proximity?
the item is very tiny 3-5mm in diameter and the detection should be done from about 30-50cm where the sensor is held like a handset and pointed towards a box containing many items including the targeted small item but the target item might not be visible where is it exactly in the box.
This link is an example to show just the general “size of the item” and not the material or the technology… it is even smaller in the link but you get the idea
It could be made of items like foil, plastic, chip or anything, just need it to be specifically detected once under the coverage range of the sensor and don’t care if the sensor does not react to other objects at all.
There are some very tiny RFID chips but the detectors are very big and can’t detect from that distance and all that is really needed is to detect the presence of the small object and not read data out of it.
If this is not possible with an Ultrasonic sensor, would appreciate a pointer what sensor should be used for such project.
Thanks,
Ahmad
